TPMS Acting up in cold weather
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LabradorBoy, Dec 9, 2010.
  1. Dec 9, 2010 at 6:59 PM
    LabradorBoy
    LabradorBoy [OP] Well-Known Member
    Canada
    09 DCab TRD Sport
    Anybody else encounter this issue? I generally detest the TPMS anyway, but recently as the weather has been dipping below 0*C, my TPMS is acting up and causing the dash light to come on.
    I have checked all of my tires and the pressure seems to be the same on all four, perhaps the cold weather is wreaking havoc on my pressures. Either way, I have 4 spare TPMS sensors, how could I troubleshoot to determine which one is bad and have it changed?
  2. Dec 9, 2010 at 7:04 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    check the pressure in the spare tire
  3. Dec 9, 2010 at 7:04 PM
    jandrews
    '09 FourDubDee TRD OR
    ...Is the pressure *low* on all four? Because being the same is not the only item TPMS monitors.
  4. Dec 9, 2010 at 7:18 PM
    udy2554
    udy2554 NORTHERN RED-NECK
    Naples, NY
    '06 Tacoma TRD Sport
    Toytec ULK, Light Racing UCA's, OME Dakar rear leaves, ARB Bumper with XRC8 winch, Good Year Duratracs 285/70/17's on 17x9" Level 8 Strike 6's. Leer cap in the winter. Pioneer Double Din with BT, iPod, etc. Boston Acoustic components in all 4 doors with a Sony amp, powered 8" sub. Ultra gauge, Tom Tom...
    x2!
    Mine did the same thing. All tires were the same...except the spare...20psi. Filled all 5 to 40psi and all is well...after resetting the tpms.
  5. Dec 9, 2010 at 7:19 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I've had the light come a few times during cold snaps....mainly early on the way to work. By the time I checked the pressure after work the psi in all the tires (including the spare) were good. Could the reason for the light coming on be due to the 4 tires heating up while driving and the spare staying cold?
  6. Dec 9, 2010 at 7:33 PM
    jandrews
    Possibly. My spare, for some reason, has no TPMS. Not that that concerns me.
  7. Dec 9, 2010 at 8:22 PM
    Rob H
    Rob H Active Member
    filled up my spare.. light went out. :p
    Interesting when I dropped the spare it has some serious deep grooves where it has been "rubbing" against the cross members. I made sure to not crank the spare up as tight as it was. Hope this relieves the grooves
  8. Dec 9, 2010 at 8:27 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    He's got an '09. Only the '06-'08 years have TPMS in the spare.
    Two suggestions above could point you in the right direction. But here's what I would do first as a shortcut. Check the tires when they're cold and ensure they're where you want them. Then use the reset button to set the computer to monitor them from that temp. It could be that one was really warm or had a higher pressure the last time they were reset. So now they're all at the right temp, but the sensor is triggering in one of them because it's lower than it was when it was last set.
  9. Dec 9, 2010 at 9:18 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    OP , we had a week of -6 C highs and - 10 C lows , my TPMS light came on and I found that all my tires had dropped by 4 lbs , apparently enough to trigger the light in my case .
  10. Dec 9, 2010 at 11:24 PM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    Something I would try; holding the TPMS calibration button under your steering wheel, and if the light goes off, THEN inflate the tires, that might stop the light from comming on when there are big temperature ranges.
  11. Dec 10, 2010 at 1:37 AM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    I use the 5lb rule for winter. Example, I run my tires at 33 lbs all the way around. Lower all 5 tires ( spare inc) to 28 lbs hit the reset button. Then fill back up to 33.
    I have not had any issues.
  12. Dec 10, 2010 at 5:01 AM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    you can remove them replace with regular stems. remove the spare tire from the wheel and take all four sensors and duct tape the shit out of them to the inside of the spare. remount the tire onto the spare wheel and you good to go, no more PIA lights comming on.
  13. Dec 10, 2010 at 5:10 AM
    Skunkman
    Skunkman Well-Known Member
    Syracuse - Tug Hill
    2007 Tacoma Access Cab ,
    I thought the cold was effecting mine yesterday, and was cussing them too. One tire was down a little so I checked it over real well and found a rivet buried in my brand new snow tire.Much as I dislike the system,it saved me from changing a flat out in weather.
  14. Dec 10, 2010 at 6:09 AM
    LabradorBoy
    Canada
    09 DCab TRD Sport
    Wow, great responses. I did not know that I was fortunate enough to have a truck without a sensor in the spare, excellent, one thing eliminated anyway.
    My scenario is very similar to OffRoadToy's, comes on especially on the way to work in the morning when the temperature is at its lowest. I will inflate all four tires to 40psi (that's a lot!) and reset the monitoring system to see if I can make it go away.
    Appreciate the advice, I will post up what I find.
  15. Dec 10, 2010 at 6:27 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I would advise against this, you'll never be able to use your spare. Make a pressure vessel out of PVC or a wheel barrel tire/rim and put the TMPS sensors in there, not a tire that would be used on the truck. You can put the PVC vessel under one of the seats, in the bed storage compartment or metal zip-tie it to the frame or under the hood if you really want to.
  16. Dec 10, 2010 at 7:13 AM
    05Moose
    Jim
    Other way around. Lower the pressure to the lowest acceptable pressure you think you'll run them at, then reset it. Next, fill them back up to where you normally run them. Filling them up to 40 psi is not a good solution.
  17. Dec 10, 2010 at 7:23 AM
    TacoSupreme
    TacoSupreme Well-Known Member
    007 DC Cuatro Por Cuatro
    The TPMS sensors are more of a hassle!! Black tape it!
  18. Dec 10, 2010 at 7:30 AM
    Pugga
    Massachusetts
    I like having one in the spare since I can't tell you how much it sucks when your spare is flat the one time you need it! I now keep a small compressor with me all the time so I guess it shouldn't happen to me again... I don't mind them, I think they're nice for most people since not everyone pays attention to their vehicle's condition.
  19. Dec 10, 2010 at 10:00 AM
    OffroadToy
    Or you could strap them to the inside of the wheels...
    http://www.revolutionsupply.com/strapkit.aspx
    Another option is the presserized vessel. I made this one out of pvc...
  20. Dec 10, 2010 at 2:48 PM
    supralight
    Dan
    Earth
    did exactly the same as that, but about three times shorter so It could fit in my rear (access cab) baggage compartment where the jack is. OP, This is the best option you have, been doing this for 3 years now and no problem.
