Trac off light and check engine light on, what would cause this?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ard1, Apr 24, 2020.
  1. Apr 24, 2020 at 6:45 PM
    Ard1
    Ard1 [OP] Member
    Hi everyone,
    Hope everyone is well. I got in my truck today, started it up and noticed my trac off light is on and my check engine light is on. Ive had the truck 6 years and never had a check engine light on before, seems to be running fine. I have a 2013 Tacoma. 4 cylinder. 4x4. Any suggestions?
  2. Apr 24, 2020 at 7:48 PM
    Muddinfun
    Muddinfun Well-Known Member
    Make sure the gas cap is tight. If that's not the problem, go to Autozone and have them read the codes.
    Ard1[OP] and Skyway like this.
  3. Apr 24, 2020 at 8:10 PM
    Philrab
    Philrab Curator of useless knowledge
    Phil
    New Orleans, Louisiana
    2015 Pyrite Mica Quad Cab Prerunner
    Bunch of Basic Taco mods.
    Best I’m aware any CEL will set off the Trac off light. CEL disables you’re traction control, retards your ignition timing, and locks out the overdrive on an auto transmission.
    Read the code, and you’ll know what the issue is.
  4. Apr 25, 2020 at 6:58 AM
    Ard1
    Ard1 [OP] Member
    Thanks! Went to autozone and the code that comes up P0138, bank 1 Sensor 2 O2 electrical signal had high voltage for a predetermined period of time. Im Wondering why this would make the trac off light come on?
  5. Apr 25, 2020 at 7:00 AM
    Ard1
    Ard1 [OP] Member
    Philrab just read your post! Thanks!!!!
    Philrab likes this.
  6. Apr 25, 2020 at 7:29 AM
    Ard1
    Ard1 [OP] Member
    muddinfun thanks!!
    Muddinfun likes this.
  7. Apr 25, 2020 at 7:37 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Look for exhaust leaks before you spend any money. Do this when the engine is cold. When things heat up and expand, it'll be harder to locate.
    Also clean the MAF sensor and TB with their respective cleaners. The butterfly in the TB is motor driven. Trying to open it could damage gears if you're not careful. Aside from spraying inside, I also use soaked q-tips to clean around the butterfly.
    As for the MAF sensor, don 't touch that lil shiny bulb. It's fragile. Just spray it down.
    When your done and start it up, it's gonna idle high. No worries. Watch and you'll see it come down in steps as the ECU sees that it doesn't need the TB open so far. All that stuff you cleaned out of the TB was impeding airflow, and the truck was compensating for that.
    Ard1[OP] likes this.
  8. Apr 25, 2020 at 8:45 AM
    Ard1
    Ard1 [OP] Member
    Larzzzz thank you!!!
    Larzzzz likes this.
  9. Apr 25, 2020 at 4:28 PM
    pdaddy
    pdaddy WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
    I’ve had the same issue for almost a year. The trac and engine light will come on randomly, then go off, doesn’t happen often, probably only 3 times. I’ve just ignored it and it’s been fine, no noticeably difference in performance or fuel economy. You might be good to just leave it alone
  10. Apr 25, 2020 at 4:32 PM
    Yotatruck
    Yotatruck Active Member
    Noel
    PA
    09 TRD Sport
    Kenda Tires, rims, stereo
    Hell of a coincidence, I just had the exact same thing happen to me today. I pulled the negative connection to the battery and it cleared after a few minutes. What I believe caused my issue was that I left the rear lights button on after I parked the truck. When I started it up the CEL and traction control lights were lit and I noticed when I put it in Drive the R on the instrument PRDN cluster was still lit. That had me stressed for a minute when I realized the backup camera was still on. I have a button that turns on my auxiliary rear lights and when I got the frame replaced the technician wired it to the reverse signal and wired the lights to the OEM backup lights. Now when I push the auxiliary rear light button the camera turns on also. It was cool, but I believe it caused me the CEL and Trac lights to go on.
  11. Apr 25, 2020 at 5:03 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Yes, that will cause a CEL having more than one indication for the gear on at the same time.
