TPMS reset won't work
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KeithB, Sep 13, 2016.
  1. Sep 13, 2016 at 11:04 AM
    KeithB
    KeithB [OP] Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    Some background:
    2009 DC TRD sport 4x4, 135,000 miles. Never saw the dash light come on before in nearly 8 years with the truck but then I never aired down before this past weekend. Took the truck on the beach and aired down to 15 psi. TPMS dash light came on as expected. Aired up a few hrs later and the light went off as expected. About 10-15 miles later the next day, the light flashed a few times and then came on steady. Stopped to check tire pressure and all is fine, 32psi just as before the beach run. Checked the manual and followed the system reset procedure. Ignition to ON (engine off), press and hold reset button until light stops flashing, turn to ACC and wait a few minutes. Only problem is when I turn the ignition to ON (engine off), the light starts blinking for a few minutes and then stays on steady. That scenario is not in the manual. I've tried holding the button while the light is blinking and while it's not blinking. No effect. Is something broken or am I just not understanding what to do? As I understand it, I shouldn't even need to reset it once the air pressure is back to what it should be, the light should go off right? It can't be a coincidence that the one time I air down, something goes wrong with the TPMS. I've had 4 sets of tires on these wheels with the same valve stem sensors so pressure has been down to 0 psi and back up as high as 40 psi when the tires were replaced. No issues then so its not like the pressure has never been changed before.
  2. Sep 13, 2016 at 11:07 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    check your spare tire, it may be low or high from your 32 psi.
    JaiOME likes this.
  3. Sep 13, 2016 at 11:07 AM
    anders99
    anders99 The Sailing Member
    Matthew
    Penscola, FL
    (07 Base 4cyl 4x4 - RIP) -> 2018 4Runner SR5 Premuim
    Taco SOS Offroad Concepts hybrid front bumper Iggy Corp. Switch panel Famous Fab ditch lights and cb antenna mount Pioneer Appradio 2 Halo Led Headlights Led Taillights 3'' toytech spacer lift on front end Toytec AAL on rear AFE cold air intake 4Runner Stock
    It could be that one of your batteries in the TPMS sensors has gone out.
    tomwil likes this.
  4. Sep 13, 2016 at 11:10 AM
    taco06
    taco06 Well-Known Member
    Alex
    pomona ,California
    06 sprt
    I can't let the wife know
    Had the same issue a few times. Once was my spare tpms. I belive 09 don't have it, & the other time I had to get tire pressure right at 29 when cold. Followed the procedure and after a few miles of driving it went away. Could also be a dead battery on your tpms.
  5. Sep 13, 2016 at 11:11 AM
    CharlieCafe
    CharlieCafe Well-Known Member
    Charles
    Wherever the wind blows
    24 Tacoma TRD Offroad Premium 4x4
    Plethora of "useless" shit
    Most likely a sensor needs to be replaced. I have an '09 as well and had two go bad just last year with the same blinking for a while then steady. Whether it is true or not I was told there is a non-replaceable battery in them that goes out or the sensor got damaged somehow.
  6. Sep 13, 2016 at 11:39 AM
    KeithB
    Keith
    Cheshire, CT
    Did not even consider batteries. I will look into that. Just seems odd that it happens right when I triggered the light to come on and then the battery dies?
  7. Sep 13, 2016 at 11:50 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I think those batteries life span is about 7 yrs. but they will last a little longer also. If one dies, you can bet the others aren't far behind.
    The lithium ion batteries inside TPMS sensors may last anywhere from five to 10 years. Five to six years is a more typical lifespan for older TPMS sensors. TPMS sensors don’t broadcast a continuous signal but only broadcast when the vehicle is in motion. Even then, the signal is intermittent to conserve battery life
  8. Sep 13, 2016 at 11:54 AM
    98tacoma27
    Ben
    Not Beech Creek
    this is what happens when they good bad...
    They are half assed seal with silicon
    wilcam47 likes this.
  9. Sep 14, 2016 at 4:52 AM
    KeithB
    Keith
    Cheshire, CT
    Update: Tried holding the SET button before turning the key to "ON". Turned the key to "ON" while already holding the SET button. Held for like 20 seconds while the TPMS light flashed the whole time. Released the button and started the truck. Light went off a few minutes later. Soooo...... what does that mean? Whatever, I'm just glad the light is off now.
    JaiOME likes this.
  10. Sep 15, 2016 at 8:30 AM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Light blinking right away and then going steady means one of the sensors isn't connecting/communicating. If it was actual low pressure the light would come on and be steady not blink.
  11. Sep 15, 2016 at 9:54 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Keith,
    I have the TechStream cable and a laptop. If it comes back, I can stop by on my way home from work with it and determine which sensor is causing the issue.
    Paul
  12. Sep 18, 2016 at 8:29 AM
    KeithB
    Keith
    Cheshire, CT
    Thanks but for now its fine. Light is still off.
  13. Sep 18, 2016 at 6:25 PM
    Fury
    Fury Well-Known Member
    My manual says to leave the ignition in the on position for a few minutes before turning to acc or lock.
  14. Oct 18, 2016 at 6:20 AM
    KeithB
    Keith
    Cheshire, CT
    Noticed my tire pressure looked a little low on the front tires so I put a gauge on them. Sure enough, all 4 tires down to 28psi. Aired up to 32psi and now the TPMS light on the dash is back on. Once again, can't reset it. Blinks for a minute or two when the truck is first started and then stays on steady. If I can't get the system to reset, I will find a way to disable the stupid light before I ever go and pay hundreds of dollars for new sensors.
  15. Oct 18, 2016 at 6:41 AM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Keith, the light on mine came on last week when it got cold out overnight. Put air in (was 27psi p, brought it up to 30) and the light stayed on with a flash when starting the truck. I had to press the reset under the dash to get it to go off. It took a few minutes of driving to get the light to go off. I assume it has to do with the pressure sensor sampling frequency as to how fast it resets.
  16. Oct 18, 2016 at 1:50 PM
    KeithB
    Keith
    Cheshire, CT
    Ok, so it finally reset after about 10 miles. Doesn't seem right but ok.
  17. Oct 19, 2016 at 1:32 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The correct procedure is as follows:
    1. Inflate all tires to pressure indicated on tire placard.
    2. Turn ignition to ON position (engine off).
    3. Hold down tire pressure reset button (located on instrument panel, knee bolster or inside glove box) until TPMS telltale flashed 3 times.
    4. Initialization will be completed when ECU has received signals from all from all sensors. Process may take 2 - 3 minutes.
    At this time the TPMS Light should be off.
  18. Oct 19, 2016 at 1:59 AM
    wafflroo
    wafflroo Well-Known Member
    Suquamish, WA
    Ruckus
  19. Oct 21, 2016 at 5:37 AM
    KeithB
    Keith
    Cheshire, CT
    Thanks
  20. Nov 18, 2016 at 6:28 PM
    anarion55
    anarion55 Well-Known Member
    Tony
    S. Florida
    2013 PreRunner SR5
    ImMrYo's Mirror Mod, Stereo Upgrade - Power Pro 60x4 Amp/Kicker powered 8" sub/Pioneer component speakers, PassPort 8500 Radar Detector, Locking Bed Storage Cubbies, Onboard air system - Viair 450C compressor/16 gal. PVC tank/15 & 16" horns, quick-d/c air chuck in bed cubby 24" LED light Bar (mounted to skidplate)A Headlights, foglights interior lights and backup lights all converted to LED (HUGE difference)
    does anyone know how to just disable the fucking TPMS light on the instrument cluster? I've had it with the bull shit false warnings. Today I found out that all 4 tires were 6 lbs low, so I inflated them to the correct pressure (32psi). Fucking light came on (flashing first, then solid) and will not reset. Gonna cut the goddamned wire to the light. I've been monitoring my own tire pressure since I started driving in 1973. I don't need a friggin' computer to do it for me, and I'll be damned if I'm spending $600+ at the dealer to replace the sensors.
    My wire cutters are waiting. Wiring diagram, anyone?
    JaiOME and Mallet like this.
