Trailer Plug Relocation
Discussion in 'Towing' started by Sccafire, Jul 5, 2015.
  1. Jul 5, 2015 at 7:00 PM
    Sccafire
    Sccafire [OP] KMG 365
    Cleburne, Texas
    2023 Jeep Gladiator Rubicon
    For those that have relocated the trailer plug into their stock rear bumper. Is the factory wiring harness long enough? Also, what size hole saw did you use to cut the hole?
    I have seen a bracket that is made to relocate the plug under the truck. I do not wish to go that route.
  2. Jul 5, 2015 at 7:22 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    No hole saw needed.
    Simply remove the driver side license plate light, and with some very minor trimming of the plastic on the backside of the plug you can get it to sit flush on the bumper. 2 small holes, 2 small bolts and lock nuts and boom, factory looking location up and out of the way.
    Cost = 1.50 for the 2 nuts n bolts.
  3. Jul 5, 2015 at 8:48 PM
    Pigpen
    Northwest Montana
    Access cab toolbox/ dog bed with seats and headrests deleted, waterproof TRD seat covers, yellow wire mod, diff breather relocated to tail light, engine block heater, Leer topper with Yakima tracks and rack, Yakima rack on cab, Ride Rite with Daystar cradles, CBI hidden front hitch, wired for winch front and rear Warn quick connect, Warn x8000i on external carrier, sway bar delete, trailer plug relocated to bumper, Pelfreybilt IFS and Mid skids, ECGS front diff bushing, ARB CKMA12 compressor, 255/85/16 Backcountrry MT 3 load E tires on stock steel rims, Up2NoGood heated mirror kit, Husky X-act Contour front floor liners, Northstar AGM 24F battery, Pelfreybilt bolt on sliders with kickout and top plates, TRD Pro headlights, Depo smoked tail lights, Energy suspension body mount bushing kit, OME Dakar leaf packs with AAL, Billstein B110 rear shocks, OME 90021 front shocks with 885 coils, SPC LR UCAs, Up2NoGood 2wd low range mod, 4 Wheel Campers Grandby slide in camper
    I thought about using the light hole. I should have - the plug blocks the light anyway. 2" hole saw. wiring was plenty long, but I had to cut and solder my ground as it was rusted to the frame. I'm sure I'll have to replace the whole pigtail before long.
  4. Jul 5, 2015 at 9:07 PM
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    image.jpg image.jpg Here what I did with mine from some metal bar stock I had laying around
    Malinosan, Key-Rei, Olcrowe and 2 others like this.
  5. Jul 6, 2015 at 8:37 AM
    Sccafire
    Cleburne, Texas
    Still leaves the plug vulnerable just not as much as before.
    I don't know where you live but a fix it ticket is not worth it.
    Thanks for the information. I may do what you did but add another type of license plate light.
  6. Jul 6, 2015 at 9:19 AM
    nd4spdbh
    SoCal
    The license plate still has a light on it from the passenger side and is lit up just fine.
    DaveInDenver likes this.
  7. Jul 6, 2015 at 9:21 AM
    Sccafire
    Cleburne, Texas
    Good to know I was going to see about that tonight.
  8. Jul 6, 2015 at 9:30 AM
    nd4spdbh
    SoCal
    and worst case if you feel its too dim with the stock light a brighter LED light in the passenger side one or some license plate bolt lights for 10 bucks on ebay.
    Also i didnt like the idea of of turning the harness facing straight down its still vulnerable, way more exposed to the elements as well. Also with an adapter plugged in or a harness to a trailer the wires hang WAY down and could drag really easy.
    scocar likes this.
  9. Jul 6, 2015 at 11:48 AM
    Detective_Dan
    Colorado Springs
    not as much as you would think. it sits higher than the hitch, the spare tire, the leaf spring knuckles, pretty much everything around it. and as said before, if you're THAT concerned its going to get ripped off from wheeling, you probably shouldnt be running the OEM bumper anyways. if the bumper hits the ground, its gonna crumple like tin foil
    Malinosan likes this.
  10. Jul 6, 2015 at 3:15 PM
    black_magic2010
    black_magic2010 Well-Known Member
    South Texas
    10 Tacoma TRD Sport DBL Cab
  11. Jul 6, 2015 at 3:22 PM
    nd4spdbh
    SoCal
    because.... 1, like stated it still has the harness located down in the elements, faces the wiring straight down which makes things prone to dragging. and 2. THATS AN EXPENSIVE PIECE OF METAL! 1.50 for 2 bolts n lock nuts and you can pop it in the already made hole in the bumper.
    scocar and rockalot like this.
  12. Jul 6, 2015 at 3:57 PM
    black_magic2010
    South Texas
    Well I guess some people are tight wads, anyways no sense arguing with that. In the end you get what you pay for. Good luck
  13. Jul 6, 2015 at 4:02 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Yes. I think it was the door knob one, but it was (6) years ago so I don't remember. Real easy to do and cost nothing. I made a gasket to sit between the bumper and the 7-pin bracket. Zero maintenance mod. Works great.
    wi_taco, Olcrowe, Bobcdn and 8 others like this.
  14. Jul 6, 2015 at 4:11 PM
    nocturne
    nocturne Well-Known Member
    Erin
    San Antonio NM
    2015 TRD Off-Road
    Bone stock
    In Maryland I would not be surprised if you still got pulled over for that.
    Gunshot-6A likes this.
  15. Jul 6, 2015 at 4:18 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    ^Plenty of vehicles come with just a single license plate light, and it isn't any brighter than the single one on the Taco.
  16. Jul 6, 2015 at 4:19 PM
    nd4spdbh
    SoCal
    With how factory looking putting the trailer plug harness in the driver side light spot.... if an officer did pull you over i doubt upon further inspection he / she would ticket you, unless they knew the truck and were super dickish.
  17. Jul 6, 2015 at 4:23 PM
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    2019 Tacoma Black,Sport,Premium and Tech Package
    Sport pedals,, Magnaflow cat back exhaust system,Kuhmo 275x55x20, Platinum #220 Abyss wheels 20x9.5. Under hood lights, OEM LED cargo bed lights, extra D-rings installed in bed, AC mod, diff. breather mod, OEM LED puddle lights and footwell lights, Homelink mirror, oil catch can, raptor grille lights, replaced chrome grille molding with black molding, tailgate lock/unlock and tailgate opener, console organizer, glove compartment organizer, Caliraised stealth LED light bar, TRD Cold Air Intake, Lighted cup holders, Meso extended fuse cover, Meso stage 1 tail lights, Meso switch panel, Door bowl lights. Anytime front and rear backup camera mod. TRD Pro Rigid fog lights.Door edge guards. TRD Pro shift knob with Boomer's TRD LED light (Red for security, blue for interior), Glass Break Sensor, sensor with LED light tied into the security LED light, OEM LED Headlights, Sequential LED Turn Signals.
    I relocated mine into the bumper. I just liked the look. Why Toyota mounted it under the bumper I don't know.
    dbole007 likes this.
  18. Jul 6, 2015 at 4:32 PM
    nocturne
    Erin
    San Antonio NM
    2015 TRD Off-Road
    Bone stock
    But those, from what I have seen are over head and not the side.
  19. Jul 6, 2015 at 4:45 PM
    scocar
    scocar hypotenoper
    bigmw, DaveInDenver, BCbuggy and 3 others like this.
  20. Jul 6, 2015 at 4:49 PM
    patbegley
    patbegley Well-Known Member
    The Kootenays
    '22 DCLB
    I think I paid $60 for my bullaculla, small price to pay for a nice clean quality piece that keeps the plug protected.
