Toytec Boss 2.0 vs 2.5
Discussion in 'Suspension' started by Ashgh, Feb 2, 2022.
  1. Feb 2, 2022 at 7:24 PM
    Ashgh
    Ashgh [OP] Well-Known Member
    Ashkan
    2021 Tacoma TRD Off-road
    Looking at getting boss 2.0 or 2.5. Shop was recommending 2.0 and saying the 2.5 are comparable to king or fox. Any insight on this? comparisons between the two from people who have them?
  2. Feb 3, 2022 at 9:13 AM
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    El Cajon, CA
    No personal experience with those Toytec, but one main difference with the 2.5 is they have an aluminum shock body. That will be nice for corrosion resistance. Looks like they also come with a 700lb spring vs a 600lb spring (King). 2.0 looks like its an IFP shock, and 2.5 come in either IFP or remote reservoir.
    Hopefully others can chime in with experience on both options.
    Curious, why did the shop recommend the 2.0?
    Ashgh[OP] likes this.
  3. Feb 3, 2022 at 10:40 AM
    Ashgh
    Ashkan
    I believe they quoted with the 2.0 because they were saying it was more in my budget.
  4. Feb 3, 2022 at 10:42 AM
    Ashgh
    Ashkan
    Any insight as to whether this is a reasonable quote?
  5. Feb 3, 2022 at 3:03 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    I was gonna get the 2.0 but the fact they come with a 700lb imo makes them too stiff if you don’t have any weight up front especially if you preload them for lift.
  6. Feb 3, 2022 at 3:13 PM
    AccuTune Offroad
    El Cajon, CA
    Not sure what you mean by reasonable. We don't sell those parts.
    labor seems a little high and same with alignment, but then again you did want the SPC arms.
  7. Feb 3, 2022 at 3:19 PM
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    The price for a full lift installed is about right. I just put in a full Dobinsons set up for about that. I believe I read the Toytech are the same as another manufacturer rebranded, cannot remember who it was.
    I agree with the fox or I am loving the Dobinson. If you are getting a 700 pound spring your front needs some extra weight or you will ride stiff :rofl:
  8. Feb 3, 2022 at 3:55 PM
    gotoman1969
    I agree. That labor is high. 4hrs tops.
  9. Feb 3, 2022 at 4:00 PM
    AccuTune Offroad
    El Cajon, CA
    I meant the hourly rate. For our stage kits (similar in product), we charge 7 hours, $150/hr, but that includes setting ride height as well. IFP shocks should be very simple to install
    71tattooguy likes this.
  10. Feb 3, 2022 at 4:05 PM
    dangles
    dangles Active Member
    2016 Tacoma TRD Sport, DCLB
    Toytec Aluma Series Boss Suspension (2") with add-a-leaf SPC Adjustable UCAs Raceline 935g Defender 17" wheels (0 offset) Toyo Open Country ATIII (LT285/70R17) CMC KDMax ECU tune Hood struts (DO THIS!) Rear diff breather
    This is what one of the Toytec guys recommended for me...
    I'd suggest giving them a call. They're extremely helpful.
    As for the labor, mine needed a CMC. Total labor (including CMC) was $2400. I think that was a bit much... :oops:
    *edit*
    That labor cost included mounting/balancing the new tires/wheels as well, though.
  11. Feb 3, 2022 at 4:05 PM
    Ashgh
    Ashkan
    I have about 100lbs in the front is that not enough?
  12. Feb 3, 2022 at 4:07 PM
    Ashgh
    Ashkan
    I’ll give them a call. Thanks for the heads up.
  13. Feb 3, 2022 at 4:08 PM
    Ashgh
    Ashkan
    Would 100lbs in the front still be too stiff?
  14. Feb 3, 2022 at 4:11 PM
    Ashgh
    Ashkan
    I found another shop in my area who quoted me $890 for labor with alignment which seems a lot better. Are the SPC UCA harder to dial in with alignment?
  15. Feb 3, 2022 at 4:15 PM
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    the SPC arms are at full retail not their map pricing which is $695.95
  16. Feb 3, 2022 at 4:17 PM
    Ashgh
    Ashkan
    I did contact them about that and they adjusted it
  17. Feb 4, 2022 at 11:42 AM
    Saskabush
    Saskabush Well-Known Member
    Adam
    Saskatchewan, Canada
    2013 TRD Sport
    Elka 2.5" DSC w/ Deaver Stage 1, Archive Hammer Hangers, SPC UCAs, Timbren bumps, 16" TRD baja wheels, 265/75r16 BFG K02, 1.25" wheel spacers, TRD skid plate, N-Fab spare tire box mount.
    The Toytec Boss line is made by Elka. Elka is comparable to King and Fox.
  18. Feb 4, 2022 at 2:56 PM
    Vst
    Vst IG:@vehiclesupportedtravel
    Scott
    Kodak, TN
    18’ Access cab TRD OFRD 4x4
    My brother has the 2.5 non reservoir ones and I don’t know if they are valved progressively maybe but even with a 700lb springs his ride soft and he doesn’t have any weight up front. I can tell you my falcon shocks ride way harsher than his
    jachal likes this.
  19. Feb 5, 2022 at 5:13 PM
    Luke_77
    Luke_77 New Member
    I have the 2.5 with reservoir up front and 2.5 with no reservoir in the rear with 3 leaf add a leaf. They are made by Elka with Toytec branding. The front rides very good the rear is the week link on the Tacoma but not because of the shocks. Everything is well made and has good quality anodizing.
    I have noticed if I drive the truck hard that there is a noticeable deference in terms of shock temperatures between front and rear.
    jachal likes this.
  20. Feb 7, 2022 at 5:29 PM
    RebleAZ
    RebleAZ Well-Known Member
    Troy
    AZ
    2020 Cement TRD Off Road
    Fox Performance Elite, RRW -25 RR7H, 295/70/17 Yokohama Geo MT. Alcan Leafs. Much more...
    Elka makes Toytec
    Mastiffsrule[QUOTED] likes this.
