TPMS Sensors - Are They The Same For Steel & Factory Alloy Wheels
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacTuna, Aug 1, 2019.
  1. Aug 1, 2019 at 6:15 AM
    TacTuna
    TacTuna [OP] Active Member
    Charlie
    2012 Tacoma Access Cab V-6 4X4
    2012 Tacoma AC - plan to purchase some factory alloy wheels to replace the steel wheels on my truck. As the post title says, are the TPMS Sensors the same for either wheel? I want to re-use if possible. Thanks.
  2. Aug 1, 2019 at 6:21 AM
    Taco-mama
    Taco-mama Well-Known Member
    2015 DCSB Prerunner
    Is it safe to assume that TPM's only work with tubeless tires? :confused:
  3. Aug 1, 2019 at 6:22 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    no they are different, also the lugnuts are different you cannot use the steel lugs for use on the alloys, there is tons of info on the site use the search
    E3g likes this.
  4. Aug 1, 2019 at 6:26 AM
    TacTuna
    Charlie
    The wheels I'm looking to purchase come with the lug nuts. Thanks
  5. Aug 1, 2019 at 6:41 AM
    TacTuna
    Charlie
  6. Aug 1, 2019 at 6:47 AM
    BillsSR5
    bill
    2014 SR5
    after using the proper alloy sensors in the alloy rims, your computer IDs has to be changed in order for the TPMS to work
  7. Aug 1, 2019 at 9:03 AM
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    Can you point to this procedure? Thank you.
  8. Aug 1, 2019 at 9:19 AM
    Muddinfun
    Muddinfun Well-Known Member
    Either go to Discount tire and have them do it or buy the pirated Techstream for ~$40, install it on a laptop and do it yourself. Get the sensor ID numbers off the new sensors before you mount them in the wheels.
  9. Aug 1, 2019 at 10:56 AM
    BillsSR5
    bill
    2014 SR5
    https://youtu.be/OfUQ8uwK9eM the new alloy sensors need to be re-registered into the ECU in order for the TPMS light on dash to work properly
    TacomaSport86[QUOTED] likes this.
  10. Aug 1, 2019 at 11:02 AM
    TacomaSport86
    This would be similar for a 2nd gen Tacoma? Thank you
  11. Aug 1, 2019 at 11:07 AM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    You can use the TPMS from the steel wheels, they need to be rotated to fit into the alloys, and you need to make sure that any subsequent tire changes you inform the shop in advance that the TPMS units have been rotated so they don't break them off when they're changing the tire.
    BillsSR5 likes this.
  12. Aug 1, 2019 at 11:10 AM
    BillsSR5
    bill
    2014 SR5
    it would be exactly the same for 2nd gen sensors, I was thinking about going to alloy rims on mine from steelies and theres a lot of things that need to be changed in order to do the switch up, I decided just to keep the steelies and just get new tires which im still researching, also 3rd gen alloys TPMS sensors CANNOT be reprogramed to work with a 2nd gen truck and vice versa, theres a lot info on this subject here on TW ive read all of it
  13. Aug 1, 2019 at 11:12 AM
    BillsSR5
    bill
    2014 SR5
    true, from what ive read not all tire dealers are willing to take the risk of breaking them during install or tire removal because the tire guy might not be aware and break the bead opposite the air valve and crunch them
  14. Aug 1, 2019 at 11:20 AM
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    It is supposedly standard procedure for them to drop the TPMS inside prior to breaking the bead. I have the steel sensors in aluminum factory wheels and remind them to anyway. And each time they tell me that "it's standard procedure...."
    I've had two sets of tires installed with the steel TPMS on the aluminum rims and no issues.
  15. Aug 1, 2019 at 11:23 AM
    BillsSR5
    bill
    2014 SR5
    I would definetly be reminding them
  16. Aug 1, 2019 at 11:29 AM
    Steve_P
    TN
    Yeah, I'm paranoid. If they get a new guy and he doesn't know procedure yet and breaks one (or 4), they'll tell me I should have told them. And I'll be buying sensors.
    I did what the OP wants to as my truck was low optioned and only came with steel wheels. I got a set of almost new alloy wheels for $160 with the lug nuts and reused the OE steel wheel sensors. No issues.
    BillsSR5[QUOTED] likes this.
  17. Aug 1, 2019 at 11:32 AM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    I did the same on my base 12 and base 17. Steel to factory alloy. OEM TPMS, no issues.
  18. Aug 1, 2019 at 11:44 AM
    BillsSR5
    bill
    2014 SR5
    ive been looking around for a good set of knockoff 2nd gen 16" alloys they are getting tough to find on the East coast most are already bubbling up the paint from road salt, right now im looking for a new set of all season tires so I can ditch the Dunlops, the MICHELIN Defenders are great tires but im at 120k miles and really don't have the funds right now for them, do u have any good ideas on a good Brand all season tires at the 245/75/16 size
