Trailer Hitch Installation
Discussion in '3rd Gen. Tacomas (2016-2023)' started by txhayden09, Jul 1, 2019.
  1. Jul 1, 2019 at 9:49 AM
    txhayden09
    txhayden09 [OP] TX -> WA -> GA
    Atlanta
    2018 Grey Tacoma SR5
    Black Step Rails
    Hey there!
    I have decide to move from GA to TX and I am looking to pull a small U Haul trailer. I know my towing weight is 3,500 lbs and I don't plan on maxing that out. Since I have a 4 cylinder SR5, I need to get a hitch installed. Would U Haul be a bad option for hitch installation? They are recommending a CURT hitch. $400.99 for hitch, ball, wiring and installation. A local shop quoted $494.99 for the same setup.
    Any guidance appreciated!
    TT005 likes this.
  2. Jul 1, 2019 at 10:01 AM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    Did U hauls price include wiring? Did the local shop include wiring? I would almost pay the extra 100 dollars for the local shop to do it, because I have seen some of the work from U haul. I had one customer come get his boat and he came directly from U haul. He had to get a 7 pin connector because he only had a 4 pin. They didnt even test their work and sent him on his way. He got to our shop and his lights didn't work. As a first step, we always check the trailer lights with our test cart, the trailer was fine. I got to looking and the guy didn't even connect the ground wire to the 7 pin. I got him fixed up. Just sharing one of the instances I have seen from U haul.
    scocar likes this.
  3. Jul 1, 2019 at 10:05 AM
    txhayden09
    Atlanta
    Black Step Rails
    It did include the wiring. And yes I am concerned about well anyone touching the wiring. What would you recommend is the price point to aim for?
  4. Jul 1, 2019 at 10:08 AM
    Itchyfeet
    Itchyfeet Well-Known Member
    The wiring should be plug and play provided they use the right kit.
    daddy_o likes this.
  5. Jul 1, 2019 at 10:17 AM
    txhayden09
    Atlanta
    Black Step Rails
    One place said they had to run a line to the battery, is this necessary? This is a small 5'X8' box trailer from Uhaul that I am wanting to pull.
  6. Jul 1, 2019 at 10:17 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    How comfortable are you doing work on your own rig? Seems like buying the wiring kit on eTrailer and a hitch, you could prolly get it all done for around $250. Looks like a pretty simple install.
    daddy_o likes this.
  7. Jul 1, 2019 at 10:47 AM
    daddy_o
    Bossier City, La
    No, they should be able to tee/tap off of wiring already at the back of the truck. As others have said, the wiring kit seems pretty straight forward.
    Edit to say: It looks like there may be a wire needed from the battery for those kits.
  8. Jul 1, 2019 at 10:49 AM
    Itchyfeet
    If they're using t-taps they're doing something wrong. t-taps are the anal warts of any wiring job
  9. Jul 1, 2019 at 10:53 AM
    daddy_o
    Bossier City, La
    I didnt mean T taps, I meant tee off of as in unplug a connector and plug a tee harness(plug and play) or tap off of such as splicing into existing wire. Either way, no need to run a wire to the battery. Yes, I agree, I do not like t-taps at all, especially on wiring that will be subjected to the elements.
    whatstcp likes this.
  10. Jul 1, 2019 at 11:02 AM
    YF_Ryan
    Kent, WA
    I was looking at a couple kits online, and they do include a fused wire to run all the way to the battery, even though all the other connections are plugs and play with the Toyota connectors. I'm betting there isn't an always on hot wire back there near the taillights. But one wire run the length of the truck to the battery? shouldn't take more than 5 minutes with a handful of zip ties.
  11. Jul 1, 2019 at 11:25 AM
    daddy_o
    Bossier City, La
    Yeah I just saw that even on the one posted above. I guess it's for that converter they are talking about. Still, shouldn't be a big issue.
    YF_Ryan[QUOTED] likes this.
  12. Jul 1, 2019 at 11:51 AM
    TT005
    TT005 Well-Known Member
    NC
    2023 SR5 DCSB 4X4
    I appreciate your post. I tossed around the UHaul option, but I haven’t made a decision yet. The factory hitch setup is expensive, to say the least. Toyota could have made the wiring much easier. On a previous Chevy S-10 I owned, it was a simple plug ‘n play connection to the taillight harness. No fuses, ground wiring, or wiring to the battery was needed.
    daddy_o likes this.
  13. Jul 1, 2019 at 12:00 PM
    daddy_o
    Bossier City, La
    Yes, the good days of simplicity. Thats the system I am used to working with. These light converters in the kits have peaked my interest.
    TT005[QUOTED] likes this.
  14. Jul 1, 2019 at 1:39 PM
    chaotic_taco
    chaotic_taco Well-Known Member
    ATX
    2017 DCSB TRD OR MT
    The "wire to the battery" youse are talking about is in the case of a 7 pin connector. The basic four connections are ground, running lights, left turn, right turn (brake lights are both turns at the same time). The additional 3 to make a 7 pin connector are brake controller, 12v power, and reverse. 12v power must come from the battery.
    Depending on your future towing needs, you may only need a 4 pin. You can get connectors that have both a 4 pin and 7 pin, like the stock one, or an adapter to go from 7 to 4 pin.
  15. Jul 1, 2019 at 1:43 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I once got a written quote from U-Haul and promptly went to a more reputable place. They "almost" matched the price, but did laugh at the parts list U-Haul was using.
  16. Jul 1, 2019 at 2:00 PM
    Early Man
    Early Man Well-Known Member
    Sand 2016 Sr 5
    I read over the specs for the wiring, and can not determine if it is induced current that runs the trailer side . It's a wiser idea to make sure the wiring and adapter are Induced Current Type. In this way your trucks charging system and lights do not power the trailers lights. There are 2 separate things. The converter creates the power to the trailer and lights the lights you tell it to when you do leaving the charging system out. In this way if the trailer ever has a dead short it won't take out the trucks charging system . The converter also transforms the European 2 separate trail lights functions brake / turn signal into the USA standard of a singe bulb with a shared filament for brake turn .
    Here is one not made specific to anything, but it is induced and something you can use to compare to , the Hoppy model #46255 powered converter gets full power to the trailer lights and protects trucks electrics at the same time.
    Sooner or later it seems someone will want you to tow a trailer that isn't yours, and they can cause havoc in the charging system. This type of converter will save your truck .
  17. Jul 1, 2019 at 5:19 PM
    TPMO
    TPMO Well-Known Member
    2017 Tacoma SR Utility 4x4 MT
    I recently installed the curt trailer hitch and curt wiring harness. Fairly straight forward process. Cost me about$240. You will need to run the provided wire to the battery and zip tie along the factory harness under the truck. Also removing the tail lights to connect the harness and control box. The curt harness only includes the flat 4 pin connection.
  18. Jul 1, 2019 at 5:25 PM
    Nick13
    Nick13 Well-Known Member
    Dominic
    2017 sr
    Did the same myself. works just fine. Amazon is your friend. Think I had 200 bucks in it. Also can get a hoppy brand plug just like factory for the bumper
    TPMO[QUOTED] likes this.
