TPMS Sensor replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 4x4Taco09, Jan 7, 2017.
  1. Jan 7, 2017 at 1:33 PM
    4x4Taco09
    4x4Taco09 [OP] Well-Known Member
    Dane
    Louisiana
    09 TRD Sport 4x4 BSP DC LB
    Kings, Deavers, Brute Force, Prinsu, Lights, all the stuff
    I don't shop at the stealership, never have and never will
    My trucks sensors finally kicked the bucket I think. From the searching on TW I've done, I found that a lot of people are buying and using these
    https://www.amazon.com/Denso-550-01...automotive&vehicleId=2&vehicleType=automotive
    I just want to make sure that these will work with SCS wheels.
    Thanks guys
  2. Jan 7, 2017 at 2:27 PM
    nine2nine
    nine2nine Well-Known Member
    Greensboro N.C.
    06 TRD Tocoma Sport 4wd
    i'd like to know myself.I had a sensor go bad less than a month ago and now my light is on again.$ 246 a dealer.I won't do that again.
  3. Jan 7, 2017 at 2:32 PM
    4x4Taco09
    Dane
    Louisiana
    Yep, my light has been on for about a week or so. Check all of my tires and they're all at 33-34. But I have new tires and waiting for the shipment of SCS wheels so I can buy my wheels for them. So Ill be buying 5 of these sensors if I know they'll work fine
  4. Jan 8, 2017 at 6:03 AM
    airrage
    airrage Well-Known Member
    Myrtle Beach, SC
    2006 Tacoma Prerunner SR5 DCSB
    17X9 Gear Alloy Rims, BFG KO2's , Android Radio, 32" LED Light Bar in Bumper, LED Bed Lights,
    cant you just replace the batteries in these or no?
  5. Jan 8, 2017 at 7:56 AM
    Taco Hunter
    Taco Hunter Well-Known Member
    Hunter
    Triad, NC
    09' Tacoma 2.7l AccessCab 4x4
    Old Steelies to Trd 16'' Matte Black with Cooper ATX3 tires Mech to Electric (Very large but super silent) Single Fan Throttle body coolant bypass + Port and Polish LED Fog lights with custom fabricated mounting 2012 headlight assembly K&N Drop In Intake StopTech Drilled Rotors with EBC Greenstuff Pads StopTech Front + Rear Stainless Steel Brake lines Old Fabric to leather swap on doors 20% Window Tint LCE Long tube headers with Milltek resonator and Magnaflow 12586 muffler WeatherTek In-Channel Deflectors Fox Racing 2.0 Coilovers with Fox 2.0 IFP in the rear Total Chaos UCA's Whiteline Lateral Locks Hellwig Rear Sway Bar Energy Suspension Poly Bushings: Sway Bar, Cab, Rear Leaf Spring
    Where did you get your tires mounted and balanced? For me its discount tire and when I had to replace one all they charged me was for the sensor because free rotations and balancing for life of tires!
    TRDSport10 likes this.
  6. Jan 8, 2017 at 8:13 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    pretty much a sealed unit... better off buying all new sensors plus installation (big bucks) or saying fuck that and check the pressure with a $15 tire gauge.
  7. Jan 8, 2017 at 11:05 AM
    4x4Taco09
    Dane
    Louisiana
    I haven't yet, thats why I am trying to make sure that these sensors would work before I order them. What did discount tire charge you for the sensor they replaced for you? I bought my tires from Discount Tires eBay, so Im going to have them mount and balance them for me
  8. Jan 8, 2017 at 2:06 PM
    only49ersfan
    only49ersfan Well-Known Member
    Myrtle Beach, SC
    09 Tacoma 4X4
    Not much. Step bars, K&N air filter
    are all 4 tpms sensors bad? you may just have one or two sensors needing replacement
  9. Jan 8, 2017 at 3:00 PM
    redz80
    redz80 Well-Known Member
    Brampton, ON
    Tacoma SR5 TRD 4x4 SWB
    I had Schrader Ez sensors installed in my summer rims. Most tire shops use them, they are fully programable. I had them clone the factory sensors so I can change my tires without reprograming each time.
  10. Jan 8, 2017 at 3:01 PM
    nine2nine
    Greensboro N.C.
    After some research I solved my problem and it might work for OP.I just had a sensor replaced a month ago and I checked my tire pressures after I got home and they had set the tires to 40psi and I run 32psi.So I dropped them to 32.then it got pretty cold here and my light came on again.what happened is when dealership set my tire pressures at 40psi they also reset the TPMS at 40 and when I dropped my pressures to 32 and it got cold it turned the light on.What I did was to turn the ignition switch to the ON position and push and hold the reset button until the light flashed 3 times and then went off.
    BruteTaco, TRDSport10, Travlr and 2 others like this.
  11. Jan 8, 2017 at 3:02 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    I bought the Oro-tek's from Amazon. Got all four for 125. Worked great in my SCS Ray10's. Dealership was the only place that could program them however.
    angeldavid216 and 4x4Taco09[OP] like this.
  12. Jan 8, 2017 at 3:09 PM
    nine2nine
    Greensboro N.C.
    "dysfunctnlretard" had a good write up on Tacoma World about this Jun 6 2009,look it up.
  13. Jan 8, 2017 at 4:39 PM
    4x4Taco09
    Dane
    Louisiana
    What did the dealer charge you to program them to your truck? I know I just need the serial numbers off the sensors for them to program them, I really don't want to give the dealer any more than I have to so I had planned on letting Discount mount and balance them for me
    I will give this a shot for now!
    No I doubt it, but the average life of the sensors are 8-10 years. My truck was bought in 08, so might as well just change them all now, plus I need one for my spare since the last shop broke one and used my spare one.
  14. Jan 8, 2017 at 4:42 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    The dealer charged my $300, but that was because I didn't have the old sensors for them to clone as I had already sold the wheels and tires with the OEM sensors. If I would of had the old sensors available to them, it would have been $200.
  15. Jan 8, 2017 at 4:46 PM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
  16. Jan 8, 2017 at 4:56 PM
    4x4Taco09
    Dane
    Louisiana
    and that was for 1 or all?
    The spare also came with a sensor as well. Ill be running a full size spare and rotating that tire in every rotation, so Id like to have one in it as well
  17. Jan 8, 2017 at 5:01 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    That was for all four.
    4x4Taco09[QUOTED][OP] likes this.
  18. Jan 8, 2017 at 5:07 PM
    Tiedie
    David
    WFOY
    That's cool I only need 4 but had all replaced at Firestone when I got new tires and jesters put on. And they programed them no extra charge.
  19. Jan 8, 2017 at 6:04 PM
    Lineback
    Lineback Well-Known Member
    2013 Tacoma DoubleCab TRD
    5 x 285/65/R18 Nitto Trail Grappler mud tires on 18" XD wheels (full sized matching spare) Bilstein 5100s with 3" spacer lift Prinsu roof rack Secondary air filter mod ARB Deluxe Bull bar front bumper + ARB LED fog lights ARB Recovery point Warn 9.5xp winch with steel cable SOS Concepts angled rock sliders with kick-outs 2 x Baja Designs LP9 Pro mounted to ARB bumper AVS window vents Interior knob mods Toyota bed mat Toyota hood deflector Toyota bed cargo divider Steelcraft 33250 Rear tail light cage guards Reverse light LED mod Wet Okole seat covers WeatherTec floor mats Tail gate anti-theft mod COMMS: On-board 2 meter VHF HAM radio (Boafeng F8HP mobile) + Bluetooth integrated mic External antenna: Nagoya UT-72 Super Loading Coil 19-Inch Magnetic Mount spotter radios: 2 x Cobra ACXT1035R FLT Gear: IFAK EMT Trauma wound kit 5lb fire extinguisher
    I just removed the sensors, good riddance.
    Travlr likes this.
  20. Jan 8, 2017 at 6:41 PM
    4x4Taco09
    Dane
    Louisiana
    Did you take sensors up there and did you get sensors from them?
    Do they have the sensors in stock usually?
