Traction control light stuck on...?
Discussion in 'Technical Chat' started by Spencer, Jun 22, 2014.
  1. Jun 22, 2014 at 9:46 PM
    Spencer
    Spencer [OP] Future President
    TIGGLEBITTIES
    Upland, Chino... all of 909.
    2013 DCSB 4X4 6cyl Sex Machine
    Redline hood lift, Flyzeye cabin lights, tailgate lock, SPOD Power block, VIAR onboard air, Cobra CB radio, Firestick 4' Antenna, Hot Blonde CoPilot Mod, SIX 9" Hella 4000 HID conversion with external 55W ballasts, Six 6" LED bars, Napier Bed Tent, Mudflaps delete using rocks, Roof rack by Brute force, Rock sliders by Brute force, Bed LED lights, Underhood LED automatic lights, Constant 12V bed plug, Rugged race radio, ICON uniball UCA's, KING 2.5 700 rate coilovers, Deaver rear leaf springs, KING 2.5 resi rear shocks (Flat 0.15 stack on compression shims), Scangauge, Empty wallet Mod Bug disease, AllPro Apex front bumper, On board heat exchange shower & water pump (Heater Core intercept mod), On Board Air - Viair for now, ARB when it dies-, allpro Skids back to gas tank- Tepui RTT on the shittiest "Bed Rack" ever made.... AllPro U Bolt flip kit with timbren bumps NEXT UP- expo leafs & bed rack, hydraulic bumps in rear, Total Chaos stock LCA's w/ Bypass, Rear 12" shock hoop relocate
    2013 DCSB off road 4X4
    Mid travel, on 33's
    Heavily used for off road.
    Lift and larger tires has been done thousands of miles ago so that shouldn't make a difference. Didn't hit anything particularly hard on the trails this weekend but the light came on yesterday on the trail & will not shut off.
    Down hill assist and Atrac are non functional now, though 4x4 works fine.
    Checked all fuses- IGN,1,2 and everything in between. No dice there.
    Last I can think of is some talk of the alignment being jacked up causing this issue?
    She was pulling hard to the right on the way out to camp Thursday and on the way home she's pulling hard left.
    Any help is greatly appreciated guys !
  2. Jun 23, 2014 at 12:13 AM
    ewbaltz
    ewbaltz Well-Known Member
    Eric
    Arizona
    12 DcSb SR5 4X4
    Totally Stock
    Although you might have a little more fun finding the simple fix and taking care of it,please for your sake take my advise.Turn around ,don't walk run,to best dealer in your area and have shop go thru that baby with a fine tooth socket now while its still under warranty. if it turns out to be serious issue could save you thousands $$$.
  3. Jun 23, 2014 at 12:22 AM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    Spencer go here In the first post it tells you how to recalibrate the VSC and that should make that light go away. You should get an alignment done first but you can still just make the steering wheel straigt do this reset and the light will go off. Redo it after you get an alignment. I've done this several times. ALways happens when I knock out my alignment on the trails.
    The above link talks about it showing up on the display...i've never seen it.
    All you have to do is jumper 2 pins on the ODB connector its pin 4 from the left on the top row and pin 5 from the left on the bottom row. make sure steering wheel is straight and you are parked on a level surface turn key on(do not start the truck) press the brake pedal 8 times within 5 seconds. Turn the car off remove the jumper and start back up...poof light is gone.
    Beefchief likes this.
  4. Jun 23, 2014 at 1:57 AM
    Aztecs
    Aztecs Well-Known Member
    Jose
    Goodyear, Arizona
    2012 DCLB V6 4x4 SR5
    Debadge, Tailgate lock, 3" ProComp Suspension Lift, ProComp wheels and tires, Volant CAI with ram air scoop.
    Take it to the Dealer, it might be part of the recall. I had my lights come on and it was the ABS system taking a shit. TAKE IT IN!!!
  5. Jun 23, 2014 at 5:46 AM
    Spencer
    TIGGLEBITTIES
    Agh. Thanks guys
    I think my game plan is to get it aligned then into the dealer. I've got a lifetime alignment so I may be able to get all this fixed for free! Kinda. Ha.
    I'll update as I find out!
  6. Jun 24, 2014 at 3:58 AM
    ewbaltz
    Eric
    Arizona
    12 DcSb SR5 4X4
    Totally Stock
    With apologies to Indiana Jones and the last crusade:
    -"You Have Chosen Wisely".
    Good luck duderino...
  7. Jun 26, 2014 at 9:13 PM
    Spencer
    TIGGLEBITTIES
    Okay so
    I first found that all the tabs around the alignment tabs were bashed in making it impossible for them to actually do my alignment. Bastards told me it was totally good to go.
    Good thing lifetime alignment means TRY AGAIN BUDDY
    So
    I bent all the smashed metal back in place & dropped it off to get aligned again.
    Here's to praying that fixes it.
  8. Jun 26, 2014 at 11:47 PM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    Just a little heads up here. Once you bend those tabs back it really weakens them. After your alignment go back and make sure all the cam bolts are really tight. More times than not bent cam tabs are due to loose cam bolts...and thrashing in the dirt ;)
    You should really consider getting the Total Chaos cam tab gussets or at the very least run a weld along the outside of each of the cam tabs to strengthen them. This problem will come back and if you don't notice that they are loose and you drive around the cam bolts will start to thrash the hole on the LCA supports that come off the frame and that will be another can of worms you don't want to deal with.
  9. Jun 27, 2014 at 12:06 AM
    Spencer
    TIGGLEBITTIES
    Sigh.....
    One more reason to find a LT kit that is built to handle my shenanigans..... Haha
  10. Jun 28, 2014 at 2:13 PM
    Spencer
    TIGGLEBITTIES
    Got it back from getting aligned... Light still on.
    Used scan gauge to clear all codes (even though it cant read the VSC code...) but worth a try.
    Nothing.
    Pulled battery cable, let it sit dead for 10 minutes, restart, nothing.
    Light still on.
  11. Jun 28, 2014 at 3:24 PM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    I told u how to clear it in an earlier post. I'm just over the hill from u in Yorba Linda if U want me to do it for u.
  12. Jun 28, 2014 at 7:52 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    I've seen dirty wheel speed sensors cause this. Pull the out and clean them well and see what happens. Also if any of the wires are broken the light will come on, as well as if the ABS fuse is popped.
  13. Jun 30, 2014 at 4:56 PM
    Spencer
    TIGGLEBITTIES
    Well it's half fixed.
    Happened to be by my company mechanic & asked I'd he could clear it & he said oh yeah no prob & jumped in & cleared the ABS memory- page two of the instructions for doing factory zero point VSC calibration.
    Cleared the light, but I know I need to do the zero point to do it correctly.
    Now I'm twice as hesitant to do the paperclip method....
    I'll get my dealer to do it when I take it in next & maybe with a paperclip when I quit being a pussy about shorting out the ECU
  14. Jun 30, 2014 at 5:08 PM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    You are not shorting out anything. The equipment your dealer hooks up does essentially the same thing. Loops those 2 connections and then he will turn the truck on step on the brake 8 times in 5 seconds and then give you your truck back with a bill.
  15. Dec 19, 2016 at 7:28 PM
    bryanbyers28
    bryanbyers28 Well-Known Member
    Bryan
    Woodstock, GA
    2013 Black Tacoma 4x4 TRD Off-Road
    WeatherTech floor liners LED Map, dome, and license plate lighting Home made console organizer 30" LED Light Bar in lower grill Toyota Bed Mat
    I have had the same problem on my 2013 but it happened after i installed my long travel kit. So you are staying that I can take it to the dealership and have them clear the codes on the traction control? i don't have any ABS light on.
    Also do you think this will cost me anything to get this done?
