TPMS & tire rotation
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rujack, Jan 5, 2019.
  1. Jan 5, 2019 at 11:31 PM
    Rujack
    Rujack [OP] Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    Now that I’m past 25k miles, it’s time for my first diy tire rotation on this truck. Will pressing the reset button prompt the system to detect the new locations of the wheels? Or is it more involved?
  2. Jan 6, 2019 at 2:14 AM
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    tire rotation is every 5000 miles, rotate and hold tpms button for about 10 seconds. drive for awhile, see what happens
    a400ryan likes this.
  3. Jan 6, 2019 at 6:07 AM
    Gator352
    Gator352 I like Publix cake ...
    Leesburg, Florida
    2018 Super White Tacoma SR5 4x2
    I thought when you rotate, it will auto update?
    over60 likes this.
  4. Jan 6, 2019 at 6:18 AM
    Markc1024
    Markc1024 Well-Known Member
    No. Just ensure when pressing the button that you're stopped and then wait for the TPMS readout to clear and stop flashing. Also, ensure your tires are cool as I believe it also sets the low pressure warning based on where they are at the time.
  5. Jan 6, 2019 at 6:20 AM
    Clearwater Bill
    Billy
    Largo Florida
    Note the DIY. I think (hope) he's had the 'free' dealer rotations up till this point.
    AvocadoTaco and Tullie D like this.
  6. Jan 6, 2019 at 7:22 AM
    tallpilot
    tallpilot Well-Known Member
    David
    Florida
    2016 TRD OR 4X4 DC SB AT Silver
    Mobtown sliders, RCI skids, Bilstein 6112/5160/Dakar, DuroBumps
    Yes. The reset button is for resetting the set point so don't push it unless you are getting false warnings. Just rotate the tires and the module will figure out the new wheel positions after a few drives.
    na8rboy likes this.
  7. Jan 6, 2019 at 7:24 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Correct, it does. I have done 3 rotates and have not had to reset. I run 35psi front 37psi rear. After rotate it auto updated, after short drive.
    Gator352[QUOTED] likes this.
  8. Jan 6, 2019 at 8:00 AM
    Rujack
    Indeed I have. I also intend to rotate more frequently than every 5k.
  9. Jan 6, 2019 at 8:01 AM
    Rujack
    Excellent, thanks all.
    Gator352 likes this.
  10. Apr 9, 2019 at 6:21 PM
    Moose256
    Moose256 Well-Known Member
    2018 Tacoma TRD Off Road
    I just got a new set of tires today. Kept same factory wheels. The tire light is on and None of the TPMS are showing pressure. I tried the reset button, it no change. I’ve driven it about thirty miles, hoping it would re-calibrate. Any ideas?
  11. Jul 12, 2019 at 2:50 PM
    Chris19TRD
    Chris19TRD Member
    2019 Tacoma TRD Off Road
    BFG KO2's
    Im about to rotate mine this week-8k miles (Im late I know) I havent had the dealer do anything - Unless there's another reason I'm unaware of - I'm not driving 45min one way to the dealer for something I can do myself in 20 minutes.
  12. Jul 12, 2019 at 3:08 PM
    Ramsus
    Ramsus Member
    Virginia
    2017 Tacoma 4x4 TRD Off-Road MT
    Goodyear Duratrac LT245/75R16 SumoSprings SSR-612-40 Tekonsha Prodigy P3 Brake Controller
    I don't remember doing anything special for the sensors after rotating mine. I do remember the aluminum alloy wheels being a real pain to get off the rear. They were seized on and I had to use a heavy mallet to knock them loose.
  13. Jul 12, 2019 at 3:27 PM
    Alesimo
    Alesimo Jeeper
    Alec
    Houston, Texas
    2020 Jeep Wrangler JLUD
    What about a 5 tire rotation?
  14. Jul 12, 2019 at 4:46 PM
    Sasquatchian
    Sasquatchian Well-Known Member
    Hold the button until the dash icon flashes. I just did this last week and it took about three days of driving around town for them to finally re-register. Just when you think you're going to have to press the button again, they pop on. And I never let the dealer touch my tires. I really don't trust them to properly torque the lug nuts and it only takes about half an hour to do the rotation yourself if you've got a floor jack and an electric impact driver. Actually it's that damned impact driver that makes it almost fun. Zip. Zip Zip. And don't forget that it's 83 lb/ft on the lugs going back on.
    over60 likes this.
  15. Jul 12, 2019 at 4:53 PM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    When the tire shop swapped my sensors I had no issues with the truck knowing which tire had what pressure.
    Not sure how it knows where the sensor is located? LF, RF, LR or RR but it seems the truck can tell where each sensor is located.
    Because it gives me the correct tire pressure for each tire.
  16. Jul 12, 2019 at 7:08 PM
    Dubiousveracity
    Dubiousveracity Well-Known Member
    2018 TRDOR DCSB MT
    none
    Why? Do you constantly have a significant amount of weight in the bed?
