Toyota is extending the hp fuel pump warranty to 10 years. Cool.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Da Voke, May 2, 2023.
  1. May 2, 2023 at 11:12 AM
    Da Voke
    Da Voke [OP] Well-Known Member
    Canada
    2020 DCLB Sport (Stolen and recovered)
  2. May 2, 2023 at 11:34 AM
    jaxyaks
    jaxyaks Well-Known Member
    2020 Silver Tacoma TRD Off Road
    Is this for all 3rd gen years or just certain year models?
  3. May 2, 2023 at 1:28 PM
    Da Voke
    Canada
    Don’t know. It says certain models of 2016-2022.
  4. May 2, 2023 at 1:40 PM
    BillyE
    BillyE Well-Known Member
    Have there been any engine fires from the HPFP?
  5. May 2, 2023 at 6:30 PM
    MadKatt
    MadKatt In need of serious help..
    Frozen Midwest Tundra
    2019 TRD OR DCLB Calvary Blue
    Is this before or after you had the FP replaced?
    Chew likes this.
  6. May 4, 2023 at 1:16 AM
    Da Voke
    Canada
    I’ve never had the pump replaced
    MadKatt[QUOTED] likes this.
  7. May 4, 2023 at 1:44 AM
    aCrimsona
    aCrimsona Member
    Toyota got a bad batch of fuel pumps. They know which trucks were affected, there's a website you can go to, or go to the dealership, run your vin and they'll tell you if your truck has the bad pump or not.
    TS4x4 likes this.
  8. May 4, 2023 at 5:36 AM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    This is different than the previous recall for the low-pressure fuel pump. This warranty extension is
    for the high-pressure fuel pump. I haven't seen any posts about leaks from the HPFP, but obviously
    there must have been some issues.
    eurowner and pdxTacoSR5 like this.
  9. May 4, 2023 at 7:22 AM
    05 4x4
    05 4x4 Well-Known Member
    @aCrimsona is there a TSB for this? Would like to check mine. Thanks!
  10. May 4, 2023 at 7:29 AM
    goingplacesanddoingstuff
    goingplacesanddoingstuff Well-Known Member
    2019 TRD Off Road
    2.5” OME lift, Koenig Six Shooter wheels, 275/70r17 Nokian Outpost AT, CMC, Nitro 4.88s, Greenlane aluminum sliders, CBI aluminum skid, Greenlane aluminum front bumper, Out Gear Solutions HC rear bumper, Baja SAE fogs
    Could this cause a loss of power?
    HondaGM likes this.
  11. May 4, 2023 at 10:25 AM
    islesrule123
    islesrule123 Well-Known Member
    New York
    2016 inferno Tacoma TRD off road
    Trd pro suspension trd pro grill
    I had my HPFP replaced due to it squeaking when the direct injection was in use. Covered under the extended warranty when I had it
  12. May 8, 2023 at 8:37 AM
    gasganofj60
    gasganofj60 Well-Known Member
    87 FJ60 & 21 TRDOR
    Which site do we visit to find out?
  13. May 8, 2023 at 8:42 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Says warranty enhancement.
  14. May 8, 2023 at 9:47 AM
    Fredk
    Fredk Well-Known Member
    Fred
    Dark grey 2020
    Just remember if you go to a dealer and have them check and there is noting wrong, you pay for appt. Read all of the letter to confirm.
  15. May 18, 2023 at 8:00 AM
    Inferno2016trd
    Inferno2016trd Active Member
    Vince
    TACOMA 2016 TRD INFERNO
    So I've got what sounds exactly like a chirping/peeping High Pressure Fuel Pump noise that follows the revs sounds like it's coming from the exact location on the videos I have found. I have no warranty on my 2016 TRD sport and I just called Toyota to see if I wax affected by a recall and they said there are no open recalls for my VIN. However it seems like the "some 2016" models could apply to me for a replacement.
    What are my options with Toyota or should I just purchase the fuel pump and have it installed by someone else?
  16. Mar 2, 2025 at 5:20 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    up to 19' since i was a part of the recall and replacement. although i remember them asking for me to come in when the tank was 1/4 or below leading me to believe they replaced the tank pump vs the HPFP
