Toyota ticking sound normal?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Collinmcd99, Apr 4, 2018.
  1. Apr 4, 2018 at 12:39 PM
    Collinmcd99
    Collinmcd99 [OP] Well-Known Member
    Collin
    Southern California
    2015 gray Tacoma TRD off road
    I have A 2015 Toyota Tacoma V6 with 15,000 miles on it and for the longest time I’ve had a ticking sound coming from my engine bay it bugs the crap out of me and i want to know why it ticks. I’ve had people tell me that it is normal for Tacoma’s to have a ticking sound coming from there engin bay. If anyone can give me some insight on why it does this and what i can Do to make it stop it would be greatly appreciated, thanks.
  2. Apr 4, 2018 at 12:51 PM
    badger
    badger Well-Known Member
    07 SR5
    Normal. You can turn the key to "off" to stop it.
  3. Apr 4, 2018 at 12:54 PM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Normal.
    Not driving your truck will stop the ticking.
  4. Apr 4, 2018 at 1:06 PM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    The clock ticking and tapping noise is normal. Keep the oil topped off as the engine burns off that 0.5 to 1 quart during the normal the 5000/7500 mi interval- and that will keep the engine as quiet and muffled as possible.
    There also is a pinging noise under certain load and warm temperature conditions, when running low quality 87 octane fuel with 10% ethanol (For my Tacoma I avoid using Sheetz and Wawa and QuickCheck fuels on the upper east coast, as well as stations that buy old fuel while adding water for re-sale at a 0.10 cent discount). The fuel injectors have been said to be noisy as well, at cold temperatures.
    BassAckwards and Collinmcd99[OP] like this.
  5. Apr 4, 2018 at 1:07 PM
    Hopesfall
    Hopesfall Active Member
    Travis
    Keizer, OR
    2011 DCSB PreRunner
    The sound is coming from the vacuum switching valve, and the valve is connected to the intake manifold by one bolt. The valve is making the noise but it gets amplified by the plastic against the bolt. Apparently you can remove the cover and access the bolt, and find some rubber washers or o-rings to put on the bolt to reduce the noise considerably, if not completely. Source: my friend has an FJ and this is what he told me.
    DISCLAIMER: I'm not telling you to do this, and I don't know if it affects any warranty or anything in any way. I haven't done it mostly because I'm lazy and I don't mind having my radio slightly louder to drown it out.
    Collinmcd99[OP] likes this.
  6. Apr 4, 2018 at 1:10 PM
    Collinmcd99
    Collin
    Southern California
    I did just have an oil change but did not put synthetic because i change My oil every 4 to 5 thousand miles. Would you recommend using synthetic?
  7. Apr 4, 2018 at 1:11 PM
    BajaTom
    BajaTom Well-Known Member
    Tom
    Utahhhh
    2015 Tacoma TRD OR DCSB 4 door
    OME 2.5 886 Dakkar suspension, ARE shell, with Thule bars and cargo rack,
    My 09 did it and I was concerned it was a lifter or something else critical. I got my 2015 @ one year old with 20K miles and it did it. I soon discovered here that it is a normal sound.
  8. Apr 4, 2018 at 1:19 PM
    TacomaMike37
    13' DCLB MGM
  9. Apr 4, 2018 at 1:21 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    what he said.
    I put some rubber washers on this valve and it quieted things up a smidge but not completely gone.
  10. Apr 4, 2018 at 1:36 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Evap purge cycle, normal..
  11. Apr 4, 2018 at 1:39 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    What ticking? :notsure:
    :rofl:
    Lester Lugnut likes this.
  12. Apr 4, 2018 at 1:51 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    That’s just as common as rust.
  13. Apr 4, 2018 at 3:10 PM
    mbrogz3000
    Northern NJ
    Yes, I’d recommend synthetic oil if you want flexibility in when to change the oil beyond the 5000 mi interval. I have exclusively used synthetic oil on 4-5 different cars since 2004. That said, if you have time to immediately change the oil exactly at 5000 miles when the maintenance comes on, then regular 5w30 is fine to use.
  14. Feb 23, 2020 at 5:14 AM
    windy ridge kennels
    windy ridge kennels Active Member
    david
    07 tacoma 2.7 access cab
    Normal,why would this be normal
  15. Feb 23, 2020 at 5:46 AM
    Larueminati
    Larueminati Well-Known Member
    Western MA.
    2013 DCSB TRD 0FF-ROAD
    I think it sounds and runs better using 93 fuel, I’ve ran it pretty much the life of mine and i’m at 111k miles.
  16. Feb 23, 2020 at 6:56 AM
    windy ridge kennels
    david
    I had 22r 22re 2.7 never heard them. These 4.0 are held in such high regard and I can’t understand why a motor that sounds like a sewing machine is normal?
  17. Feb 23, 2020 at 7:57 AM
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    in California that pinging under load is pretty standard with our gas. Using our premium (91) helps minimize it.
    DukeE likes this.
  18. Feb 23, 2020 at 8:16 AM
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    Because almost every one of the 4.0 engines make that sound, and they've lasted for hundreds of thousands of miles. It's a vacuum valve located on the driver's side of the engine. It's noisey . It's it the engine itself.
  19. Feb 25, 2020 at 4:07 AM
    Ottawa river taco
    Ottawa river taco Well-Known Member
    Tim
    Westmeath
    09 dclb sport barcelona red
    Bought it with 3" lift and xd rims wrangler tires
    The Toyota tick. Everyone I ever owned. 92 4banger, 86 v6, 03 dblcab, 01 rav4 and '13 rav4. They all ticked. Annoying but harmless.
