Toyota service cost
Discussion in '3rd Gen. Tacomas (2016-2023)' started by t'comatose, Oct 4, 2021.
  1. Oct 4, 2021 at 8:04 AM
    t'comatose
    t'comatose [OP] Member
    kevin
    2016 Tacoma TRD 2wd 6cyl
    I just took my 3rd gen in for 65,000 maintenance and it cost $1300. Is this common?
  2. Oct 4, 2021 at 8:06 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    What service work did you agree to have performed?
    supmet likes this.
  3. Oct 4, 2021 at 8:12 AM
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    Dealer pricing yes, but an independent shop would cost you half for the same work.
  4. Oct 4, 2021 at 8:13 AM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    I'm sure half of those can be done by yourself.
  5. Oct 4, 2021 at 8:18 AM
    TacoBella
    TacoBella Well-Known Member
    Tom
    2016 Tacoma (SOLD) leased RTL-E Ridgeline
    AVS Bug Deflector. TruXedo Lo Pro
    Holy mackerel
    . I just got the following things replaced on my Porsche. New spark plugs, new coils , front rotors, and brakes, rear pads flush Cooling flush, brake flush, transaxle flush, replaced Serpentine belt I
    i paid less than $2,000 for everything including labor and parts. Most of this maintenance was based on time rather than mileage.. No way should Toyota be charging that much. My car is at 28,000 miles and 10 years old.
  6. Oct 4, 2021 at 8:21 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Ouch! BOHICA baby!
    t'comatose[OP] likes this.
  7. Oct 4, 2021 at 8:23 AM
    Dank Donkeh Luvver
    Dank Donkeh Luvver Well-Known Member
    Eric
    Maryland
    2020 TRD OR White 6MT
    OVTune/Coyoza, Eibach Pro Lift, Mobtown Sliders/Skid, Softopper, Martin Offroad Rack
    My guess is something like this:
    Front brake pads + turn rotors - $450
    Rear brakes - $300
    Oil change - $75
    Trans Flush - $150
    Cabin Air filter - $100
    Intake filter - $75
    Other random crap/tax - $150
    Taco_Coma and t'comatose[OP] like this.
  8. Oct 4, 2021 at 8:24 AM
    t'comatose
    kevin
    The main services: spark plug replacement, rear differential fluid replacement, air condition filter replacement, oil and filter change, some bolt tightening, etc. it’s all listed in maintenance book.
  9. Oct 4, 2021 at 8:24 AM
    oldtimertoyota
    oldtimertoyota Well-Known Member
    New Mexico
    2009 4X4 Double Cab-1986 2wd Pickup Orig own
    That seems like a lot!
  10. Oct 4, 2021 at 8:25 AM
    t'comatose
    kevin
    Caveat: i’m in san francisco, so services cost more for everything.
  11. Oct 4, 2021 at 8:26 AM
    t'comatose
    kevin
    Should i get an itemized charge list?
  12. Oct 4, 2021 at 8:26 AM
    yoopersteeze
    yoopersteeze Fake it til you make it
    WI
    2017 Magnetic Gray Metallic Tacoma TRD OR MT
    Yikes. Depending on what you had done (assuming the stealership actually did things) those could add up at their prices. Did they get you with the $80 wiper replacement?
  13. Oct 4, 2021 at 8:27 AM
    yoopersteeze
    WI
    Yes. I think they took advantage of you personally.
  14. Oct 4, 2021 at 8:28 AM
    yoopersteeze
    WI
    My local dealer (WI) quoted me $365 for their "4x4" maintenance. Doing it yourself would be maybe $100 on the high side.
    Vlady likes this.
  15. Oct 4, 2021 at 8:29 AM
    yoopersteeze
    WI
  16. Oct 4, 2021 at 8:29 AM
    t'comatose
    kevin
    i live in an apt and have no tools, little experience. I like doing things myself, but a vehicle seems risky.
    tacoman45 and Skydvrr like this.
  17. Oct 4, 2021 at 8:30 AM
    lamjam
    lamjam Well-Known Member
    Los Angeles
    2021 TRD Off road 4x4
    When I lived in SF, I would always do all my errands in the east when where I worked so I saved myself from the SF price hike
  18. Oct 4, 2021 at 8:31 AM
    yoopersteeze
    WI
    Everyone has to start somewhere and I understand where you are coming from. You can start off slow and do the things you are actually in control of that take 0 tools.
    Engine Air Filter
    Cabin Air Filter
    Wiper blades
    Good luck!
  19. Oct 4, 2021 at 8:31 AM
    t'comatose
    kevin
    No. No wiper replacement, but they do list windshield washer solvent (?!).
  20. Oct 4, 2021 at 8:32 AM
    Knute
    There is about 4 hours labor in there based on typical labor schedules. Many dealer standard labor rate is about $150/hour.. Meaning roughly half of your invoice is labor. Oil/filter change is about $50 for materials, Diff fluid about $30/quart, plugs about $10/each (likely more depending on plug type).
    As far as dealer service price.....seems about normal.
    Ironically, YOU could do all this service for less than $150 and an afternoon of your time.
    BTW: Yes, you should get an detailed itemized invoice of the parts used and labor hours with labor rate.
    t'comatose[OP] and yoopersteeze like this.
