Trailer Hitch Plate Weld on Nut Size
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ken08Taco, Mar 2, 2023.
  1. Mar 2, 2023 at 12:52 PM
    Ken08Taco
    Ken08Taco [OP] Well-Known Member
    Ken
    Pittsburgh, Pa.
    2008 Tacoma TRD Sport
    Anyone know the size of these weld on nuts located on the rear frame rails for mounting the reinforcement plates for the hitch? Thread size and pitch? I have a 2008 Tacoma.
  2. Mar 2, 2023 at 1:11 PM
    AustinWest
    AustinWest The Amazon Special
    South Carolina
    2006 Tacoma - DCSB - 4WD - Manual
    I may be wrong but I don't believe that Toyota welded those nuts on there, that looks like a pretty sloppy weld for OEM. Now that being said, they do look similar (if I remember correctly) to the actual nuts that thread onto the bolts holding the hitch plate in place... I would start by calling your local Toyota dealer and getting a part number for that nut (if they are the same ones) and do a little digging around to find the thread pitch using that part number. You can always ask the dealer for a "hitch diagram" or "bumper diagram" that "shows all the hardware required for complete replacement."
  3. Mar 2, 2023 at 1:21 PM
    Ken08Taco
    Ken
    Pittsburgh, Pa.
    These are what are there from the factory. I'm disassembling the rear end so I can get the frame rails in the back replaced due to an accident. I noticed these there after removing the hitch plates.
    Anyone think I can get away without having these welding on to the frame? When I reinstall the hitch, can I just use locking washer on there? Is there enough hand room to get in there to hold the nuts in place when tightening? I'm guessing no as this is probably why they are welded.
  4. Mar 2, 2023 at 1:50 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  5. Mar 2, 2023 at 5:04 PM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    Toyota welds them on to make it easy on the assembly line for the assemblers. Toyota also pins the mounting brackets so there's no alignment issue. Just assemble it and go on to the next one. It makes for a very precise assembly with no guesswork for the assembly line. There should be enough room for tool access.
    When I replaced my bumper with an aftermarket one, I couldn't use the OEM mounting angle brackets so it took a little finessing to get the bumper and box fit pleasing to the eye.
  6. Mar 2, 2023 at 5:13 PM
    wgb89
    wgb89 Well-Known Member
    North Carolina
    05 Prerunner SR5 DCLB
    Bilstien 5100s Added Leaf 17x9 Wheels 285 BF Goodrich KO Aftermarket 2 sets of Boston Component Speakers Sony Head unit 2 2way pioneer amplifiers to power component speakers Reese Hitch Tinted windows
    Bump
  7. Mar 2, 2023 at 5:23 PM
    Sysco
    Sysco Well-Known Member
    Jim
    Fort Worth
    2013 Tacoma Base
    When I added my hitch, I ran a tap thread cleaning through the nut, and it was definitely 12mm x 1.25, same as TnShooter said above.
    TnShooter likes this.
  8. Mar 2, 2023 at 6:00 PM
    TnShooter
    Deogee
    STOCK
  9. Mar 3, 2023 at 11:06 AM
    Ken08Taco
    Ken
    Pittsburgh, Pa.
    Thanks, fellas! Anyone know what the part number for those nuts are so I can order new ones for the install? I was at the dealer today but the parts diagram did not show a part number. I'd like to get automotive strength nuts instead of something cheap at Lowe's or HD!
  10. Mar 3, 2023 at 11:43 AM
    TnShooter
    Deogee
    STOCK
    You aren’t going to find the weld on nuts.
    They are part of the frame. I’ll have to see what the torque spec is for those bolts and match it to the grade nut/bolt.
    I guess I could crawl back under mine and look a the head of the bolt and see what grade it is? But it’s raining now.
    I will see what I can find.
  11. Mar 3, 2023 at 12:23 PM
    TnShooter
    Deogee
    STOCK
