TPMS Sensors
Discussion in 'Wheels & Tires' started by Gamebreaker81, Dec 26, 2019.
  1. Dec 26, 2019 at 9:34 AM
    Gamebreaker81
    Gamebreaker81 [OP] Well-Known Member
    MA
    2016 sr DCSB 4x4 v6
    Bought new wheels whats my move for TPMS sensors? Aftermarket work ok? OEM is crazy pricey. Suggestions?
    tacofish likes this.
  2. Dec 26, 2019 at 10:40 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Swap them over
  3. Dec 26, 2019 at 10:41 AM
    Bishop84
    Bishop84 Well-Known Member
    This is best, the headaches with aftermarkets isn't worth it.
  4. Dec 26, 2019 at 11:17 AM
    Gamebreaker81
    MA
    2016 sr DCSB 4x4 v6
    Problem is i gave my old wheels and tires to my dad. So either me or him have to get sensors.
  5. Dec 26, 2019 at 11:22 AM
    Ccrames2018
    Ccrames2018 Jack of some trades.
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    -Bilstein 5100s @1.75" -16x8 SCS Ray10s with 305/70R16 General Grabber AT -CMC -URD Short Throw Shifter -Bed stiffeners -Bed mat -Aftermarket head unit -AFE Rebel exhaust -ME-SO Customs dome/map lights -Window tint with eyebrow -OEM LED 2015 tail lights -GTR Lighting headlight bulbs -Husky floor liners -Camper shell -Sumo Springs -Air intake -Aftermarket Volkswagen key fob -Aftermarket A/C knobs -Aftermarket LED license plate lights -Console organizer -JBA High Caster UCAs
    I've heard a lot of mixed reviews on aftermarket sensors, as well as compatibility issues with some trucks. OEM is obviously the best choice but yeah they're pretty spendy. Looks like they're around $65 each.
  6. Dec 26, 2019 at 11:24 AM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    I bought a set of Denso from Amazon and they seem to work fine. It hurt but less than buying them from Toyota directly.
  7. Dec 26, 2019 at 11:24 AM
    gotoman1969
    We’ll spend the money on oem, go in half with the your dad, one of you was gonna half to buy some anyway
    Truc577 and Ccrames2018 like this.
  8. Dec 26, 2019 at 11:28 AM
    Ccrames2018
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    This↑
    Truc577 likes this.
  9. Dec 26, 2019 at 12:54 PM
    calebc
    calebc Well-Known Member
    I had my tire shop install some aftermarket ones on my 4Runner and have had zero issues with them. I haven't done any TPMS sensors on my Tacoma after going to aftermarket wheels (bought them through a different shop and they wanted $60 per sensor for aftermarket sensors, my regular tire shop only wants $20 a sensor for aftermarket ones). My light hasn't come on yet and it's been probably three months. I'll wait till it comes on then I'll go have my regular shop put their aftermarket ones in.
  10. Dec 27, 2019 at 12:53 AM
    Crow Horse
    Crow Horse Well-Known Member
    Central NY
    2012 DCSB TRDOR
    If I remember correctly from what I've read, Denso supplies the sensors to Toyota but they're actually manufactured by Parker Industries for Denso. They're about $39 ea on Amazon.... You can go this route and save some loot.....
    ****Edit - The manufacturer is actually Pacific Industrial......
    Truc577 likes this.
  11. Dec 27, 2019 at 4:55 AM
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    You may be thinking of Pacific Industrial. You can save some money if you can find TPMS sensors from Pacific re-boxed. That's the company that usually makes TPMS sensors for the Japanese brands. I think Pacific is the direct supplier to Toyota.
    https://www.pacific-ind.co.jp/eng/
    Typically companies like Beck-Arnley or Dorman (and others, NAPA, etc.) do not actually make their own replacement parts and they'll sometimes get them straight from the original supplier. The problem is there's no guarantee that an aftermarket brand won't find a cheaper company in China to knock off the part either.
    So part of the reason you buy directly from Toyota is you're pretty sure it's done to spec and not counterfeit. In this case Denso doesn't make TPMS sensors and is the company re-boxing them. But they are also a legitimate company (being another major primary supplier to Toyota for parts they do make) so the reason to buy from them is you can usually trust they aren't fakes either and should be a little cheaper than Toyota.
  12. Dec 27, 2019 at 5:01 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    7 cars worth of TMPS from Discount Tire since 2010 or so. Zero issues. There is your answer.
  13. Jan 1, 2020 at 5:11 AM
    Truc577
    Truc577 Well-Known Member
    Curt
    NOMO
    2005 TRD OR 4x MT, 2020 TRD OR 4x AT
    High output valve stem caps 2020: Bilstien 6112/5100 Mobtown sliders RRW RR-5 Bronze wheels 2005: 2018 frame and full suspension 2017 Dark Anthracite wheels ARB front bumper
    What about programmable\cloneable sensors? Anyone had luck with those?
  14. Jan 1, 2020 at 5:19 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Tire Discounters broke one my sensors and replaced it with whatever aftermarket ones they carry. Zero issues...and that was nearly 2 years ago.
    And my daughter's 10 year old Yaris has had a couple of sensors die. Again...no issues with the AM replacements
  15. Jan 1, 2020 at 5:24 AM
    Plain Jane Taco
    USA
    That's what Tire Discounters uses. They cloned the sensor that they broke from my Tacoma. A sensor can be cloned as long as it's still transmitting a signal.
    But in the case of my daughter's Yaris, the sensors had died. Can't clone a dead one. They simply dumped the new sensor's info into the OBDII port overwriting the old info
    Truc577[QUOTED] likes this.
  16. Jan 1, 2020 at 5:29 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Since you already have a 2016 I'd use the old sensors in the new wheels. Sensors typically last 7-10 years. Your truck is only 4 years old so you should be good until you need tires the next time. Before buying my next set of tires I'd locate some and have them installed with the next set of tires. If your truck were a 2014 or older I'd probably spend the money for new ones now.
    And I've used aftermarket sensors in the past. Worked great.
  17. Jan 2, 2020 at 2:13 PM
    Texas
    Texas Well-Known Member
    This is correct info. Pacific Industries manufactures each and every TPMS sensor in the Tacoma. Pacific also manufactures the rubber snap-in valve used on the spare assembly of every Tacoma or also the ground assemblies on the export market Tacomas where TPMS sensors are not used.
  18. Oct 22, 2024 at 2:10 PM
    jardoo
    jardoo Well-Known Member
    Beirut, Lebanon
    2016 DOUBLE CAB MGM 4X4 TRD OFF ROAD SHORT BED
    sorry I know this is old but I ordered the denso Tpms sensors from rock auto for my 2016 OR.
    Did I get oem? Thanks.
  19. Oct 23, 2024 at 1:59 PM
    Texas
    Pacific Air Controls out of Ohio supplies the sensors at the factory for the 2016 models. I am sure Denso is just as good though, they are a trusted supplier of Toyota.
    jardoo[QUOTED] likes this.
