TPMS light is on.....but tires are fine.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HubbaBubbaGump, Oct 21, 2010.
  1. Oct 21, 2010 at 12:35 PM
    HubbaBubbaGump
    HubbaBubbaGump [OP] Member
    Carlos
    Katy, Tx
    06 Prerunner SR5
    Hello.....I just joined this site. Lots of good info and this is my question:
    The TPMS light turned on about 2 weeks ago but all tires looked good upon initial inspection. I took it to Discount Tire and they checked all four wheels. All looked good but light will not reset. Then last week as I was hauling my son and 2 of his friends home (800 lbs of football players), I noticed the rear right side made a grunting noise as I made a u-turn. Never heard such a noice before. :eek:
    So I'm thinking I have a busted shock...would this cause the TPMS light to come on? Truck has 105k and it has original shocks....what do you all think?:eek:
  2. Oct 21, 2010 at 12:37 PM
    HubbaBubbaGump
    Carlos
    Katy, Tx
    06 Prerunner SR5
    Yes, it was checked. It's still secure under the bed. Is that what you meant?
  3. Oct 21, 2010 at 12:37 PM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    What he said ^^^^^^^and welcome
  4. Oct 21, 2010 at 12:38 PM
    Loudpedal
    Loudpedal Mind = Blown
    Blair
    Not really New, not really Mexico
    02 SR5-Hole 4x4
    Andres Devil Horns, Goodyear Duratracs, Accidental Tailgate Delete (x2), Billy 5100s, OME 881 coils, Wheeler's 5-leafs, BAMF Sliders with kickouts, Box Rocket Fab Bedrack.
    The air pressure in the spare.
  5. Oct 21, 2010 at 12:38 PM
    98tacoma27
    Ben
    Not Beech Creek
    No, it has a sensor also. Throw some air in there.
  6. Oct 21, 2010 at 12:39 PM
    HubbaBubbaGump
    Carlos
    Katy, Tx
    06 Prerunner SR5
    Hhhhmmm.....I didn't realize the spare had a TPMS sensor. I will do that.
  7. Oct 21, 2010 at 12:39 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    No, check the PSI in the spare as well. If it is off, it will bugger the reading and Bam, TPMS light.
    Mine has been on since I got the truck in early 08. Tires have been all the same. I have no clue what is wrong with the fucking thing.
  8. Oct 21, 2010 at 12:41 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You may have to reset it once you fill the spare. There's a buttom below the steering column used to reset the light.
  9. Oct 21, 2010 at 12:43 PM
    HubbaBubbaGump
    Carlos
    Katy, Tx
    06 Prerunner SR5
    Figures....kid that checked the tires did not look a day over 18. :rolleyes:
  10. Oct 21, 2010 at 12:46 PM
    Cobra6
    Cobra6 Well-Known Member
    Beri
    Tennessee Valley
    '06 PreRunner SR5 TRD Sport
    my spare would leak about 5 lbs of air over a 2 - 3 week period, and it would cause the TPMS light to come on.
    I finally found where the tire had a bad plug in it and got it fixed.
  11. Oct 21, 2010 at 12:47 PM
    iSTIZO99
    iSTIZO99 Well-Known Member
    Jax, FL
    2010 TRD Sport 4x4 DC/SB
    Just so I understand...only the 05-08 Tacos have got a sensor in the spare and the 09+ don't? Mine came on earlier this week, but I'll check it out tomorrow once I've got some time.
  12. Oct 21, 2010 at 12:47 PM
    HubbaBubbaGump
    Carlos
    Katy, Tx
    06 Prerunner SR5
    Yes sir....I've reset it a few times before. I just did not realize the spare has a sensor. It makes sense now since the light will not reset when I have my spare on....cuz the tire I took off is flat.:eek:
  13. Oct 21, 2010 at 12:49 PM
    98tacoma27
    Ben
    Not Beech Creek
    Wait? You have a flat that you removed from the truck and the tire is still flat?
  14. Oct 21, 2010 at 12:56 PM
    HubbaBubbaGump
    Carlos
    Katy, Tx
    06 Prerunner SR5
    No..no...no.....I was refereing to past experiences with the TPMS....
  15. Oct 21, 2010 at 12:57 PM
    98tacoma27
    Ben
    Not Beech Creek
    Ah, gotcha. :thumbsup:
  16. Oct 21, 2010 at 1:17 PM
    CtTaco
    CtTaco Well-Known Member
    Eric
    Connecticut
    2010 4x4 Doublecab Sport Longbed Supercharged
    3" lift, Tundra wheels with BFG ATKO's, Viper Remote starter TRD Supercharger
    If that doesnt fix it, just open up the guage cluster and stick a piece of electrical tape over the led for the TPMS light. Problem solved :) Theres a writeup on here somewhere...
  17. Oct 21, 2010 at 1:20 PM
    HubbaBubbaGump
    Carlos
    Katy, Tx
    06 Prerunner SR5
    I'll have to buy your book : 1,000,001 Ways to Use Tape :D
    What's the typical life for these tire sensors anyway? Anyone know?:confused:
  18. Oct 21, 2010 at 1:36 PM
    Cobra6
    Beri
    Tennessee Valley
    BTW - I also found out that as soon as I removed the spare from the truck and it was being repaired, the TPMS light went off.
    Once I had the tire fixed and mounted, I just reset the TPMS with the button under the dash and everything was fine.
  19. Oct 21, 2010 at 1:49 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    lol yea, they stopped putting a sensor in the spare in the 08+ models I believe because they realized it's a pain in the *** to keep getting underneath the truck and refilling the spare.
  20. Oct 21, 2010 at 1:56 PM
    mws4ua
    mws4ua I'll try being nicer if you try being smarter.
    Birmingham
    2018 GMC Sierra SLT Z71 4x4... Yeah yeah, I know.
    I'm inferring from this...
    I know somebody who wants to replace his steelies w/ aluminum TRD rims. As we know, the sensors from steel wheels won't fit the aluminum wheels. Taking all of the sensors off the truck will result in the TPMS light coming/staying on.
    What if he replaced all of his wheels, but left the sensor in the spare (which is not being replaced). Would that one sensor be enough to keep the TMPS light from coming on, assuming he kept it properly inflated?
    Just wondering, since it seems that removing one low-pressure wheel will make the light turn off.
