Toyota's Direct and Port injection explained
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kamille.bidan, Feb 14, 2019.
  1. Feb 14, 2019 at 8:07 AM
    Kamille.bidan
    Kamille.bidan [OP] Well-Known Member
    2017 Blue TRD OR MT
    I didn't realize they used the Port and Direction to also affect torque.
    More than a few members of this board have claimed that DI doesn't cause carbon deposits, and that DI was basically flawless on it's own. They also said that any attempt to clean EGR or recycled air with a catch-can was dumb because there is no issue to begin with.
    Funny how the engineers that this guy talked to try suppress the carbon deposit issue.
    However, I remember a video where Mike Sweers openly boasted about Port/DI Toyota's self cleaning mode.
    Maybe the folks at Toyota aren't so bad?
    https://www.youtube.com/watch?v=66C4YIiwRbM
    Here is Mike referring the the Tacoma's self-cleaning feature.
    https://youtu.be/bd4Xj5nhjpQ?t=83
  2. Feb 14, 2019 at 8:29 AM
    Gerard6778
    Gerard6778 Well-Known Member
    Gerard
    2015 TRD Sport
    BMW started using direct injection many years ago and has had problems with carbon deposits on the intake valves, so have many other manufacturers. Having an injector in the intake port is a great remedy, today many manufacturers do this.
  3. Feb 14, 2019 at 9:06 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    The older Lexus IS 250 v6 was also just DI. they also had huge problems with carbon build-up. The 06 to 09 had recall, to have engines torn down and rebuilt (upper half) due to carbon build-up. I had an 06, they replaced engine, because it was so bad.
  4. Feb 14, 2019 at 9:37 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    So basically what you are telling us is that you didn't know the basics before, but you do now. Congratulations. Try reading tech articles next time (from reputable sources) instead of watching youtube all day long. You will be smarter for it.
    shakerhood and Hank Heel like this.
  5. Feb 14, 2019 at 10:33 AM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    I don’t recall anyone saying that DI doesn’t form carbon deposits.
    Fords ecoboost was having carbon issues so they copied Toyota and added port injection to their motors.
  6. Feb 20, 2019 at 7:28 AM
    dbyker
    dbyker Well-Known Member
    Dave
    NE TN USA
    2018 Tacoma TRD Sport Access Cab V6 6MT 4x4 Inferno Red
    VF Tune, TRD Intake, TRD Cat-Back.
    Mike Sweer's video above states that port injection cleans direct injectors in cylinders.
    Top Tier fuel should help keep direct injectors in cylinders clean.
    The problem with DI is VALVE deposits, which Top Tier fuel can't touch, which the video does NOT address.
  7. Feb 20, 2019 at 10:58 AM
    Herniator
    Edmonton
    The port injectors will still help with valve deposits.
    shakerhood likes this.
