TPMS oem part number
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 808stateofmind, Apr 28, 2023.
  1. Apr 28, 2023 at 8:15 PM
    808stateofmind
    808stateofmind [OP] Well-Known Member
    Kona
    '22 Lunar Rock TRD OR 4x4 DCSB 6MT
    Eibach pro truck 2.0/2R lift kit 1.5" AAL OME/ARB UCA BFG KO2, 285/70-17 SCS Blaze 10, 17-8.5, -10 offset ECGS bushing needle bearing replacement Clutch accumulator disk delete Poor mans TRD intake, K&N 57 series intake tube, K&N high flow filter, TRD flow accelerator
    Looking for the oem part number for TPMS sensor for a '22. getting two different part numbers, and I am not sure which is the right one. 42607-04020 or 42607-06030, hard to tell what the difference between the two is on parts sites
  2. Apr 29, 2023 at 12:48 AM
    WhiteTaco20
    WhiteTaco20 Well-Known Member
    Perkasie, PA
    SW 2020 TRD Sport DCSB
    One might be for the steel wheels. But i bought a used set of oem off of ebay for like 80 bucks awhile back to put in a set of new wheels and ive never had any issues with it. Been almost 3 years now
  3. Jul 8, 2023 at 12:41 PM
    Kingspeedy
    Kingspeedy Member
    Rob
    2023 Tacoma
    I am running into the same issue. Did you figure out what was what? I have alloys.
    When searching for 42607-06030 on Amazon .ca it says doesnt fit my 23 Trd sport.. Some sensor listing show either number as an alternate part # some sensors are 20 % the cost or the oem..its a mindfield of choices..lol
  4. Jul 8, 2023 at 9:02 PM
    808stateofmind
    Kona
    I ended up having costco swap my tpms sensors from my stock wheels to my new wheels when I had my tires mounted. I had originally bought replacement sensors off of Amazon to make the process easier, but later decided to have them swapped to my new wheels and just put regular valve stems in my stock tires. The oem sensors are more valuable which is why i kept them, and i didnt wanna run into issues not being able to program the new ones.
    these are the ones I bought and returned, not sure if they would have worked or not
    Amazon.com: PDQ TPMS 315MHZ Tire Pressure Sensor 4 Pack Metal Stem Toyota Lexus Scion Pre-Programmed for OE Part # 42607-0E020 | 42607-02050 | 42607-06030 | 42607-48010 | 42607-53020 : Automotive
  5. Nov 11, 2024 at 6:56 AM
    YE2KA
    YE2KA Well-Known Member
    JB
    19 Cement Grey Tacoma Offroad
    Does anyone know if you go with OEM sensors does the dealer need to program them or will the automatic sync to the tire pressure madule?
  6. Nov 11, 2024 at 7:04 AM
    BDSKJChris
    BDSKJChris Well-Known Member
    Albany, NY
    2019 Quicksand TRD OR DCSB
    A new OEM sensor will need to be registered to the Trucks TPMS system via techstream or a TPMS tool. Might be worth posting in a regional Forum to see if anyone close to you has a TPMS tool and get a price to have them clone the bad sensor with a universal sensor
  7. Nov 11, 2024 at 7:13 AM
    YE2KA
    JB
    Thanks for the info I figured they needed some sort of programming
  8. Nov 11, 2024 at 12:02 PM
    JaTe
    JaTe Well-Known Member
    Maryland
    2017 Tacoma TRD OR DCSB
    I bought Autel MX TPMS sensors for my SCS wheels and cloned the IDs off the stock TPMS. Now I can swap wheels whenever without having to reprogram the truck.
  9. Nov 12, 2024 at 3:00 PM
    YE2KA
    JB
    Nice! How much would it cost to get new sensors program
  10. Nov 12, 2024 at 5:09 PM
    JaTe
    Maryland
    I have the tool so was able to clone it myself.
