Trailer floor sealant?
Discussion in 'Off-Topic Discussion' started by Babybluetaco, Jun 28, 2020.
  1. Jun 28, 2020 at 9:14 AM
    Babybluetaco
    Babybluetaco [OP] Well-Known Member
    Austin
    Monroe, North Carolina
    09 5 lug
    Recently purchased a new 6.5x10 and would like to stain the deck. Not sure what product to use or if regular ol wood deck stain and sealant would hold up to the use a trailer will get. Any ideas guys? Any textured finishes out there somebody has used with good results?
    wilcam47 likes this.
  2. Jun 28, 2020 at 9:15 AM
    Babybluetaco
    Austin
    09 5 lug
    New trailer. Just got it yesterday. Trying to finish the deck before I use it for anything
    cubie and wilcam47 like this.
  3. Jun 28, 2020 at 9:18 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    If you want the most perfect deck, consider using composite lumber. Never needs stained or sealed or dries out and shrinks.
    You will never be happy with a trailer deck that lives outside its whole life. You can only put off the eventual deck replacement.
    wilcam47 and Drainbung like this.
  4. Jun 28, 2020 at 9:20 AM
    Babybluetaco
    Austin
    09 5 lug
    Yeah I realize it won’t last for ever. Just trying to make it look nice. Paid good money for a nice quality trailer and want it to stay that way. It sits under a carport so it’s not directly exposed to rain.
  5. Jun 28, 2020 at 9:25 AM
    Toyko Joe
    Toyko Joe Here for the pictures
    It appears to be pressure treated already. I'd say wait a few more months then apply any deck stain like Penofin (my preferred stain) or similar. Make sure when you do to spray the underneath too. IMHO
  6. Jun 28, 2020 at 9:27 AM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    I used Behr DeckOver on my trailer. Has held up well to firewood being thrown/stacked, tractor equipment being drug over it, oil spills, pressure washing, shovelling gravel, all sorts of stuff. Only spots where it has pulled up is where chunks of the wood have been gouged out.
    maxtherat likes this.
  7. Jun 28, 2020 at 9:27 AM
    koditten
    Kirk
    Central Michigan
    Thompson's water seal is good, but you should just use the store brand and get 5 gallons. Use a cheap, 1 gallon garden sprayer to coat it once a year.
    As for adding traction, my opinion is it hides the imperfections and knots in the wood. The wood used is never the highest quality. I want to know where the weak spots are on the deck. I've stepped thru a couple rotted decks over the years.
    Babybluetaco[OP] likes this.
  8. Jun 28, 2020 at 9:29 AM
    koditten
    Kirk
    Central Michigan
    Judging by the gaps in the lumber, I'd say you are fine to apply a sealent. It's plenty dried out and will soak up the coating fast.
  9. Jun 28, 2020 at 9:32 AM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    I was thinking this product as well. No personal experience with it but I remember the commercials and seems ideal. When I did my trailer I used rustoleum enamel paint out of a quart can. Has held up well
  10. Jun 28, 2020 at 9:34 AM
    pdaddy
    pdaddy WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
    koditten likes this.
  11. Jun 28, 2020 at 9:46 AM
    Babybluetaco
    Austin
    09 5 lug
    Wow thanks for all the reply's. Wasn’t expecting to get so many. I was thinking Thompson’s water seal+stain. 2-3 coats on the top and bottom and should be good. If it last 5 years I’d be happy.
  12. Jun 28, 2020 at 9:55 AM
    maxtherat
    Inland Northwest
    That’s what we are here for... our $.02 opinions.
    Toyko Joe likes this.
  13. Jun 28, 2020 at 9:57 AM
    Babybluetaco
    Austin
    09 5 lug
    Didn’t mean to quote you the first time but thanks for the reply’s. I’m gonna go tmo and pick out something and try and get it stained tmo, and install my flush mount tie downs in the floor
  14. Jun 29, 2020 at 1:02 PM
    Babybluetaco
    Austin
    09 5 lug
    Ended up using Thompson water seal. And installed a harbor freight tongue box for my straps. Bolted in my tie downs. Pops said trailer is nice to use now :D
    ColoradoTJ and windsor like this.
  15. Jun 29, 2020 at 1:23 PM
    koditten
    Kirk
    Central Michigan
    That turned out nice!
    Now treat yourself to some Gorilla Lifts. 2 fingers to lift and lower the gate. No risk of blowing a grape!
  16. Jun 29, 2020 at 2:18 PM
    Babybluetaco
    Austin
    09 5 lug
    Ah come on now I’m only 25 my grapes are still solid
  17. Jun 29, 2020 at 2:22 PM
    koditten
    Kirk
    Central Michigan
    What about the old man?
  18. Jun 29, 2020 at 2:26 PM
    Babybluetaco
    Austin
    09 5 lug
    The old me or my pops?
    Pops has plenty of trailers won’t need mine haha
    koditten[QUOTED] likes this.
  19. Jun 29, 2020 at 5:35 PM
    Babybluetaco
    Austin
    09 5 lug
    Buddy came by and built me a spare tire mount. No completed pics of the studs welded through the plate but you get the idea.
    ColoradoTJ likes this.
  20. Jun 29, 2020 at 5:42 PM
    koditten
    Kirk
    Central Michigan
    1/2" plate? I usually use 10 gauge. That's not going anywhere!
