TPMS on aftermarket wheels
Discussion in '3rd Gen. Tacomas (2016-2023)' started by iLLbiLLkiLLz, Sep 21, 2023.
  1. Sep 21, 2023 at 9:58 PM
    iLLbiLLkiLLz
    iLLbiLLkiLLz [OP] Member
    2020 Tacoma SR
    S&B cold air intake Pedal Commander 20x9 Fuel Blitz wheels 275/55 Bridgestone Duellers TRex Billet Grille Form tail lights
    I bought some Fuel Blitz wheels and tires second hand. After installing them, I'm getting "Check TPMS" on the dash. I'm not sure if the new rims have them, is there an easy way to check or anything I can do to reprogram them if the do have them or is this a job for the tire shop? Pic included of what my aftermarket valve stem looks like. Thanks.
  2. Sep 21, 2023 at 10:00 PM
    LOLLY
    LOLLY Well-Known Member
    Alfredo
    Norwalk, CA
    '05 Tacoma DCLB TRD Sport (RIP) Now '21 TRD Off-Road
    If you still have the original wheels then your easiest cheapest route would be to have a shop swap them into the new wheels. That's what I did when I got new wheels and tires
    iLLbiLLkiLLz[OP] likes this.
  3. Sep 21, 2023 at 10:16 PM
    iLLbiLLkiLLz
    2020 Tacoma SR
    I do still have my OEM wheels, they are the basic steel rim. Is there a way to tell if these aftermarket ones have TPMS on them already and maybe these just need flashed or programed to fit my truck? I was told they came off a dodge ram.
  4. Sep 21, 2023 at 11:44 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Really the only ways to know if they have tpms is to break the tire bead and look. Other option would be a tpms scan tool (tire shop) and see if it picks up a device.
    MQQSE and iLLbiLLkiLLz[OP] like this.
  5. Sep 22, 2023 at 1:27 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    You'll save yourself time and frustration by going to your tire shop as advised ^^^^.
    I can tell you aftermarket sensors are available significantly more affordable than OEM. I didn't have sensors in my Winter rims 4 years ago. I went to have new tires mounted and my tire shop told me they couldn't mount my tires w/o TPMS sensors; not sure if an actual legal issue or insurance issue?
    I commented frustrated, "man, those things are over $100 a piece."
    They tell me, "we have aftermarkets a third of that price." Bottom line, they installed 4 sensors for $165 (parts & installation). No issues with them for 4 years running. I do my own seasonal changeovers and stop by their shop to have them scan and synch the sensors every Spring and Fall. I'm generally in and out in 5 mins w/o charge. Hope this helps, good luck.
  6. Sep 22, 2023 at 2:04 AM
    iLLbiLLkiLLz
    2020 Tacoma SR
    Sounds like I'm gonna hit the tire shop and go from there. Appreciate all the feedback so fast!
    MQQSE likes this.
  7. Sep 22, 2023 at 3:13 AM
    Xero
    Xero Well-Known Member
    18 Tacoma TRD Off Road, 22 4R, 08 4R
    18 Tacoma TRD off road OME BP51 front Fox 2.0 Resi rear OME Dakar Meduim Yoko G006 325/75r16 Black Rhino stadium wheels Cali raised ditch light brackets Baja Designs S1 pods Baja Designs Squadron SAE fogs Prinsu Cab rack TRD Pro grille AVS rain guards Backwoods adventure mods hi-lite bumper BL Apex 12k winch Dobinsons 4x4 snorkel Sy-clone prefilter ARB rear diff breather relocation RRW rock sliders RCI full skids At the helm bed stiffeners lil b LCA skids Warfab Phantom rear bumper Warfab tie rod sleeves C4 fender liners Dirt king UCA Duro bump stops
    I had them put my OEM sensors in my new wheels. If you aren’t going to use your old set I’d just have them swop them over.
  8. Sep 22, 2023 at 3:30 AM
    OBXPaul
    OBXPaul Just do what you say you're going to do!
    Paul
    Kill Devil Hills, NC (Outer Banks)
    2016 Black Tacoma Limited, 1983 Blue Deluxe Pickup
    1983 restoration in progress, major mods so far new 6" lift and 35" Mickey Thompsons.
    Tire shop is your best bet if you don't have the tool for programming the sensors. You can pick one up on Amazon very inexpensively, good to have in your toolbox, especially if you rotate your own tires like a lot of us do.
  9. Sep 22, 2023 at 3:32 AM
    50Buck
    50Buck Living rent free Timmy the Tool's head
    If you didn't tell them to swap over the OEM ones, or you didn't tell them you wanted aftermarket ones in the new wheels, then they likely didn't install any. They aren't auto included and certainly aren't free. Check your receipt to see if you paid for sensors if you didn't tell them to swap the OEM ones over.
  10. Sep 22, 2023 at 3:40 AM
    Ed_Force_1
    Ed_Force_1 Up the Irons!
    Jeff
    Battle Creek, MI
    2023 Limited Nightshade
    Interior LED lights, hood struts, Weather Tech floor mats, Toyota bed mat, screen protectors, sill protectors, Pop & Lock power tailgate lock, McGard tailgate anti-theft lock, gas cap holder, iArmor drop step running boards.
    You might be able to buy some cheap cap style sensors and sync them to your truck.
    Could be cheaper than dismounting and remounting the tires just to move over the OEM sensors.
  11. Sep 22, 2023 at 5:06 AM
    LOLLY
    Alfredo
    Norwalk, CA
    You are going to need to buy new ones. I've heard the sensors in steel wheels are not able to mount into alloy wheels
