Toyota OEM V6 O2 sensors versus Denso, part number discrepancy.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nixinus, Jan 11, 2019.
  1. Jan 11, 2019 at 11:32 PM
    Nixinus
    Nixinus [OP] Well-Known Member
    Oregon
    2010 4x4
    I am trying to understand why the part numbers for OEM Downstream O2 sensors are different from Toyota, 89465-04340 (left) and 89465-04350 (right). They are both O2 sensors and according to @RockAuto website, the denso OE replacement is the same for both left and right downstream O2 sensors. The fact that there are different part numbers (and significant price difference) makes me think the downstream O2 sensors are uniquely different. Anyone have insight or experience with this? My searches got me nowhere.
    I will probably do the AF sensors at the same time. I read that Denso is a good choice instead of OEM. I might go OEM if @gunny1005 can get me a good price. I don't want to start an anecdotal debate but facts/evidence always intrigues me.
    Truck: 2010 Tacoma V6 AT 4x4 Access Cab
    OEM Parts Numbers (local dealer prices):
    89467-04040 - Left - Upstream (A/F) $149.29
    89467-04050 - Right - Upstream (A/F) $149.29
    89465-04340 - Left - Downstream (O2) $116.81
    89465-04350 - Right - Downstream (O2) $130.06
    Denso Part Numbers (Rock Auto):
    234-9067 - Left - Upstream (A/F) $112.79
    234-9084 - Right - Upstream (A/F) $112.79
    234-4260 - Left/Right Downstream (O2) $47.79
  2. Jan 12, 2019 at 2:27 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    The Toyota sensors may have different part numbers because of different length harnesses side to side.
    Denso just made their harnesses the same length so they could consolidate, use the same part side to side and save money
    Sometimes it's as simple as something like that. If either company says their part will work then you can trust them
    Lester Lugnut likes this.
  3. Jan 12, 2019 at 2:47 AM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    denso makes them both so either is a good choice
    dbennett48 likes this.
  4. Jan 12, 2019 at 12:01 PM
    Nixinus
    Oregon
    2010 4x4
    That makes sense but I wouldn't expect the price difference to be $15 difference. But with OEM, the markups are insane.
    I'll try to find pictures of each to confirm. Thank you for your suggestions.
  5. Jan 12, 2019 at 12:02 PM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    I dont buy much toyota labeled parts. I get the oem supplyer for toyota. Spicer, denso, ect. It saves money for the same parts.
  6. Jan 12, 2019 at 12:22 PM
    RecklessTLS
    RecklessTLS Well-Known Member
    Rowdy
    Ft Collins, Colorado / Texas Native
    2009 Tacoma DCSB TRD Offroad 4.0
    TRD CAI and Exhaust,ECGS bushing, Blistien 6112 Fronts at 2.5, SPC upper arms, Bilstien 5160 Rear with 2in AAL, Interior light mod, Back up camera anytime Mod, Overhead Console Temp/Compass Fix. Leather Interior with heated seats, Weathertech floor liners, Ultraguage, Oil catch can, Smart Tap, More to come
    I bought those same sensors from Rock auto for my 4.0 with zero issues
  7. Jan 12, 2019 at 12:23 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    OP - I spent some time on this same issue one day and ended up dizzy. I believe it's like b_r_o said. Denso simply used one length of line to save time/money.
  8. Jan 18, 2019 at 11:01 PM
    Nixinus
    Oregon
    2010 4x4
    I went with Densos from @RockAuto for the 4 sensors and MAF. Was about half the cost of the best OEM price I could find. The A/F sensors are nearly identical. The O2 sensors have different hole designs but I'm not concerned since it's downstream of the cat. MAF is identical.
    At 85k my sensors looked bad. 1 AF sensor threads disintegrated when removing it. Truck has a lot of pep and the idle is now smooth. Not sure what helped since I also did plugs and a new air filter. Ill be doing sensors from now on at 75k if I can afford it.
    Thanks for the advice and help!
    b_r_o likes this.
