toyota paint ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by bsb120, Feb 3, 2013.
  1. Feb 3, 2013 at 6:18 AM
    bsb120
    bsb120 [OP] Well-Known Member
    Bradley
    Easley, South Carolina
    2016 DCLB TRD SPORT
    i have a couple of places that are bad on my paint one at each corner where the toolbox rubbed, and also one at the top corner of the tailgate( dont know how but it was like that when i bought it), does my local toyota dealer sale touch up paint? if not where can i get it to match the paint perfectly
  2. Feb 3, 2013 at 6:48 AM
    Madjik_Man
    Colorado Front Range
    Yes, the dealers sell touch up paint. Your color code is on the driver's side door jamb information panel. It'll look something like: 3K4
    And yes, there are places online that sell touch up paint and spray paint to color match as well
  3. Feb 3, 2013 at 11:09 AM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Ordering online or a place like advance auto is much more cost effective than the dealer for touch up paint. Just make sure it's the right code.
  4. Feb 3, 2013 at 1:11 PM
    bsb120
    Bradley
    2016 DCLB TRD SPORT
    ok thanks so much guys
  5. Feb 3, 2013 at 1:14 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  6. Feb 3, 2013 at 1:18 PM
    Rackster
    Rackster Well-Known Member
    Kevin
    Connecticut
    '04 E/cab 4x4 2.7 Auto SR5
    You should be able to find a local source that can mix and prep a shaker-can for doing smaller jobs. Same as with the others: get the paint code and take it to the store.
  7. Feb 3, 2013 at 2:30 PM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Colorado
    98 3.4L V6 TRD Ext. Cab 4x4 SR5
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    Except for us lucky ones with my color, they discontinued ours at dealers for some reason.
  8. Feb 3, 2013 at 3:38 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Yup - Horizon Blue Metallic was only available for two years. :(
  9. Feb 3, 2013 at 5:18 PM
    david2011sr5
    david2011sr5 Well-Known Member
    take a guess
    MA/VT
    2011 SR5 4x4
    afe pro dry, weather tech floor liners,5100's on all four corners@ 0, eibach 620 coils. toytec 3/4" spacer driver/s & passenger/s, rear spring tsb w/toytec 1" blocks, 4runner sport wheels, in channel vent visors, 1.25 spidertrax wheel spacers on the front, Wet Okole's, smity tow hook.
    Couldn't find my color anywhere (pyrite mica) for a yet to be finished satoshi project:rolleyes:... I called Dupli-color and they recommended Automotive Touch up. They were one of only two manufacturers that stocked my color.
  10. Feb 3, 2013 at 8:16 PM
    Madjik_Man
    Pretty sure they have it at my local dealer b/c a friend has the same color truck and did some touch up.
    If you want/need some, I'll check for you.
  11. Feb 4, 2013 at 6:38 AM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    I don't like that some places list my paint as the right code but wrong name. 6Q7 should be imperial jade mica, not dark green pearl. The last place I ordered I got the dark green pearl even though they said 6Q7.
  12. Feb 4, 2013 at 10:03 AM
    Rackster
    Kevin
    Connecticut
    I like that color. If you can't get through Automotive, you might want to ask one of the chain automotive store folks if they recommend a local paint supplier. Most can point you towards someone who can mix your exact code and some have the capability to put it into a shaker can for small touch-ups. Some can blend the clearcoat into the mix, but I prefer to spray that separate.
  13. Feb 4, 2013 at 10:37 AM
    david2011sr5
    take a guess
    MA/VT
    2011 SR5 4x4
    Thanks for the heads up. I ended up ordering automotive touch up. fingers crossed it will be a good Match.
    I've never heard of mixing clear coat and paint into one. Seams like it would come out hazy. No?
