TPMS sensor questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2ndhandTacoman, Sep 22, 2023.
  1. Sep 22, 2023 at 11:19 AM
    2ndhandTacoman
    2ndhandTacoman [OP] Well-Known Member
    Walter
    Maryland
    '15 Base AC 4x4, 2.7 powerhouse
    3rd gen TRD OR suspension
    Hello everyone. Has anyone been through the process of buying new TPMS sensors for their truck? I've got some 3rd gen wheels that I want to run on my '15, the issue is that I still have the stock steelies so I can't use those sensors on the alloy wheels. I've been going through search results and still don't have a clear idea of what all is involved with getting aftermarket Denso sensors and getting them to play nice with the 'puter of my '15 Taco.
    I'm looking at Denso 5500-103 on Rockuto for the sensor.
  2. Sep 22, 2023 at 11:36 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    I believe the only differences are steel wheels versus alloy wheels
  3. Sep 22, 2023 at 1:49 PM
    Agoldxj
    Agoldxj Well-Known Member
    James
    Central Pa
    2009 SWB AC
    I put 3rd gen alloys on to replace the steelies on my 09. Went with Autel MX sensors since we have the programming tool at my workplace.
    2ndhandTacoman[OP] likes this.
  4. Sep 22, 2023 at 2:27 PM
    Geeves77
    Mark
    Northeast
    2011 Tacoma DCSB
    no don’t forget if you have a spare you might have to buy five of them, you don’t have to put one in the spare though, and then you’ll have to take it to a garage and have them program the new sensors in for you
    ScrippsRanch67 likes this.
  5. Sep 22, 2023 at 3:21 PM
    Ted Striker
    Ted Striker Well-Known Member
    2 WHEEL DRIVE!
    All of the aftermarket 315 MHz or dual 315/433 sensors will work. Don't need OEM. As for steel vs alloy, many (most?) aftermarket sensors will fit both wheel types. The only difference is how you orient the wide part during installation.
    2WD likes this.
  6. Sep 22, 2023 at 3:56 PM
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
    @2ndhandTacoman I bought Denso sensors from Rock Auto about 5 years ago when I put some 3rd gen wheels on my 07. I was in AZ at the time (I live in TX) and went to Discount Tires to purchase new tires and have them mounted on the 3rd gen wheels along with the new sensors. The tech doing the install could not get the sensors to communicate with his scanner. He said I should have written down the ID numbers so he could program them into his scanner. Long story short, I went to the manager, explained the situation while asking him to look up my 40+ year purchase history with Discount. He did, then grabbed another reader and went to my truck. Within 7 minutes the senors were scanned and communicating with my truck. I'm not sure if the tech was incompetent or just lazy. I was just glad the manager took the time to take care of a long time customer.
    This is what the ID's looked like.
    2ndhandTacoman[OP] and GilbertOz like this.
  7. Sep 22, 2023 at 5:35 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    starting 09 they only have 4 - none in spare on mine. They have to unload the old sensor #s to add the new.
  8. Sep 22, 2023 at 5:52 PM
    soggyBottom
    soggyBottom Well-Known Member
    When I got new tires on my 2018, they broke one of the sensors. They replaced it with a generic one. It keeps the tpms light off but won't sync up to display tire pressure.
    When I connect using techstream, it's stuck showing "judging" and never actually figures out which wheel is mounted on which corner. You can manually set the wheel location but if you press the tire reset button, you'll get stuck in that loop again.
  9. Sep 22, 2023 at 6:00 PM
    VaGlock
    VaGlock Well-Known Member
    Kevin
    central virginia
    14 DBLC / Sport / Blue Ribbon Metalic
    Weathertech mats and wind deflectors, Bak Flip cover, CB Radio,Clazzio seat covers,Scan gauge,Uni filter,LED interior lights, Redline hood struts
    I believe the Denso's have two different part numbers one for steel and one for alloys is because of the mounting angles of the TPMS stems. A lot of the other aftermarket TPMS sensors have a universal style stems.
  10. Sep 22, 2023 at 6:08 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I've had good luck with sensors from Amazon. They cost $15-$20 each and I had no issues getting them installed and programmed. I've replaced sensors in 3 vehicles with them.
  11. Sep 22, 2023 at 6:39 PM
    2WD
    2WD Well-Known Member
    Pete
    2013 DCSB TRD Off-Road Pre-Runner Taco
    King 25001-119A, JBA HC and superbumps, EL095 leafs with longer overload leaf removed and 2 degree shim, Bilstein 5160 rears with fox roost shield on passenger side, King 2'' bump stops, B&M 70264 trans cooler, CSF FJ radiator, Leer Trilogy X2T bed cover, Scangauge, 34R AGM battery, weathertech floormats, Gold plug on the differential, fancy engine and diff oils, UNI air injection filter mod, Factory antenna chopped 4'', De-badged, Ram mount on A pillar, Cooper ST Maxx 265/75 R16.
    I bought 4 RDE228V21 from rock auto when I got new wheels and tires to replace my 10 year old oem sensors. No issues. It's the same BH brand Discount uses and at a big savings.
  12. Sep 22, 2023 at 7:27 PM
    My2009taco
    My2009taco Committed - or at least some thinks I should be…
    Joe
    Massachusetts
    2009 MGM Tacoma SR5 Access Cab 4x4
    Rough Country Bull bar, Redrock side steps, Raxial Axiom black housing halogen headlights, LED black housing tail lights, K&N oiled filters, black rear bumper, TVD red emblem inlays, black powder coated 16” five spoke sr5 rims, Falken Wildpeak at3w 265/70R16 tires, spidertrax 1.25” wheel spacers, torch sway bar drop kit, g2 red epoxy painted calipers, tinted cab glass, hood protector, Trifecta folding Toneau cover, Argent raptor grill w/ leds, led fog lights, Bilstien 4600 shocks, Rigid d-series midnight edition spots, Redline hood struts
  13. Sep 23, 2023 at 6:02 AM
    Geeves77
    Mark
    Northeast
    2011 Tacoma DCSB
  14. Sep 25, 2023 at 4:25 PM
    2ndhandTacoman
    Walter
    Maryland
    Thanks for all of the replies and sharing your personal experiences with different brands. I'm leaning towards the Denzos, at $35/each it seems like a "safe " bet although some of the ones on the africian river company website show good reviews ( 4.0 +) for the 4 pk for $35.. my inner cheapskate likes that idea even better.
    BlkDakDave likes this.
  15. Sep 25, 2023 at 5:44 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Same experience as above. The tire shop I've been going to for a long time (w/ a TW member as one of the managers) said he couldn't get the Amazon sensors to sync up. I didn't feel like dealing w/ the hassle so just let them sell me theirs. I think it was about 80 each, installed?
  16. Sep 25, 2023 at 8:26 PM
    Geeves77
    Mark
    Northeast
    2011 Tacoma DCSB
    Remember, you get what you paid for.
    Rock auto get the denso’s. 35+ each
    Then sees ya in 10 years
    4 pack for 35, do it again in 1 year, if they sync up. And will cost twice as much in the end
    My2009taco likes this.
  17. Sep 26, 2023 at 12:45 PM
    myrustytaco
    myrustytaco Active Member
    Jerry
    Michigan
    06 tacoma
    Debadged 18" wheels
    My 06 has tpms sensor in spare, can it be deleted or do I need to buy 5.
  18. Sep 26, 2023 at 4:31 PM
    Geeves77
    Mark
    Northeast
    2011 Tacoma DCSB
    You don’t have to buy five as they can just remove the TPM from the computer that belongs to the spare tire
    myrustytaco likes this.
