Trailer hitch motorcycle carrier
Discussion in 'Towing' started by AKTacoParty, Jul 19, 2018.
  1. Jul 19, 2018 at 9:27 PM
    AKTacoParty
    AKTacoParty [OP] Well-Known Member
    Jake
    Astoria, OR
    2013 DCLB
    885s, Dakars, Bilsteins, Allpro Sliders, Archive Garage Hammer Hangers, Wheelers Ubolt flip, super bumps, RCI front skid
    I am looking for some reviews on anyone who has purchased a hitch mounted motorcycle
    carrier. I have a 1980 harley sportster that weights 530lbs. I am looking for a steel one that is well made. I have looked at a handful on Amazon but they all seem to be cheap foreign made ones. Any help would be appreciated. Thank you
  2. Jul 23, 2018 at 5:55 PM
    AKTacoParty
    Jake
    Astoria, OR
    2013 DCLB
    Bump, anyone have experience with these type of carriers?
  3. Jul 24, 2018 at 4:20 PM
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    Your truck is rated for what tongue weight at 8-12” to where a tongue ball would be? Now move that weight out another 12” or more and you double the leverage and half the capacity of your rated tongue weight. Guarantee it exceeds the rating by a substantial amount. I know lots of people who have done this and it is unsafe.
  4. Jul 24, 2018 at 6:43 PM
    Ranger Dave
    Ranger Dave Well-Known Member
    Cross FLOT
    2015 White TRD Off Road 4X4
    Fold a cover, Spacers, Scan Guage II, Weather Tech Vents, All weather floot mats, mod sideview towing mirrors, tow package, mod differential. LED back up lights, Flyzeye console/glove compartment lights, heavy duty farm seat covers, TSC bed mat.
    Save your truck, save your bike, get a trailer!
    Herniator likes this.
  5. Jul 24, 2018 at 6:46 PM
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    Trailer is always the best... but not most practical. I’ve used and still use a double mx carrier of a factory hitch. Both bikes weigh in at 300lb. So 600lb + leverage. I’d defiantly suggest airbags or sumosprings if your gonna do it.
  6. Jul 24, 2018 at 6:50 PM
    Pickeledpigsfeet
    Pickeledpigsfeet Well-Known Member
    Foothills, CA
    I have a well built all steel welded one. I carry a dirtbike on it. I would not run a bike as heavy as yours on it with modifying it. I would want 3 points of contact with the truck. You can weld 2x2 sq tube on both ends of the carrier and then matching receiver hitches to your truck usually on a custom subframe. This is how the truck/suv guys blasting thru baja carry their dirtbikes. No rocking and weight distributed.
  7. Jul 26, 2018 at 5:29 PM
    AKTacoParty
    Jake
    Astoria, OR
    2013 DCLB
    Decided on this one. If it needs anything added to it I can weld to it. I probably should have made my own but didn't think about these until about a week ago and I'm leaving for sturgis 03Aug so time is up. Do you think the dakars will handle it?
  8. Oct 17, 2018 at 4:11 PM
    TheSaltyDoc
    TheSaltyDoc Member
    Colton
    I'm also looking to get a trailer hitch carrier for my Sportster, and I've got HD Dakars on my taco too. How did the Dakars work for you, and did you have any other issues with the haul?
  9. Oct 17, 2018 at 8:09 PM
    AKTacoParty
    Jake
    Astoria, OR
    2013 DCLB
    I ended up changing plans last minute and renting a uhaul trailer. I didnt like how wobbly the carrier was after I test loaded my bike, it was also on the upper end of what the carrier could hold. What year is your sporty?
  10. Oct 17, 2018 at 8:54 PM
    TheSaltyDoc
    TheSaltyDoc Member
    Colton
    @AKTacoParty mines a 2018. I'm hoping I can find a more reliable hitch carrier because I don't have anywhere I can store my Leer shell.
  11. Oct 17, 2018 at 11:10 PM
    AKTacoParty
    Jake
    Astoria, OR
    2013 DCLB
    Good luck because the most weight allowed that i have found was 600 lbs, which is what the one above is, but it doesnt give piece of mind.
  12. Oct 18, 2018 at 4:17 PM
    Indy
    Indy Master of all I survey.
    Rent a trailer for $50. Buy a trailer for 400.
    Standard class 3/4 is rated for 600 lbs tongue. That's at the hitch. You're planning on putting 600 plus at least 2 feet out. The welds at the hitch are likely rated based on the amount of torque they can carry. By putting 600lbs 2 feet out, you're applying 1200 ftlbs of torque.
    Assuming the hitch had a 100% safety buffer, you're exactly at it, until you hit a bump. WILL it work? Probably. But do you want full risk of damaging the bike and or everyone behind you on a probably?
    Get a trailer.
  13. Oct 18, 2018 at 9:49 PM
    AKTacoParty
    Jake
    Astoria, OR
    2013 DCLB
    I would recommend a trailer for anything other than a dirtbike. I used to have a trailer until it was stolen...
  14. Nov 7, 2018 at 5:11 PM
    flyby
    flyby Well-Known Member
    Ohio
    14 DCSB 4x4
    Glad you decided against it. I have a similar carrier and I carried a sportbike on it which was probably 400lbs. Even though I had no issues, it made me nervous the entire 2 hour trip. I would not consider putting a Harley on it. If you're that tight on space and don't want to bother renting every time, there are some folding options.
    https://www.stingertrailer.com/product/trailer-in-a-bag/
  15. Nov 7, 2018 at 5:14 PM
    AKTacoParty
    Jake
    Astoria, OR
    2013 DCLB
    Thats kind of neat. I think im gonna get another enclosed trailer if i do get one again. That way i can move my things when i move.
