Trailer light connection issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by Fuzzy Taco, Dec 11, 2023.
  1. Dec 11, 2023 at 2:04 PM
    Fuzzy Taco
    Fuzzy Taco [OP] Well-Known Member
    02 4x4 3.4
    Hey all.
    Something weird is going on.
    Using an led plug tester.
    Without brakes applied, Trailer blinkers only work if the tail lights are OFF. Unless the brakes are applied then they blink along with the tail glow.
    The second the taillights are turned on the blinkers quit unless the brakes are on.
    The trailer wiring appears to be extra jacked up. Im only getting a left blinker unless the tail is on then i get nothing. Said left blinker does not operate only as a brake.
    I could be dealing with a bad ground In the truck?
    Something shorted in the factory trailer converter box under back seat?
    Blown fuses to said converter?
    Any thoughts appreciated
  2. Dec 11, 2023 at 2:17 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I do know the factory trailer lights box was a piece of crap.
    If your trailer plug is not corroded and bleeding voltage to another pin, you can reasonably assume the trailer light box is bad.
    I've had 2 out of my 3, 1st gen Tacomas do this.
    Bivouac likes this.
  3. Dec 11, 2023 at 3:59 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    2nd on the converter box!!
  4. Dec 11, 2023 at 4:25 PM
    Fuzzy Taco
    02 4x4 3.4
    Not entirely surprised
    Do you have any suggested alternatives besides simply replacing the box and expect to replace it again in another 20 years?
    Id rather not hack into the wiring under the bed and add an aftermarket box
    If i had a schematic to hack an aftermarket box in the location of the oem one i would be much fonder of the idea
    I may poke around and figure it out without a schematic too
    All wires and connections Look 100% ok
    Hilariously the trailer wiring is completely crapped out at the same time as the truck having issues. Found out why the right side was definitely doing nothing. Both hot wires rotted off at their crimp connections. (Definitely not related to the taco's own drama)
    Bivouac likes this.
  5. Dec 11, 2023 at 4:57 PM
    Bivouac
    Sooner or later all my vehicles get 7 pin plugs
    Even if itis just for fixing trailer lights and brakes.
    You should be able to get the light schematics from someone.
  6. Dec 11, 2023 at 5:05 PM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma SR5 4x4 DC SB V6 AT Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. OEM All-Weather floor mats (summer), Factory/TSB OEM rear leaf spring modification.
    Find and inspect all of the grounds too: especially the trailer wiring related ones, but all of the others as well. Bad, sketchy/rusty or broken grounds can cause all kinds of strange electrical problems: like brake lights on when you turn on the headlights, blinkers making taillights blink dimly, etc.
  7. Dec 12, 2023 at 9:45 AM
    Fuzzy Taco
    02 4x4 3.4
    Everything on the truck Looks great
    The ground goes all the way back to the converter box by the looks of things
  8. Dec 12, 2023 at 2:24 PM
    Fuzzy Taco
    02 4x4 3.4
    Hopefully this was not a bad idea
    I bought a "new" oem module from ebay. I was sent a warning from the seller.....
    Please be aware this is not a self-install plug and play item. At a minimum, it will require body control reset using ob2d scanner. It may require TechStream Toyota Lexus software depending on the issues your vehicle has.
    Is this guy correct?
    Why the hell would a trailer converter need to be programmed and matched to the computer?
    Is it gonna be a total nightmare?
  9. Dec 12, 2023 at 8:38 PM
    Bivouac
    I have never heard this with a truck of your age .
    Good luck
    If you bought a converter box.
    It only works for the lights any other effects will be up stream from converter box.
  10. Dec 13, 2023 at 9:06 AM
    jibarnes
    jibarnes Active Member
    James
    2002 Tacoma
    S/C TRD Headers, 7th inj. Magnaflow exh.
    Take the trailer out of the equation and check voltages at the truck wiring connection at the bumper your test light or with a DVM. I thought I fried my converter back in 2002 when the truck was new doing a little trailer wiring so my friend at Toyota got me a new one under warranty. Turned out to be a fuse below the converter so still have a new one in the box.
  11. Dec 13, 2023 at 9:21 AM
    Bivouac
    Fixing trailer lights is a on going job though Led's have made it mostly wiring and connections
  12. Dec 14, 2023 at 8:48 AM
    Fuzzy Taco
    02 4x4 3.4
    Yea the trailer wiring was its own separate nightmare that as of yesterday has been freshly rehashed and might be good for at least a minute and a half. Im about to put crinkle tube on the wires so maybe theyll last about 2 minutes.
    The truck's issues are real as confirmed by the test plug. The fuses dangling from the harness at the converter under the seat are intact
    I also cannot imagine this guy being correct about the module needing to be keyed to the computer but what do i know
  13. Dec 14, 2023 at 10:27 AM
    notrouble
    notrouble Well-Known Member
    western Washington
    2004 single cab 2wd
    The tester results really sound like a bad ground pin connection on the truck side of the trailer connector. You are borrowing the tail lights as a ground when they are not on.
    I have not had any problem in my Tacoma with the factory 4-pin trailer wiring harness adapter but I don't tow all that often. I bought the wiring adapter and the receiver from my dealer and installed it myself back in 2004. I did not have to do any sort of reset procedure. I disconnected the battery while installing the factory trailer wiring and reconnected the battery when done, and everything has worked fine since. (2004 Tacoma, base model 5-lug)
  14. Dec 14, 2023 at 1:17 PM
    Fuzzy Taco
    02 4x4 3.4
    Bad ground... this has obviously crossed my mind but i know not where to start looking. Weird crap happens with a bad ground.
    I wish in a way that said ground was out there and visible (yeah right it would be rotted off) lol. Guess ill have to poke around
    Id expect the converter box to eliminate the ground loop through the tail lights but i guess weirder things could happen
  15. Dec 14, 2023 at 1:45 PM
    Fuzzy Taco
    02 4x4 3.4
    Hokay
    Its not a ground issue. I just made up an extension with an auxiliary ground wire grafted in that i hooked directly to the battery. No difference. Flashers work alone
    Tail only if its on
    Unless the brakes are on. Then everything acts normal
    Seems like the blinker-power circuit is confused.
    The blinker-brake interrupt circuit is still solid
    It seems like the converter has to be at fault. New one will be here soon.
    Bivouac likes this.
  16. Dec 14, 2023 at 1:59 PM
    Fuzzy Taco
    02 4x4 3.4
    Im just confused and becoming pissed off lol.
    I just fully rewired the trailer. Soldered joints. Know i hooked em up right. Tested the lights before i put it together. I know they do things.
    Well all i get is a left blinker. Nothing else does jack. Not even matching the test plug.... i have the ground jumper to the battery to no avail... uy
  17. Dec 14, 2023 at 2:23 PM
    Bivouac
    After 40 years I learned to go with the flow.
    At any time did it ever work correct ?
    Clean the sockets check the bulbs with a meter ..
    This is why I convert every trailer to separate turn signals like the Toyota Tow vehicles.
  18. Dec 14, 2023 at 3:02 PM
    Fuzzy Taco
    02 4x4 3.4
    Becoming has became.
    This is a living nightmare
    Of course it already has the squirrel shield installed. Was a bitch in a boat to put on.
    They are led. I wont use anything else anymore.
    Separate turn signals on the trailer.
    Ok cute.
    Are you misusing a 7 pin plug?
    Even those intend for the lights to be combined
    The left blinker. Only. Ever.
    Only from the truck.
    Trying to do some diagnostic with a known good battery. Testing at 12.65v. Sparks gleefully when i bang the jumpers together.
    I tried touching the plug. Nothing
    Tried cutting into the wires in doubt of the plug. Nothing. Multimeter says the plug is fine. Hang the jumpers on the cut-into trailer wires. Nothing. Yet the left blinker was blinking merrily from the truck.
    All lights tested good before i rewired it
    The wires are double twisted and soldered. Nice solid joints. No cold solder. No crimps. No twist and forget
    Ground wires directly to the lights... no shitty rusty ground through the shitty rusty frame. I know for a damn fact i hooked em up where they need to go
    At this point im just ranting
    This is a tacoma forum not Your Grandpa's shitty boat trailer that has been turned into an extra-shitty utility trailer forum...
    Im glad i didnt wait until the last minute when im headed from kentucky to arizona in march for my wedding and to drag back my old deathtrap of a motorcycle
    Uy. The shit saga continues.
    I may have to get new lights?
    Despite seemingly being OK?
    UY
  19. Dec 14, 2023 at 3:50 PM
    1blink
    1blink Well-Known Member
    Storm Mtn, CO
    2000 3.4 manual SR5
    Sounds like you're working on a new problem, trailer wiring now. If you have the truck side of things fixed, that's progress!
  20. Dec 15, 2023 at 1:31 AM
    Zink_91
    Zink_91 Well-Known Member
    Kevin
    Mississippi
    2004 Double Cab PreRunner V6 TRD
