TPMS battery replacement SUCCESS!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mattmaxon, Jun 28, 2022.
  1. Jun 28, 2022 at 5:34 PM
    mattmaxon
    mattmaxon [OP] Active Member
    being an inveterate cheapskate I was galled to see it was going to cost somewhere between $150 - $25 each for 5 new TPMS sensors + installation and programming for my 2008 Taco Access Cab 4x2 2.7L
    2 local shops wanted $500
    BAH! I first opted for the cheapest solution black tape over the light
    Searching for solutions I saw this guy on youtube
    https://www.youtube.com/watch?v=EtZWndK1gE8
    I tried the jack <> the car and the tire method but I'm not that cheap and bought the XB-450 Bead Buster from the mfg website since it was $10 less than anywhere else + free shipping
    https://beadbuster.com/product/beadbuster-xb-450/
    I got the batteries on ebay 5 of them for $24
    https://www.ebay.com/itm/125301354436
    Some of what was done in the video was cringe worthy and I felt I could do better.
    Using the XB-450 is easy but for my rims I needed to reposition it after making a bit of room to get the foot close as I could to the rim .
    Using a wood 2x2 with a 45 on one end I pried the tire down and removed the sensor
    This is the sensor on the bench
    Pry off the back cover with a small screwdriver
    remove the potting compound from around the battery and circuit board being careful not to damage the circuit board
    Carefully insert the screwdriver under the battery lifting gently, when the battery is free do the same with the circuit board eventually extracting the assembly from the housing
    Remove the potting compound from around the area where the battery is soldered on the circuit board and remove the solder. A desoldering Iron makes this a breeze which I have HAKKO FR-300
    I found for the best result you need to clean as much of the potting compound as you can from the circuit board and case.
    The batteries I got the tab was too big to fit in the hole so I used scissors to trim some off the width of the tabs.
    Make certain you get + to + and - to - as there are no markings on the circuit board and are tiny on the battery.
    I checked the voltage of all the batteries I removed and one was below 1 volt . When I reinstalled the tires one at a time I checked to see if the warning light was off. The one with less than 1 volt was the culprit. All the others where near to falling below one volt so the decision to replace them all is validated.
    I test fitted the repaired assembly in the case, then removed it then filled the case with Silicone Bathroom sealer. Gently pressed the assembly in the case making sure the circuit board was on the posts and the battery was in the clips. I then smoothed over the excess sealer and added more as needed. I'd recommend nitrile gloves when handling the sealer and in a well ventilated area
    This is the repaired sensor
    Self-leveling electronic grade potting compound is available, but it is expensive and setting time is 24 hours
    I opted for a spin of the wheel with silicone bathroom sealer since I had it on hand
    I also had mis-matched rims making it difficult to buy the sensors and some independent Toyota Techs say the aftermarket ones can be problematic
    I have 4 T15x6J rims they use the PACIFIC PVM-108J sensor
    I have one J15x6JJ rim this uses the PACIFIC PVM-107J sensor
    Hope this helps someone
    ENJOY!
  2. Jun 28, 2022 at 5:43 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Good on ya for this. I need to fix my spare TPMS, but I have already bought the replacement.
  3. Jun 28, 2022 at 6:25 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    I would have went to rock auto bought the pre programmed ones and called it a day
    The garage charged me 75.00 to scan them in
    yanceyh3 likes this.
  4. Jun 28, 2022 at 6:48 PM
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
    "being an inveterate cheapskate I was galled to see it was going to cost somewhere between $150 - $25 each for 5 new TPMS sensors + installation and programming for my 2008 Taco Access Cab 4x2 2.7L
    BAH! I first opted for the cheapest solution black tape over the light"
    My hat is off to you for venturing into this project. Being retired, I've pressed forward in similar DIY undertakings.
    Amazing how much prices have increased, while our security and quality of living have decreased in just a very short period of time.
    mit88 and SR-71A like this.
  5. Jun 28, 2022 at 8:23 PM
    huyner
    huyner CoCKaSiAn
    Huy
    Orlando
    2007 Tacoma TRD Prerunner Sport 4x4
    a lotta money spent, lotta scars made
    Idk if they still do it, but I know discount tire programmed mine on another vehicle for free. When I rolled up for free air, I asked em about it and he just ran the tool n did it.
  6. Jun 29, 2022 at 4:22 AM
    mattmaxon
    FWIW these are the OG sensors and batteries so what 14 years? I don't encounter freezing temperature much so that maybe a factor for battery life
  7. Jun 29, 2022 at 4:28 AM
    mattmaxon
    [QUOTE="BlkDakDave, post: 27504687, member: 89422"My hat is off to you for venturing into this project. Being retired, I've pressed forward in similar DIY undertakings.[/QUOTE]
    Yeah I was kicked to the curb just before the Covid - catastrophuck 45+ years experience is apparently negative
    This would have been something I'd be tasked with repairing since parts where not readily available or not available at all and the machine had to be repaired
    PzTank and BlkDakDave[QUOTED] like this.
  8. Jun 29, 2022 at 6:50 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Good job! I'm lazy and went with the light on the dash and a $10 tire pressure gauge...
  9. Jun 29, 2022 at 7:10 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Cool writeup. You say you have mismatched sensors, but they are all OEM correct? Someone doing this job on stock rims can expect the same procedure for their sensors?
  10. Jun 29, 2022 at 7:35 AM
    hyper15125
    hyper15125 Headlight Retrofitting Hobbyist Vendor
    NJ (609)
  11. Jun 29, 2022 at 8:28 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    aint that the truth!
    BlkDakDave[QUOTED] likes this.
  12. Jun 29, 2022 at 9:00 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    :eek: Robbery.
    Great write up @mattmaxon :thumbsup:
  13. Jun 29, 2022 at 10:23 AM
    mattmaxon
    PACIFIC is the manufacturer for Toyota and many other vehicle manufacturers, so yes the one I have are the OEM ones
    https://www.pacific-ind.co.jp/eng/products/car/tpms/
    I would presume the procedure would be the same, but my experience is with my truck only
    SR-71A[QUOTED] likes this.
  14. Jun 30, 2022 at 10:37 PM
    Bluebaron7
    Bluebaron7 Well-Known Member
    Augusta, GA
    2009 Tacoma Double Cab TRD Off-Road(Sold)/2024 4Runner ORP
    3 Inch Lift, Leaf spring pack, SPC UCA's, Bilsteins 5100's, AFE CAI, ECGS Needle Bearing, CVJ Axles, Under seat Infinity Sub & 4 channel amp, softtopper, decked system, prinsu roof rack, Kenwood deck & Infinity speakers all around with door matting, taco sauce only sticker, steering wheel leather wrap and dash cam.
    Wow! Hats off to you for putting in so much work. I did the mod that disables the TPMS system instead and just check my tire pressure every so often.
    TexasWhiteIce likes this.
  15. Jun 30, 2022 at 10:51 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    that kind of silicone is usually acidic and will corrode the electronics if it is
    did it have a vinegar smell
  16. Jun 30, 2022 at 11:08 PM
    Fatback17
    Fatback17 Masshole
    Billy
    South of Boston, Massachusetts
    2020 TRD Pro MGM
    Not sure the guy making that vid would've thought it was worth it had he taken his thumb off while cutting that battery loose. Safety last must be his motto.
