Tpms not reading?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Azianwind, Nov 12, 2018.
  1. Nov 12, 2018 at 12:12 PM
    Azianwind
    Azianwind [OP] Well-Known Member
    Michael
    Orange county ca
    2017 Blazing Blue TRD Sport 2WD - 2021 TRD Off Road 4x4 Voodoo Blue
    Anyone knows how long does it takes before the tpms register? Ive drove a good 15 miles to work and it didn’t read the pressure at all. A few days ago the check engine light came on after we drove about 30 miles and there was no reading. Just curious if this is normal?
  2. Nov 12, 2018 at 12:18 PM
    Kilokato
    Kilokato Go Vols!
    George
    East Tennessee
    2016 SR5 Access Cab V6 Auto 4wd
    Limited wheels, extra rope hooks in bed.
    Mine has a TPMS reset button under the steering wheel...Check to see if yours does too.
  3. Nov 12, 2018 at 12:19 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    No. It is not normal, and you are about the third person to post this in the past week or so.
    Hopefully, those folks will post their resolutions.
    My only guess is that the system is dependent on determining which sensor is in which wheel. The only way that I can imagine a single antenna doing that is by comparing the change in wheel RPM as you go around corners. So, try a good drive with some corners and no stops? From my experience, stopping seemed to restart the process?
  4. Nov 12, 2018 at 12:21 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Did you recently rotate the tires, sometimes takes a little while after rotating and resetting.
  5. Nov 12, 2018 at 12:24 PM
    Azianwind
    Michael
    Orange county ca
    No haven’t rotate the tires recently
  6. Nov 12, 2018 at 12:26 PM
    Azianwind
    Michael
    Orange county ca
    It does. How do you reset it?
  7. Nov 12, 2018 at 12:26 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    If I'm right, the sensors won't go blank by themselves after a rotation. You have to hold the button down for that to happen? I've only used the reset button a few times. Once after a cross rotation rather than asking the dealer to do that. It took no time for the pressures to come up on the proper tires. Less than a couple minutes at about 35mph.
    shakerhood[QUOTED] likes this.
  8. Nov 12, 2018 at 12:26 PM
    Kilokato
    Kilokato Go Vols!
    George
    East Tennessee
    IDK...
    Probably look in the manual.
  9. Nov 12, 2018 at 12:27 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Page 468 of the manual.
    Hold it until the low pressure light flashes three times. Then drive 25mph or faster for about 10min.
    I've had it read again while going slower than 25mph. It just takes a lot longer.
    shakerhood likes this.
  10. Nov 12, 2018 at 12:32 PM
    shakerhood
    Southern Ohio
    I think it does go blank and then registers numbers after about 10 miles of driving
    tonered[QUOTED] likes this.
  11. Nov 12, 2018 at 12:33 PM
    KBOX
    KBOX In a va.. *cough* truck down by the river.
    Jody
    Acton, Ontario
    2017 Tacoma DC Sport V6M 4X4
    Stock
    I still cannot find that screen for the life of me.
  12. Nov 12, 2018 at 12:36 PM
    tcjacado
    tcjacado Well-Known Member
    The tpms screen?
    You get there by pushing the direction left or right on the steering wheel controls.
    shakerhood and tonered like this.
  13. Nov 12, 2018 at 12:36 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Use the button on the right side of your steering wheel. If your center display is on the first screen (speed or MPGs), bump it right three times, and you're there.
    shakerhood and tcjacado like this.
  14. Nov 12, 2018 at 12:41 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I'm looking forward to being done with ToyotaCare. So far for messing around with stuff when taking the wheels off (lubing the leafs until I realized that you can do that without pulling the wheel), the TPMS didn't seem to care. I was curious to see how fast it would determine the new positions after the cross over. I just swapped sides since the dealer just did the regular rotation and was barely out of the neighborhood before it started registering. I did hold the button down though first.
  15. Nov 12, 2018 at 12:46 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    When I just changed my tires the other day it registered them super fast. I backed out of the bay, and drove about 50’ around the corner of the building. Stopped and all the pressures were reading
  16. Nov 12, 2018 at 1:00 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Don't forget to set the tires to your intended pressures BEFORE doing the button reset....
  17. Nov 12, 2018 at 2:41 PM
    KBOX
    Jody
    Acton, Ontario
    Stock
    Yeah. I don't have the vehicle symbol on mine. I wonder if it's a Sport vs. Off Road or a US market vs Canadian feature.
    I do have the sensors on both sets of rims.
  18. Nov 12, 2018 at 2:47 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Good point. For the US, the only real difference that I am aware of is the ORs get the Inclinometer, which I believe is a screen below the Compass screen? The symbol might be different for the CA trucks, but you should have the pressures reported. Be sure to scroll up and down on each screen?
  19. Nov 12, 2018 at 3:00 PM
    Azianwind
    Michael
    Orange county ca
    Sorry what does that mean? All my tires are around 32 psi the last time i saw it.
  20. Nov 12, 2018 at 3:29 PM
    KBOX
    Jody
    Acton, Ontario
    Stock
    Yeah. I have been looking for this for over a year now.
