Trailer Harnes Extension
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kuee, Dec 27, 2017.
  1. Dec 27, 2017 at 4:45 PM
    kuee
    kuee [OP] Member
    Carsten
    2017 Dessert DC TRD Off-Road
    So I installed my Expedition One Rear Bumper the other day.
    The trailer plug in the OEM bumper fits right in the EXP One Bumper nicely.
    However it is located further away than stock the the wires won’t reach
    Is there any sort of extension one can buy?
    Or do I need to extend the wires myself.
    PvilleJohn likes this.
  2. Dec 27, 2017 at 4:54 PM
    Killowatt
    Killowatt Well-Known Member
    Citrus County Florida
    2013 4x4 TRD OFF ROAD
    Use google, I'd bet there's an extension available somewhere. I relocated my trailer harness, found a plug for it with 1 foot wire extensions with a 4 prong plug on the end.
    Good place to start.
    https://www.etrailer.com/
    If it's only a few inches, I'd solder in extensions and use shrink tubing that has the glue inside, making it water tight. Time consuming, but it will never fail if done right.
  3. Dec 27, 2017 at 5:18 PM
    kuee
    kuee [OP] Member
    Carsten
    The plug looks custom. Similar 7 pin layout but not quite the same notches.
    I just thought someone has run into this issue before.
    Whats "google"???
  4. Dec 27, 2017 at 5:44 PM
    Jeff1795
    Jeff1795 Well-Known Member
    Panama City FL
    LT 2017 TRD Sport 4x4 Access Cab 6-Speed
    Pull some plastic harness retainers out and stretch it’ll reach. I thought it could never reach my bumper and after doing that it now fits perfectly.
  5. Dec 27, 2017 at 5:50 PM
    Killowatt
    Very well someone has, and will chime in. If not, I still say add a splice in the middle somewhere to get a custom fit, solder and heat shrink tube it, good to go for years.
  6. Dec 27, 2017 at 5:52 PM
    Killowatt
    Good idea, I haven't spent much time under mine yet, sounds like the way to go.
  7. Dec 27, 2017 at 6:49 PM
    Jeff1795
    Panama City FL
    Yea it’ll give you at least a few inches. Plus with as finicky as these trucks electrical systems are I’ll stretch like a mother f@#!er over cutting and extending anything!
    Killowatt[QUOTED] likes this.
  8. Dec 27, 2017 at 8:12 PM
    jkm25
    jkm25 Well-Known Member
    2016 QS DCSB OR MT
    Hmm I'll have to try that too. Installed the SOS Concepts bumper and its like 3 inches short. Was dreading splicing in a whole mess of new wires. Thanks for the idea. Were you able to replace the harness retainers after moving them down the wires or how did you reattach the wires?
  9. Dec 27, 2017 at 8:20 PM
    Jeff1795
    Panama City FL
    I replaced the retainers with zip ties and even that was overkill. There was no reason to, it’s not like it’s going anywhere. Not sure what you mean by “reattach wires”. All I’m referring too is this plastic clips that hold the harness to the frame.
    jkm25[QUOTED] likes this.
  10. Dec 28, 2017 at 8:51 AM
    kuee
    kuee [OP] Member
    Carsten
    So you disconnected the harness as it runs down the frame towards the front of the truck to get those few inches? I’ll give that a shot.
    Thanks.
  11. Dec 28, 2017 at 9:14 AM
    Jeff1795
    Panama City FL
    Correct
  12. Dec 28, 2017 at 9:17 AM
    PvilleJohn
    PvilleJohn SVT Raptor
    Powdersville SC
    SVT Raptor
    I have the same issue now that I installed my SOS Concepts High Clearance bumper
  13. Jul 28, 2019 at 6:13 AM
    Pwhis
    Pwhis Well-Known Member
    Centerville, IA
    2018 DCSB TRDOR
    How far forward did you have to go to get the length you needed? I pulled them out of their hold downs to the gas tank and didn’t really gain much. Still need another inch or 2.
  14. Jul 28, 2019 at 9:21 AM
    caribe makaira
    Caribbean, Puerto Rico
