Trailer hitch wiring
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nacho Libre, Jul 1, 2023.
  1. Jul 1, 2023 at 6:24 PM
    Nacho Libre
    Nacho Libre [OP] Well-Known Member
    2022 Magnetic Grey Tacoma
    Nerf bars and LED headlight bulbs
    So I want to add a trailer hitch to my 2022 Tacoma SR but don’t want to do the tail light connection I keep seeing on videos. I looked underneath where the false connection cover is and saw a pig tail connection where the taillight wiring/connection is and was wondering if that’s for the hitch wiring connection. Can anyone help me out?
  2. Jul 1, 2023 at 6:27 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    No, trailer hitch wiring is hard-wired right into the truck harness and if the truck doesn’t have a hitch, it doesn’t get that wiring. What you are referring to is probably the unused blind spot monitor hookup, all trucks get that even if they don’t have BSM.
    LeakyAC likes this.
  3. Jul 1, 2023 at 9:56 PM
    Nacho Libre
    But it looks like it’s tied in or coming from the rear light wiring harness. Can’t imagine it’s a sensor pigtail.
  4. Jul 1, 2023 at 9:57 PM
    Nacho Libre
    I’ll take a pic and post tomorrow
  5. Jul 1, 2023 at 10:59 PM
    BLtheP
    Plano, TX
    All trucks have a pigtail that mounts to a little bracket back there for BSM and sonar. If equipped, the BSM and sonar sensors have a harness in the bumper that will plug into that pigtail. Right next to the BSM pigtail that may or may not be used, is a rear lighting pigtail. That one is always used, obviously.
    The tow harness is not like the other two. Trucks have different harnesses from the cab to the rear depending on if they’re a tow package truck or not. Non-tow package trucks don’t have any wiring provisions for towing. On a truck that does have the tow package, there is no pigtail along the way. The wiring from the cab goes all the way back there and terminates to a plug that actually plugs into the back of the 7/4 tow connector itself. If the truck isn’t equipped for towing, then none of the wiring that goes to that plug for the 7/4 is there at all.
    LeakyAC likes this.
  6. Jul 3, 2023 at 9:03 AM
    Nacho Libre
    Thank you for the information. Any thoughts on the best way to wire up for trailer wiring?
  7. Jul 3, 2023 at 9:10 AM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    It's not related to trailer lights or the 7/4 housing
  8. Jul 3, 2023 at 9:29 AM
    LeakyAC
    Only have 2 choices: one of the aftermarket harnesses (most are just the 4pin and won't use the oem 7/4 housing in the back bumper, so you'll have it dangling there in the back, which looks like ass) or trying your luck with building your own 7pin round end connector and making it work with the driver's door sill plug-in, which your truck may or may not have. Which is 50% more work for a result that may not work.
  9. Jul 3, 2023 at 6:28 PM
    Nacho Libre
    Thanks for the info
