Toytec Lift Issue
Discussion in 'Suspension' started by Executive, Nov 10, 2023.
  1. Nov 10, 2023 at 12:31 PM
    Executive
    Executive [OP] Conservative
    Peabody, Massachusetts
    2012 DCLB TRD Sport
    Hello Tacoma World,
    Back in July 2020, I installed a lift from Toytec. Aluma Series 2.0 coil overs, SPC UCAs, Aluma rear shocks, and OME rear springs. I've been completely happy with the setup and have had zero problems, other than a little difficulty dialing in the proper alignment after the initial installation. Until now.
    Last week I started getting a grinding noise from the suspension. After two days the noise stopped and I noticed that the driver side now sits 2 inches lower than the passenger side. Sort of Taco-Lean on steroids. The ride seems normal and I can not find any visible problems after inspecting everything including springs, bushings, shocks, tire pressure, and anything else that might be causing the problem. I'm at a loss.
    Can anyone offer some advice on what else to look for?
    2012 DCLB Sport, above suspension mods, 110000 miles.
    Thanks in advance.
  2. Nov 11, 2023 at 7:14 AM
    Toolndie7
    Toolndie7 Well-Known Member
    2019 Sport DCSB Cavalry Blue
    Definitely have something serious going on but kind of impossible to diagnose without seeing it.
    Can you load some pics from underneath to show us what’s going on?
  3. Nov 11, 2023 at 7:21 AM
    Bishop84
    Bishop84 Well-Known Member
    Need to take wheels off and truly look at the suspension.
    sounds like a broken spring.
    908tacoma likes this.
  4. Nov 11, 2023 at 8:32 AM
    908tacoma
    908tacoma Well-Known Member
    New Jersey
    2018 MGM
    OME, SPC, TRD
    Broken spring or unseated
  5. Nov 11, 2023 at 10:56 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Pics of both sides would help greatly
  6. Nov 11, 2023 at 4:30 PM
    Executive
    2012 DCLB TRD Sport
    Thanks very much to you all who responded. After reading your posts, I concentrated on the springs and measured them. The driver side (problem) spring measures 9 1/2" tall. The passenger spring is almost 11" tall. Seems like a broken spring or some spring failure. Emailed Toytec to see if I can buy a new pair of springs. Could not find these on their site, only complete coilovers. I'm guessing it will be smart to change them both. Really appreciate the help.
    Pics: the view showing top of tires is from exactly the same perspective on each side. The UCA is clearly off.
    Driver side
    Passenger side
    Driver side
    Passenger side
  7. Nov 11, 2023 at 5:47 PM
    gotoman1969
    We’re they preloaded more than the recommended 1.2” can’t tell from the pics.
  8. Nov 11, 2023 at 5:55 PM
    gotoman1969
    That driver side top coil looks wet did it blow a seal possibly.
  9. Nov 12, 2023 at 6:57 AM
    Executive
    2012 DCLB TRD Sport
    Preload is set as received from the factory. (Bought the coilovers pre-assembled).
    Wet look on driver coil is from some WD-40 sprayed to deal with a noise that started before the spring problem.
    gotoman1969 likes this.
