Toyota spec. list IMPORTANT
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BadKitty, Jul 27, 2020.
  1. Jul 27, 2020 at 3:25 PM
    BadKitty
    BadKitty [OP] Well-Known Member
    Indianapolis
    2017 Black Tacoma TRD-offRoad 6spd
    TRD Intake, TRD exhaust
    Useful content: the thread
    (please correct or add to this as necessary, and ALWAYS double check if you arent sure!)
    (This is an ongoing work I have compiled from any and all sources Either direct from Toyota™ or otherwise)
    Nut & Bolt Sizes
    -Front Top Hat Nut: M10x1.25 (Qty.6)
    -Front Lower Strut Bolt&nut: M14x1.5x76 (qty 2)
    -Rear strut top Nut size: M10x1.5 (Qty.2
    -Rear lower strut bolt: M12x1.25x70
    -Rear Shackle bolt: M14x1.5 x 100mm long.
    -Front recovery hook: 12 x 1.25 x 60 mm grade 8.8 #90119-A0193
    -M12-1.25 (1.75)
    -front sway link m12
    -license plate bolt/washer M6x1x20mm
    -alignment cam m16
    Toyota Part#:
    Strut bolt assembly
    -90105-A0113: bolt
    -90178-A0058: nut
    -91622-41400: washer
    Suspension/Control Arm/Alignment Cam
    -Upper Control Arm Nut 90080-17208 x2
    -Outer Tie Rod 45046-09340 x2
    -CV Dust Cap, Grease Cap 43514-28010 x2
    -Adjust Cam, RIGHT 48409-60020 x2
    -Adjust Cam, LEFT 48190-60020 x2
    -Adjust Cam, LEFT 48198-60011 x2
    -Bolt W Washer 90119-A0166 x2
    -Control Arm Nut 90178-A0001 x2
    -Front Strut Lower Bolt, Bolt Flange 90105-A0113 x2
    -Front Strut Lower Nut, Gear Assembly Nut 90178-A0058 x2
    TORQUE SPECS
    Engine:
    Throttle body mounting nuts/studs: 13 ft-lbs
    Spark plug: 14 ft-lbs (2RZ/3RZ), 13 ft-lbs (5VZ)
    Oil drain plug: 27 ft-lbs
    Engine mount to frame: 28 ft-lbs
    Engine mount to block: 38 ft-lbs (2RZ/3RZ), 32 ft-lbs (5VZ)
    Head bolts: 29 ft-lbs + additional 90° + another 90° (2RZ/3RZ)
    Head bolts: 25 ft-lbs + additional 90° + another 90° , recessed 13 ft-lbs (5VZ)
    Main bearing caps: 29 ft-lbs + additional 90°(2RZ/3RZ), 45 ft-lbs + additional 90° (5VZ)
    Exhaust manifold: 36 ft-lbs (2RZ/3RZ), 30 ft-lbs (5VZ)
    Intake manifold: 22 ft-lbs (2RZ/3RZ), 13 ft-lbs (5VZ)
    Air Intake Chamber: 15 ft-lbs (2RZ/3RZ), 13 ft-lbs (5VZ)
    Crankshaft pulley bolt: 193 ft-lbs (2RZ/3RZ), 217 ft-lbs (5VZ)
    Oil pan bolts: 9 ft-lbs
    Rear main oil seal: 9.7 ft-lbs
    Rear end plate: 14 ft-lbs
    Starter mounting bolts: 29 ft-lbs
    Pressure plate to flywheel: 14 ft-lbs
    Flywheel to crankshaft bolts: 65 ft-lbs (2RZ), 19 ft-lbs + additional 90° (3RZ), 63 ft-lbs (5VZ) ~USE LOCTITE~
    Flexplate to crankshaft bolts: 54 ft-lbs (2RZ/3RZ), 61 ft-lbs (5VZ)
    FRONT:
    Brake caliper mounting bolts: 90 ft-lbs
    Brake caliper banjo bolt: 22 ft-lbs
    Steering knuckle to lower ball joint: 59 ft-lbs ~USE LOCTITE~
    Outer tie-rod to lower ball joint: 67 ft-lbs
    Lower control arm to frame (alignment cams): 96 ft-lbs
    Lower control arm to shock absorber: 101 ft-lbs (may vary with aftermarket equip)
    Lower control arm to swaybar end link: 51 ft-lbs
    Lower ball joint to lower control arm: 112 ft-lbs
    Upper ball joint to upper control arm: 80 ft-lbs
    Upper control arm to frame: 87 ft-lbs
    Shock absorber upper mount (3 bolts): 47 ft-lbs (may vary with aftermarket equip)
    Shock absorber center nut: 22 ft-lbs
    Swaybar to swaybar end link: 22 ft-lbs
    Swaybar brackets to frame: 19 ft-lbs
    Differential front mount to frame: 101 ft-lbs
    Differential rear mount to frame: 64 ft-lbs
    Ring gear bolts: 71 ft-lbs
    Differential drain plug: 48 ft-lbs
    Differential fill plug: 29 ft-lbs
    Axle shaft hub nut (ADD): 174 ft-lbs
    Free wheel hub inner lock nut (manual hubs): 203 ft-lbs
    Axle shaft inner hub safety bolt (manual hubs): 13 ft-lbs
    Hub body to axle hub (manual hubs): 23 ft-lbs
    Hub body cover (manual hubs): 7 ft-lbs
    REAR:
    Backing plate to axle housing: 50 ft-lbs
    Shock absorber to axle: 53 ft-lbs
    Shock absorber to frame: 53 ft-lbs
    Axle u-bolts: 90 ft-lbs
    Front leaf spring mount: 115 ft-lbs
    Shackle bolts (both): 67 ft-lbs (may vary with aftermarket equip)
    Leaf spring centering pin: 33 ft-lbs
    3rd member to axle housing: 18 ft-lbs
    (with e-locker), 54 ft-lbs (w/o e-locker)
    Ring gear bolts: 71 ft-lbs (with e-locker), 92 ft-lbs (w/o e-locker)
    Carrier bearing caps: 83 ft-lbs (w/o e-locker)
    E-locker acutuator to 3rd member: 20 ft-lbs
    Differential drain & fill plugs: 36 ft-lbs
    Torque specs are 74 lb ft for bottom bolt and 15 lb ft for top nut.
    STEERING:
    Steering wheel set nut: 26 ft-lbs
    Inner tie-rod to rack: 76 ft-lbs
    Tie-rod end lock nut: 41 ft-lbs
    Steering rack mounting clamp: 123 ft-lbs
    Steering rack vertical center mounting bolt: 123 ft-lbs
    Steering rack horizontal mounting bolt: 141 ft-lbs
    Miscellaneous:
    Seat mounting bolts to body: 27 ft-lbs
    Seat belt: 30 ft-lbs (all mounting points)
    Body mounting bolts: 48 ft-lbs
    Conversion Factors:
    1 ft-lb = 12 in-lb = 1.35582 Nm
    TRD Air Filter: Part Number PTR0334140:
    TRD Air Filter Clean Kit: Part Number: PTR4300088:
    TRD Oil Filter: Part Number PTR43-00082 (cartridge style for 16+):
    TRD Skid Plate: PTR6035190:
    TRD Oil Cap: PTR041210802:
    TRD Radiator Cap: Part Number PTR040000003:
    TRD Floor Mat (carpet): PT206-35089-02:
    3rd Gen TRD Off-Road:
    Factory Wheels
    Wheel: 16x7
    Offset: +25
    Backspace:
    weight: 25lbs
    Tire: Goodyear Adventure Kevlar
    weight: 42lbs
    Engine OIL
    Engine oil (0W-20 ILSAC GF-5 oil - Toyota part # 00279-0WQTE-01)
    1) Check w/ engine warm greater than 5 minutes after shutting off engine
    2) Tip: leave dipstick out while waiting 5 minutes to allow oil in dipstick to drain back down, makes it easier to read
    3) Per manual, it’s 1.6 qts from low mark to full mark, don’t overfill
    Coolant (Toyota SLLC - Toyota part # 00272-SLLC2, 50/50 pre-diluted, Canada is 55/45)
    1) Between LOW and FULL lines with engine cold
    Brake fluid (FMVSS No. 116 DOT 3 or SAE J1703)
    1) Between MIN and MAX (should be near or at max with fresh pads)
    Power steering fluid (Automatic transmission fluid DEXRON® II or III)
    1) Between min and max (cold and hot lines provided)
    2) Cold - not driven in last 5 hours (50-85 degF fluid temp)
    3) Hot - driven 50 mph for 20 mins (140-175 degF fluid temp)
    Clutch fluid (FMVSS No. 116 DOT 3 or SAE J1703)
    Rotate tires - every 5k or 6 mo
    Front to back/back to front on each side
    Lug nut torque - 83 lb-ft (21mm)
    Check torque ~1000 miles after rotating
    Replace engine oil and filter - every 10k or 12 mo (severe: 5k or 6 mo)
    Torque specs:
    Oil pan drain plug - 30 lb-ft (14mm)
    Oil filter cap - 216 lb-in/18 lb-ft (TOY640 with 15/16" or 24mm socket)
    Oil filter drain plug - 120 lb-in/10 lb-ft (3/8" square drive)
    No. 1 engine under cover sub-assembly - 22 lb-ft (12mm)
    No. 2 engine under cover sub-assembly (off-roads) - 22 lb-ft (12mm)
    Parts:
    Oil - 6.1-6.2 qts 0W-20 ILSAC GF-5 oil - Toyota part # 00279-0WQTE-01
    Oil pan drain plug gasket - Toyota part # 90430-12031
    Oil filter element kit - Toyota part # 04152-YZZA1
    Special tools:
    $18 Assenmacher Specialty Tools TOY 640 Oil Filter Socket Wrench for Toyota/Lexus
    AST TOY640 filter wrench (or Toyota SST 09228-06501)
    5/8” ID tubing (for oil filter drain pipe)
    Tips:
    1) Requires removing skid(s) for access.
    2) Oil filter has permanent housing, oil filter element kit includes new filter cartridge, 2 new gaskets, and the temporary oil filter drain pipe.
    3) Hose for oil filter drain pipe (if used) should be 5/8” ID (15 mm). About $1 at Lowe’s in the plumbing section for clear vinyl tubing. Can help with splashing.
    4) Proper torque of the oil filter cap and oil filter drain plug should help prevent the cap coming off before the drain plug on the next change, which can be a lot cleaner.
    5) When you remove the filter drain plug, give it a little impact. If you're too smooth, the plug and housing will try and move together.
    6) https://www.tacomaworld.com/threads/oil-change-checklist-service-record.462476/ by @RichVT
    Re-torque propeller shaft bolts - every 15k or 18 mo (severe: 5k or 6 mo)
    DIFF GEAR OIL
    Toyota Genuine Differential gear oil LT 75W-85 GL-5 or equivalent - Toyota part # 08885-02506
    Front - 1.6 qts; Rear - 3.1-4.2 qts (varies with model)
    Rear drain plug gasket - Toyota part # 12157-10010
    Rear fill plug gasket - Toyota part # 12157-10010
    Front drain plug gasket - Toyota part # 90430-24003
    Front fill plug gasket - Toyota part # 12157-10010
    Manual transmission oil - inspect every 30k or 36 mo (severe: replace every 30k or 36 mo)
    Torque specs:
    Drain plug - 27 lb-ft (24mm or 15/16")
    Fill plug - 27 lb-ft (24mm or 15/16")
    Parts:
    Toyota Genuine Manual Transmission Gear Oil GL-3 (GL-4) or equivalent, SAE 75W-90
    4 cyl - 2.3 qts, 6 cyl - 2.6 qts
    Drain plug gasket - Toyota part # ??
    Fill plug gasket - Toyota part # ??
    Factory Alignment
    FWIW, factory spec is;
    +2.2 caster
    +0.5 camber
    +0.05 toe
  2. Jul 27, 2020 at 3:51 PM
    Linkbelt
    Linkbelt Active Member
    Robert
    2020 white double cab sport
    Nice write up.
    t0nyvalenzuela likes this.
  3. Jul 27, 2020 at 3:55 PM
    slowlane
    slowlane Well-Known Member
    AZ
    16 double cab MGM
    Liked and bookmarked. Great job OP!
  4. Jul 27, 2020 at 4:16 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
  5. Jul 27, 2020 at 4:56 PM
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
    Looks like a lot of the same information thats in the maintenance sticky?
    pltommyo, MOC221_ and DWD484 like this.
  6. Jul 27, 2020 at 5:31 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    I thought it might be helpful to put the Tacoma Product Information pdf files here for the years 2016, 2017, 2018, 2019 & 2020. These files include extensive details on power train, exterior features, interior features, what's standard across the trim levels, and the various Packages and Options available for each year.
    Hopefully the attached pdf files will be a useful reference for 3rd gen owners or those looking to buy a new or used Tacoma.
    NOTE: 2018 specs lists a 4-cylinder manual transmission, that never happened, 4-cylinder manual was discontinued for 2018, 2017 was the last year for the I4 manuals.
    Space Ghost Coma, Grindstone and daks like this.
  7. Jul 27, 2020 at 5:42 PM
    Tacospike
    Two Trucks
    Subbing
  8. Jul 27, 2020 at 6:00 PM
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    Sub a dub dub
  9. Jul 27, 2020 at 6:03 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
  10. Jul 27, 2020 at 6:15 PM
    davidstacoma
    David
    NC
    And of course no Master List would be complete without a link to the 3rd Gen Tacoma Service Manual (2016, I think the last year they published in document form), courtesy @tonered :
    2016 Tacoma Service Manual Availability PDF
    It's a huge file, so download might take a while.
    jmauvais and BangosTaco like this.
  11. Jul 27, 2020 at 6:38 PM
    t0nyvalenzuela
    t0nyvalenzuela Well-Known Member
    2019 Tacoma TRD OR DCLB
    Puck level
    What’s the TL/DR.
  12. Jul 27, 2020 at 6:49 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Too Long/ Didn't Read version.
  13. Jul 27, 2020 at 6:57 PM
    t0nyvalenzuela
    Puck level
    Haha! I was being a smart ass ASKING for the tldr version.
  14. Jul 27, 2020 at 7:28 PM
    aggr0crag
    aggr0crag Well-Known Member
    19 DCSB 4x4 Sport M/T
  15. Jul 27, 2020 at 7:31 PM
    Saeros
    Saeros #dealermole
    Canada, Eh!
    2022 Venza Limited
    Maybea you could add the Canadian part numbers for the following...
    Toyota Super Long Life coolant 55/45: C0009-00120
    0W20:
    1L C0BBA-0W2SN-1L
    5Qt: C0BBA-0W2SN-1J
    davidstacoma likes this.
  16. Jul 27, 2020 at 9:38 PM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    our trucks like to twerk and apparently they have oil in them
  17. Jul 28, 2020 at 3:36 AM
    Xer0 SiN
    Xer0 SiN Well-Known Member
    Hilo, HI
    19 TRD SPORT TACOMA / 21 LIMITED RAV4
    this and that...
    3rd gen trd or come with goodyear adventures stock? thats awesome.
  18. Aug 11, 2020 at 1:27 PM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    Should be a sticky or a link in the 3rd gen DIY maintenance section
  19. Aug 11, 2020 at 1:31 PM
    grubburg
    grubburg Well-Known Member
    2019 TRD OR MT
    K & N Intake, Gibson Catback (chopped), Weathertech floormats, 285/70/17 Ridge Grapplers, Black Rhino Glamis wheels, Kicker Key, Kicker Hideaway, Infiniti Speakers, OV Tune, 888's, 5100s X 4, HS 3-leaf, LR SPC UCAs, Diff Drop, Carrier Bearing Drop, OEM Bed Mat, Morimoto HID low beams, Morimoto LED 2 Stroke High Beams, KC 336 LED bar, KC C3 LED pods for rear, KC LED 6'' SlimLites ditch lights, N-Fab Steps, Auxbeam Interior Blue Lights, 7r41lbr34k3r Shift Knob, Wet Okole Seat Covers, Diode Dynamics SAE Pro Fogs, Cali Raised ditch light brackets, hidden light bar brackets, tailgate light brackets.
    anyone have the 3rd gen Haynes manual?
  20. Aug 11, 2020 at 1:35 PM
    Dirk Diggler
    Columbus, GA
    2017 MGM OR DCSB
    I think I have the Hayes manual. Might be the Clymer not 100% it is in a box while moving. Definitely get one but had some stuff missing or not completely clear in some sections
