Toyota mechanic pre 1990(22r specifically)
Discussion in 'Southern California' started by Dorf510, Jul 28, 2024.
  1. Jul 28, 2024 at 7:00 AM
    Dorf510
    Dorf510 [OP] Well-Known Member
    Tyler
    Vista, CA
    18 TRD 4x4
    Dayton wires, flux-capacitor, port-a-potty
    What’s going on everyone, i am searching for a toyota mechanic that will work on the 22r carb’d engine. All the local shops say they wont touch carbs, does anyone know of any reputable shops to take my truck to? Truck is a 1986 pickup with the 22r(original carb may be the issue). Thanks for your time!IMG_4006.jpg
    Black97v6MT likes this.
  2. Jul 28, 2024 at 7:06 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I don't have any suggestions, just admiring your truck. I see you are in CA. Do you have to keep it stock to pass emissions? What is it doing that makes you think it is the carb?
    I have a '77 Celica with the 20R (pretty much the same motor), and I put a Weber on it and eliminated all the emissions crap. But I don't live in CA - I think even a '77 is required to have all original stuff there.
  3. Jul 28, 2024 at 7:11 AM
    Dorf510
    Tyler
    Vista, CA
    18 TRD 4x4
    Per the overlords of CA gov, I’m supposed to keep it stock to pass smog BUT it’s currently catless with a bunch of LCE parts. I have a smog guy so I don’t sweat the emissions stuff.Ive been on the fence on a Weber setup, found a new one locally for $250(just the carb) but I’m unsure on what else is required to run the Weber besides a pressure regulator. The intake side of things is mostly stock(always chasing vacuum leaks) so ill likely make the jump to block off all emissions and just run a Weber…..hoping to find a shop/mechanic that will take it on and get it running correct so i can focus on other projects.
  4. Jul 28, 2024 at 7:18 AM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Yeah, I started this project with the stock Aisin carb. It actually started up first crank (which shocked the crap out of me), but it ran really rich and I could never get it to lean out. It had 20 feet of vacuum lines running all over the place, must have checked those diagrams 20 times just to be sure I had it right. But yeah, lots of opportunity for vacuum leaks. I gave up and did the Cannon intake, block off plates, and Weber. The Weber was super simple to get running, but other than a pressure regulator, I don't recall anything else special that is needed.
    Dorf510[QUOTED][OP] likes this.
  5. Jul 28, 2024 at 8:00 AM
    Dorf510
    Tyler
    Vista, CA
    18 TRD 4x4
    Sounds exactly like my issue, can’t get it to lean out(smells like a race truck bc of how rich it is) no matter the adjustment, makes it stumble on idle. Ill give LCE a call tomorrow to get the right kit on order, I’ll try that before towing it to a shop.
  6. Jul 28, 2024 at 8:19 AM
    machotaco91
    machotaco91 Well-Known Member
    Mantis
    2018 Toyota Tacoma TRD Off-road
    I was having a similar issue with my 82. The way I got it to finally pass smog with very low numbers was to install a Weber 32/36 (CARB approved - thanks Gruesom Newsom) and use an AFR gauge to tune the idle jets and the main jets. Doing that I was able to tune to get AFR around 15ish and was passed CO and HC well. As for NOx… well that was a different story. I originally had a lce header with a remflex gasket and found that the gasket was actually impeding the airflow going to the egr! I ended reinstalling the original exhaust manifold with an oem gasket and it passed with flying colors.
    These jet values might or might not work for you, but here’s what I used.
    main: 140, main secondary: 145
    Air primary:160, air secondary: 170
    Idle primary: 50, idle secondary:45
    I also readjusted the float, but I didn’t write down in my notebook what I adjusted to.
    Try giving Squirrel Concepts in Long Beach, CA a call. Those guys specialize in early Yotas. They might be booked up for a while, but they’re always happy to help keep our trucks on the road!
  7. Jul 28, 2024 at 8:42 AM
    lit_taco4x4
    lit_taco4x4 IG and YT: @2a_crawlcamper
    Louie
    2018 Tacoma TRD Pro
    JD fab LT, Archive and Deavers, King shocks, Dual locked, Dual T case, Tundra steering rack, 39’s
    Try Yotamasters
    Dorf510[OP] likes this.
  8. Jul 28, 2024 at 10:46 AM
    LOLLY
    LOLLY Well-Known Member
    Alfredo
    Norwalk, CA
    '05 Tacoma DCLB TRD Sport (RIP) Now '21 TRD Off-Road
    Superdave1.0 and Dorf510[OP] like this.
  9. Jul 28, 2024 at 8:52 PM
    IEsurfer
    IEsurfer Well-Known Member
    Socal
    Maybe @Superdave1.0 can help, most shops won’t touch anything pre obd2 as you’re finding out
  10. Jul 29, 2024 at 6:58 AM
    Dorf510
    Tyler
    Vista, CA
    18 TRD 4x4
    Thanks all for the info and help, I’m ordering the Weber 32/36 kit w/ block off plates from LCE. Ran the truck last night, rough idle(stock oem carb)even though it’s been rebuilt(3rd Aisin take-off carb I’ve tried, i have a spares box of 5 of them). Hoping the Weber with the deletes will free up the 22r, and rid it of the silly emissions spaghetti(always chasing air leaks). Ill reach out to Jason once i get the parts installed, he is a wizard with Toyotas. Thanks again for all the suggestions!IMG_6113.jpg
  11. Jul 30, 2024 at 9:39 AM
    Rainier
    Rainier Well-Known Member
    OC, CA
    Black 15' Tacoma DCSB 6spd
    got a mechanic in SD that can diagnose my buddies 22r pickup? Battery died one day somewhere so he called a tow truck and they tried to jump start it but reversed positive and negative terminals and fried some stuff.
    Havent had a chance to even look at it but hes done some attempts with no fix yet!
  12. Jul 30, 2024 at 10:25 AM
    Dorf510
    Tyler
    Vista, CA
    18 TRD 4x4
    For all who may be wondering,
    LCE and other manufacturers are no longer selling EGR block plates due to EPA fines. I found a few other sources to get them(yota1,22reperformance,Yotashop). The 32/36 Weber kit from LCE is great, you’ll just have to source “odds and ends” to fully remove all emissions stuff(Egr delete, charcoal canister delete, spaghetti mess of air hoses for carb deleted).LCE also sells a ”intake plug kit” for all the sensors that will be removed during the de-smog. Main goal is simplicity with gained function, and to clean up the engine bay. Photo is anticipated outcome once done.IMG_0333.jpg
    machotaco91 likes this.
  13. Jul 31, 2024 at 5:53 AM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    This is an example of all the stock vacuum lines on a '77 20R.
    This is after:
    Dorf510[OP] and LOLLY like this.
  14. Jul 31, 2024 at 7:09 AM
    Dorf510
    Tyler
    Vista, CA
    18 TRD 4x4
    Found this searching through some other forums with the reverse jumpstart issue:
    “There's a fusible link(wire) that goes from the positive terminal on the battery to the black 80 amp in the fuse block sitting nearby.
    I'd take a hard look at that wire. It looks like regular stranded wire, but is designed to operate like a fuse. It might have one of those loose plastic sleeves protecting it. Look for heat discoloration and/or evidence of melting. Or just ohms check it.“ for a 89 w/ 22re
    Could be burnt out wiring, or a fuse. Id OHMS/resistance test the wiring from the battery to the fuse box and other accessories, ensure your have continuity throughout the circuit.
    Edit: most on the forums are pointing to the 80 amp, they’ve replaced it and fixed the non start issue….some unlucky ones had the stray voltage reach the alternator and fry it too.
    Rainier[QUOTED] likes this.
  15. Aug 2, 2024 at 1:21 PM
    Rainier
    OC, CA
    Thanks, i'll let him know. Not sure how far hes gone in terms of trying to get it started but i'll send him the info!
  16. Aug 3, 2024 at 3:04 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    I can’t help much with your problem, I’m just here to :drool: over your truck. :cheers:
  17. Aug 3, 2024 at 3:34 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
  18. Sep 2, 2024 at 7:54 AM
    Dorf510
    Tyler
    Vista, CA
    18 TRD 4x4
    Welp i am lost for words currently, new Offenhauser intake, Weber 32/36 and full desmog. Idles perfect, but falls on its face under load(taking off from the light, no power unless i “clutch kick”). Timing is set at 0, but i do notice when I blip the throttle the timing retards about 15 degrees(likely timing chain guides or skipped a tooth)on a timing light. Talk about frustrating, but i guess that’s how it goes with old trucks. Fix, break, repeat.IMG_6346.jpgI may be at the point of getting in contact with Jason (@Speed Freek) because i am hitting a mental block on this troubleshooting.
    G2.M6 likes this.
  19. Sep 3, 2024 at 5:16 AM
    gdr
    gdr Well-Known Member
    Bill
    Temescal Valley, Ca.
    2016 Inferno Tacoma TRD OR 4x4
    Your timing numbers sound all wrong. Just about every distributor motor I've had is around 8 degrees BTDC at idle. I also see you have a dual diagram distributor so that means vacuum advance and retard yet you only have one vacuum hose hooked up. Is that all because of instructions for this carb kit?
    I don't think you can skip a timing chain tooth without hearing alot of noise.
    My buddy destroyed his 22re in a 89 pick up due to a broken guide. His poor wife just happened to be driving it at the time. She heard a lot of clatter and had lose of power. She tried to get it off the road and into a parking lot but it died.
    I just saw pictures of the damage and it was incredible. The hole engine was destroyed. The plastic guide broke and everything under the cover was chewed up. #1 cylinder broke a valve head which beat the shit out that cylinder. That valve head made its way through the intake into #4. It was so unbelievable it could do that. The valves in #4 didn't break but that cylinder also got beat to shit. The camshaft broke too. All thus happened in about 10 seconds.
    You want to look at your main crank pulley. I'm not sure if you have it but a lot of them are 2 pieces. The outer piece is bonded to the hub with a rubber material. I guess it makes it a harmonic balancer. The rubber gets hard and cracks. My 3vz would shift back and forth giving me confusing timing numbers until I figured it out. They can finally separate.
  20. Sep 3, 2024 at 10:32 AM
    Dorf510
    Tyler
    Vista, CA
    18 TRD 4x4
    Thanks for that write up! I set timing at 0 per Webers carb guidance. I also just received a new harmonic balancer bc my OG one is original and likely delaminating internally. One hose on the dist per the Weber “setup instructions” and the other is capped. Thank you for confirming my inclination on the pulley separation, i was on the fence and figured a new one wouldn’t hurt.
