Trailer hitches
Discussion in '1st Gen. Tacomas (1995-2004)' started by SEAMONSTER401, Jan 3, 2017.
  1. Jan 3, 2017 at 1:35 PM
    SEAMONSTER401
    SEAMONSTER401 [OP] Well-Known Member
    Zach
    Mocksville, NC
    04 Tacoma 4x4 Ext Cab
    Hey guys I'm wanting to buy a trailer hitch for my 04 Tacoma and been looking around because my bumper is about a 6-8 inches too high for any towing. What are you guys' suggestions. Would like something that's a little bit hidden but it doesn't have to be.
  2. Jan 3, 2017 at 1:56 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    most hitches will be mostly hidden but the receiver will be below the bumper. check your local Craigslist or the Buy/Sell/Trade forums here first.
    most hitches new are around $125 on Amazon or other retailers (U-Haul is too expensive)
    brands most common are: Curt, Reese, Draw-Tite, etc.
  3. Jan 3, 2017 at 2:48 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Do you mean the hitch receiver or the hitch itself (with the ball)?
    Hitch receivers mount to the frame with the same 4 bolts as the rear bumper, super easy to install. I have a Hidden Hitch, but you can pick one up at a U-haul (though usually expensive) or any other truck parts supplier (4Wheelparts, etc...).
    As for the height of your hitch, just get a drop hitch. You can get expensive adjustable ones, or cheaper fixed height ones. All you do is get your truck and your trailer on a flat surface. Measure the height of both the hitch receiver on the truck, and the trailer hitch (when trailer is flat and level). the difference is the height of your drop hitch.
  4. Jan 3, 2017 at 2:54 PM
    SEAMONSTER401
    Zach
    Mocksville, NC
    I know I'll need a drop hitch, but I was looking for what brands or styles of receivers people commonly use and what's best.
  5. Jan 3, 2017 at 4:28 PM
    rodehard
    rodehard Active Member
    BKP
    2001 Tacoma Base
    K&N Intake. Gutted Cats. Slightly larger tires.
    I towed about 6k with my curt class 3. Did just fine. Got mine off of Amazon.
  6. Jan 4, 2017 at 12:10 PM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    I just installed a Curt hitch on my 2003 Tacoma. After installation I noticed a rattle. It was my exhaust pipe rubbing on the hitch. With engine off clearance was 1/4 inch or better. I shaved a little off the hitch with a dremel and fixed it.
    Here are some suppliers near you. I used etrailer.com Less than $200 I think. Installed it myself.
    http://trailer-hitches.regionaldirectory.us/north-carolina.htm
  7. Jan 4, 2017 at 2:56 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    You can sometimes find used ones quite cheap.
    Try and stay away from those Universal Hitches they can be a pain
    I have been building mine for years but any of the major brands were decent if they are made in China now All bets are off.
    Since the Receiver Hitch bolts in the same holes as the bumper you might want to have new hardware just in case.
    You really don`t want to be drilling new holes
  8. Jan 4, 2017 at 5:00 PM
    jbrandt
    Justin
    This is what I have (I got mine from a local shop, though):
    https://www.amazon.com/Hidden-Hitch...automotive&vehicleId=1&vehicleType=automotive
    As to "what's best" that's very subjective. They are all class III, black welded pieces of steel that bolt on to the frame. Very little actual differences between them. They all run usually between $150 and $180ish. As has been said, the U-haul receivers are usually pretty expensive for what you get (i.e. the same thing as a $150 receiver!)
  9. Jan 4, 2017 at 8:59 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    A lot of 04 Tacoma's came with them installed from factory or dealer. Might call a few junkyards. I picked mine up from dealer.
  10. Jan 5, 2017 at 4:37 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    I have a Hidden Hitch on my truck. It sits recessed behind the bumper. If you plan to use anything besides the ball, you may have interference issues and need to use an extension in order to get the pin through the hitch and item to secure it.
    Otherwise, it's nice to have it a little hidden behind the bumper as it gives a TINY bit more departure angle for dropping off curbs at the mall.
  11. Jan 5, 2017 at 5:42 PM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    I have a curt and does just as good as any other brand out there
  12. Jan 5, 2017 at 5:43 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    I got the stock one from an 09.
  13. Jan 5, 2017 at 5:49 PM
    bmidd
    bmidd Member
    Brian
    Chattanooga,TN
    2001 Tacoma Pre Runner
    and it bolted up on a Gen 1?
  14. Jan 5, 2017 at 5:53 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    never mind
  15. Jan 5, 2017 at 6:46 PM
    blind cowboy
    blind cowboy Well-Known Member
    Don
    Auburn CA
    2002 TRD XC 5sp
    I went with the factory Toyota hitch which is rated as class IV. Fit is perfect and cost about $145 online. Had to buy a wiring harness separately. Oh yeah the part # is PT22804030.
    mechanicjon likes this.
  16. Jan 5, 2017 at 7:12 PM
    jbrandt
    Justin
    Yeah, and they called that a "tow package".. :mad:
    mechanicjon[QUOTED] likes this.
  17. Jan 5, 2017 at 8:28 PM
    Indy
    Indy Master of all I survey.
    There's really not enough of a difference in most of them to matter. Youre not hauling 100 tons back there. Find a good deal and done.
  18. Jan 5, 2017 at 8:28 PM
    SEAMONSTER401
    Zach
    Mocksville, NC
    Alright. Thanks for the advice.
  19. Jan 6, 2017 at 5:53 AM
    MartinDWhite
    MartinDWhite Well-Known Member
    Martin
    Greenville, SC
    2004 4-dr 4x4 Tacoma TRD
    Relentless front and rear bumpers, Warn M-8000S Winch, Relentless RockSliders, bigger tires, bed cover RTT ... and more big changes in the works.
    I have a factory rear and custom made front hitch for sale in Greenville SC for a first gen tacoma.
  20. Jan 6, 2017 at 6:47 AM
    rodehard
    BKP
    2001 Tacoma Base
    My curt came with new hardware.
