Toyota Super Long Life Antifreeze/Coolant
Discussion in 'Technical Chat' started by Hanz, Aug 19, 2011.
  1. Aug 19, 2011 at 11:33 AM
    Hanz
    Hanz [OP] Well-Known Member
    Doug
    Long Island, NY
    2003 Tacoma DC 4X4 TRD
    LED Instrument lights
    One Gallon Pre-Mixed PINK Colored
    Toyota Part Number
    00272-SLLC2
    Here's what the container looks like:
    Front
    Back
    Part Number Close Up
    Don't dilute it - use it full strength.
    This is the Pink Fluid - Toyota also has a Red Fluid.
    I hadn't seen it before so I figured I'd snap some photos to share :cool:
    GQ7227 and Biscuits like this.
  2. Aug 19, 2011 at 11:49 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Does the 2nd gen use the pink and what's the difference between the pink and red?
  3. Aug 19, 2011 at 11:56 AM
    Hanz
    Doug
    Long Island, NY
    My Second Gen is a 2008 4.0L and uses the Pink fluid. I know Toyota makes a Red colored coolant but I don't know what the difference is or what vehicles use it.
    GQ7227 likes this.
  4. Aug 19, 2011 at 12:00 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    2nd Gen uses pink. At least for the 4.0L's they do.
  5. Aug 19, 2011 at 12:03 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    It's not limited to second gens. Pink has been used since in all Toyotas since 2000 IIRC.
    The red is not diluted, pink is already pre diluted to 50/50.
  6. Aug 19, 2011 at 8:22 PM
    Night
    Night Well-Known Member
    Canada
    '11 TRD OR AC MagGrey
    Banks Monster Exhaust, aFe ProGuard 7, 3M Film, UnderCoating, alpine 920 headunit, alpine 6.5 components, 20% tint all around, JL Stealthbox, PDX-V9 Amp, Avid Lightbar, Avid Sliders, Full Metal JackRabbit Tonneau, TRD S/C
    So what happens after -34 because its colder than that in canada eh.
    GQ7227 likes this.
  7. Aug 19, 2011 at 8:35 PM
    samer312
    samer312 Well-Known Member
    Sam
    Alexandria VA
    2020 Cement TRD OR
    how often are you suppose to change it? I have seen 100,000. Are you planing to flush or simply change?
  8. Aug 19, 2011 at 8:49 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    According to the US booklet, 10 years / 100,000 mi.
    According to the Canadian booklet, initially at the equivalent of 8 years / 80,000 mi, then every 4 years / 40,000 mi.
    Makes you wonder, doesn't it?
  9. Aug 19, 2011 at 10:10 PM
    Hanz
    Doug
    Long Island, NY
    It Freezes eh. You get to use a block heater.
    Simple drain and refill. My truck has 30K on it. I don't expect to see anything out of the ordinary in the catch basin.
    It does make you wonder. I'm just going to stick to a maintenance routine that has served me well with multiple Jeeps. If it's good for a Jeep it should be a breeze for my Toyota.
  10. Aug 19, 2011 at 10:15 PM
    THE TECHNICIAN
    THE TECHNICIAN Well-Known Member
    You're wasting your money. It will do 100K no problem.
  11. Aug 19, 2011 at 10:35 PM
    Hanz
    Doug
    Long Island, NY
    It took me 3 years to get to 30K. No way am I leaving the same coolant in my truck for 10 years.
    I've wasted money on worse things. :cool:
  12. Aug 20, 2011 at 4:54 PM
    KenLyns
    Belly of the Beast
    Buy the undiluted coolant and do a 70/30 mix with water. That will lower the freezing point to -90F/-68C.
    I hope you are using a good 0W20 or 0W30 oil at those temps. :)
    It's the next 100K you should be worried about. :) Toyota has an incentive to skimp on maintenance to 1) look good in the JDPower studies and 2) reduce costs on its free maintenance program. The harmful effects won't appear until after the powertrain warranty expires.
    The recurring 4 years / 40,000 mi interval in the Canadian booklet is a good guideline.
  13. Jul 5, 2018 at 10:00 AM
    irhunter
    irhunter Well-Known Member
    Maine
    '96 2WD 5-sp 2.4 Tacoma and '03 4WD AT 4.7 Tundra
    My owners manual says: "Toyota super long life coolant." I can not find a P/N for the red version...only the 50/50, pink. Anyone got a P/N for me?
    Roy
  14. Jul 5, 2018 at 10:05 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    why u need a P/N number? just ask for the Toyota long life concentrated coolant
    GQ7227 likes this.
  15. Jul 5, 2018 at 11:02 AM
    irhunter
    Maine
    OK, here is what Olathe Toyota tells me.
    Pink super long life (for, say, a '07 Taco) is not available as a non-diluted product. Red long life is available (as spec'ed for my '03 Tundra). They say, the Toyota line is, red plus distilled water is not recommended in motors which spec pink super long life.
    I'd still like the p/n for super long life, non-diluted...but, it might not exist.
    Roy
  16. Jul 5, 2018 at 11:12 AM
    Gorillazrus
    Gorillazrus To be continued...
    01 Prerunner SR5
    5100 Bilistens set @ 1" in front, Wheelers 5 leaf in rear, Leer Topper, TRD Skid Plate, Dual Band Ham Radio
    HandOfGod and irhunter like this.
  17. Jul 5, 2018 at 11:57 AM
    irhunter
    Maine
    Thanks.
  18. Oct 22, 2020 at 12:24 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    that is brutal COLD!!
