Toyota Engine Oil System Cleaner
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Racer78, Jun 7, 2011.
  1. Jun 7, 2011 at 1:14 PM
    Racer78
    Racer78 [OP] Well-Known Member
    05 Tacoma 4X4 Sport
    Billstiens 5100 @1.75, 5125, 1.5 AAL,Leaf Spring TSB,TRD Intake, Roof Rack, Satoshi Grill, BHLM,T-Rex Eyelids, Undercover Cover, Powdercoated Sport Rims, KC Slimline 8" Lights, MTX ReQ5 w/ipod imput, 12" Shallow Pioneer Sub, RF 800.4 amp, JBL Comp, Bed Ext, USB Port, Shorty Antena, Spider Trax Spacers,TRD Skid Plate, Napier Sportz Tent II, Scangauge II, AirBedz
    So, I did a brake job yesterday and snapped off one of the wheel studs. While waiting in line for the new wheel stud, I seen this Toyota version of Seafoam at the dealer and of course, the little tubes of before and after oil samples to justify the $20 price tag..
    Being a Seafoam guy, I thought I would give it a try as it is a Toyota product. I was wondering if anyone has tried this Toyota brand and what you thought of it compared to the $10 Seafoam?
    Im thinking they are pretty much the same as a pre oil case sludge cleaner before you drop the oil.
    Thanks
  2. Jun 7, 2011 at 1:41 PM
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    I wonder if Toyota dealerships use this when doing certain scheduled maintenance services. I did not know that toyota had this. Personally, because i baby my truck i would feel safer using toyota brand than seafoam.
    The only difference that you'll probably notice is a thinner wallet. :)
  3. Jun 7, 2011 at 1:51 PM
    JKD
    JKD Well-Known Member
    There is no need to use a Toyota brand version of something like this unless the Toyota brand is cheaper. Seafoam works fine in everything.
    Good find though.
  4. Jun 7, 2011 at 9:17 PM
    808hiker
    808hiker Taco addict
    Justin
    Big Island, Hawaii
    Interesting...let us know how it goes. :popcorn:
  5. Jun 7, 2011 at 10:21 PM
    Taco11
    Taco11 Well-Known Member
    Seattle WA
    Subaru just recently released this same type of product.. Interesting.
  6. Jun 7, 2011 at 11:10 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    I believe this stuff is a market to get your money. Hard crusted on carbon will not disappear. That is done through manually removing it.
    With that being said your mileage may very and the above is MY opinion.
  7. Jun 8, 2011 at 4:20 PM
    Racer78
    05 Tacoma 4X4 Sport
    Did my oil change today and tossed the treatment in the crankcase. Let it idle for 20min (can suggested 15min)...I wanted my moneys worth :D. I expected to see a clear liquid in the can but it was red and also kinda smelled like diesal. It had me thinking back when guys use to add a few drops of tranny fluid in the case to free up sticky lifters...
    I use Mobil 1 full synthetic and it came out pretty black. Being that I change my own oil, springing for the little extra cost isnt that bad I guess for that feel good feeling of knowing its done right.
  8. Jun 9, 2011 at 6:53 PM
    Taco11
    Seattle WA
    I would agree that this wont dissolve chunks of carbon.. however from my experience it will remove some deposits of carbon and most of the sludge. I wouldn't do this every oil change but every now and then it certainly can't hurt. Its more for people who have been neglected changing their oil for a while, or have been using low quality oil.
  9. Jun 9, 2011 at 10:25 PM
    BUZZCUT
    Georgia
    Quart of automatic trans fluid for a week or two prior to oil change or a quart of diesel fuel and 30 minutes idle time before change.
    Problem is those who have neglected their vehicle shouldn't do either they should just run a good HEDO (diesel) oil and it will do amazing things. It won't happen overnight but it won't chunk up things that could really cause a problem if lodged somewhere.
  10. Jun 10, 2011 at 9:46 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    I would leave the stuff alone. Change your oil more often if you think you have a sludge problem, or switch to synthetic. Anytime you thin your oil in the hopes of cleaning the engine, you decrease the size of the oil film on the crank and rod bearings.
    To each his own, but you won't catch me using it.
    Rambo54, 06Tacooo and ABNFDC like this.
  11. Jun 12, 2011 at 3:40 AM
    reg boulette
    reg boulette Well-Known Member
    Saw this crap and a fuel system treatment in last issue of Toyota marketing magazine. Sad they have sunk so low.
    Just snake oil to increase profits at the dealership. Toyota hasn't had a sludgy engine since the late 1990's/ (although those ones resulted in a class action suit against them) Regular oil changes are all you need.
    As for Seafoam, if you've got a coleman camp stove/lantern, rubbing alcohol for your sore back and a kerosene heater for your ice fishing shed, make your own. Naptha, isopropyl alcohol and kerosene are the three ingredients. (check their WHMIS sheet)
    Rambo54 likes this.
  12. Jun 12, 2011 at 5:50 AM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    If you take apart an engine with 100k miles that has seen reg changes with good quality synth oil you will see how clean it is. Putting this sort of "cleaner" stuff in your oil is at best snake oil and at worst could do some damage. Waste of time and money....
    06Tacooo, TacomaMike37 and jsi like this.
  13. Jun 12, 2011 at 6:19 AM
    themuffinman619
    themuffinman619 Play stupid games, win stupid prizes
    themuffinman
    Your moms house
    I'll take some of that :popcorn:
  14. Jun 12, 2011 at 7:51 AM
    Scott K
    Scott K Well-Known Member
    Scott
    Coquitlam, BC, Canada
    Amsoil Synthetic ASL 5w30 Oil, Amsoil ATL Fuel Efficient ATF, Amsoil Severe Gear 75w90 in front/rear diffs & transfer case.
    On my 93 Toyota Xtracab Pickup with the 3vze 3.0 V6 in 4x4 I used to run Mobil 1 synthetic 10w30 (not the EP stuff, just the regular synthetic) for the longest time. I used it for regular 6000 to 7000 km oil changes for about 70,000 km's or so (about 40,000-ish miles or so give or take). For some reason I did a change in there with some Amsoil 10w30 just to try it but then switched back to Mobil 1 again. I noticed the engine on Amsoil started slightly better/smoother, and it seemed to run slightly better. But I didn't give too much thought it after that. Then I made the decision to switch over to Amsoil entirely. I got a bottle of their Engine Oil Cleaner and dumped it in with a previous Mobil 1 10w30 change, and let it idle as per the instructions, then changed it out for some Amsoil 10w30 (their top tier stuff). When I took the truck for a drive it was noticeably more responsive and slightly more powerful. I really couldn't believe the results. It ran so much better. This stuff honestly made a difference. And this was in an engine that had had detergents from Mobil 1 synthetic working on it for quite a long time. Overall I think a crankcase cleaner might be worthwhile for some applications, and in that one it worked like a hot damn.
    Rambo54 and SonnyBones like this.
  15. Jun 12, 2011 at 8:28 AM
    Raylo
    MD, USA
    If you actually take an engine like this apart you will see that all the parts that matter in the crankcase are pretty much like the day they left the factory. And I fail to see how cleaning some varnish off the oil pan and galleries can make a motor "run better". Just makes no sense. And if the oil ports were clogged you would already have failed bearings and/or valve train. But if it seems to work for you, that's all that counts I suppose. As they say, YMMV.
    TacomaMike37 likes this.
  16. Jan 23, 2017 at 2:37 PM
    7fever
    7fever New Member
    After reading the replies on this thread I had to make an account. After working on numerous different makes and models of cars for 30 years I can assure you that running a detergent in your engine is the best thing you can do it less a full tear down. The ignorance displayed by some of these snake oil posters is absurd. Spreading ignorance is the something I cannot ignore. Where someone can come up with this garbage is beyond me. And please do not run detergents or thinners in an engine under load. Another completely ignorant post. All of my tear downs that have run detergents every second oil change came out with immaculate results. Even on engines with sludging issues like ALL BMW motors or even some of the 1mz motors. Good luck and don't listen to people online with zero experience, knowledge, or heck even theory of the subject. The Internet sure is a wonderful place to share wrong answers!
    igno1tus, Pabloeeto and Bluebaron7 like this.
  17. Jan 23, 2017 at 2:49 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    on the 1gr that has shown to easily live to 400k miles.... i plan on just doing regular old oil changes with quality oils at proper intervals.....
    devkurf and Pigpen like this.
  18. Jan 23, 2017 at 5:08 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I'm sorry, but that is called a placebo effect. Without real numbers the ass dynomometer results are not worth anything. When ever you hear words like "it feels like ...", it is usually just Bologna.
    And when people are talking about removing sludge... Well if you have sludge to begin with you have already screwed up. The last thing you want is to have it break loose in a chunk and block an oil passage or the oil pump.
  19. Jan 23, 2017 at 5:56 PM
    SonnyBones
    SonnyBones I VOID WARRANTIES
    Jeffery
    2015 TACOMA ACCESS CAB
    Yeah man, made the switch over to amsoil as well not to long after purchasing the truck. Prior to switching over, during cold morning startups it had a hard time. Switched over to amsoil and no hard start ups. Not really what I would call a performance gain, but more of a operational gain
    Rambo54 likes this.
  20. Jan 23, 2017 at 6:15 PM
    Pabloeeto
    Pabloeeto Well-Known Member
    Paul
    San Diego
    06 DCSB TRD Sport 4x4
    K&N filter, 3.5 Aux input mod, Fox 2.0 Coilovers, Fox 2.0 Resi Shocks, Element UCAs, Old Man Emu Dakar Leaf pack.
    TOYOFOAM
