Toyota Dealer No Post Inspection Report, Trying to Tricking Me?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoBell07, Jun 13, 2022.
  1. Jun 13, 2022 at 1:17 PM
    TacoBell07
    TacoBell07 [OP] Well-Known Member
    Four door 2wd Taco
    Below is the only copy my dealership who did the frame inspection could produce.
    I asked service if they had any other documents as this does not tell me anything as to what were the results of the below inspections.
    I do not know any place that does an inspection that cannot produce a defect list stating what was found to be wrong or correct on a post inspection report.
    I suspect the dealer just does not want to give it to me or never produced the post inspection report at all. If they did not produce frame report of what was found to be ok then that does not look good for them.
    What do you all think?
  2. Jun 13, 2022 at 1:23 PM
    Tacoma Mike
    Southern Maine
    For You, Pass Or Fail
    The exact severity of the rust is electronically documented and sent to Toyota.
    If there were holes in frame you would be told. There is no documentation for the owner?
    Then arrangements would be mad to have it sprayed if you haven’t had it done already.
  3. Jun 13, 2022 at 1:30 PM
    TacoBell07
    Four door 2wd Taco
    Im not in a rust belt or salt state though, so how does this affect the inspection report? My understand is that if you were not in a salt state you did not get the CRC treatment sprayed on.
    So the exact severity is electronically recorded? So Toyota has photos of how bad it was at the time of inspection ??
  4. Jun 13, 2022 at 2:15 PM
    Tacoma Mike
    Southern Maine
    There are sample pictures and we match the pictures to our visual inspection and check that box off and then we send it off to Toyota. I couldn’t visually see if you were in the salt belt so I was just going by Maine procedure
  5. Jun 13, 2022 at 2:20 PM
    TacoBell07
    Four door 2wd Taco
    So based on your experience (in Maine dealerships) no actual picture of the consumers frame is ever actually taken and delivered to Toyota Inc ?
    Cell bill ??
  6. Jun 13, 2022 at 3:36 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    This sums it up nicely.
    What most fail to understand is that rust isn’t what makes the frame fail inspection.
    It’s rust perforation of the frame. And it must be of a 10mm size or larger.
    Not only that, depending on year/model, it need to be in a certain area. The whole frame is covered/inspected.
  7. Jun 13, 2022 at 5:51 PM
    Tacoma Mike
    Southern Maine
    Unless a issue. Then we take pictures and send them off to corporate, then they send down a rep. Oh yeah damn spellcheck lol
  8. Jun 13, 2022 at 5:52 PM
    Tacoma Mike
    Southern Maine
    Salt belt
  9. Jun 13, 2022 at 5:54 PM
    Bishop84
    Bishop84 Well-Known Member
    It's pass or fail. It's a class action law suit, we can't speculate or mention rust spots that are anything but perforations. If it was a fail there would have been a frame ordered.
    TnShooter likes this.
  10. Jun 13, 2022 at 6:01 PM
    Tacoma Mike
    Southern Maine
    Do not, I repeat do not, do anything to try and make a hole.They will fail that frame instantly for assistance.
  11. Jun 13, 2022 at 8:45 PM
    burrito782
    burrito782 Shit Throwing Ape
    08 TRD Off Road
    Unfortunately OP has no shortage of holes in his frame...
    https://www.tacomaworld.com/threads/taco-frame-repairable.767434/
  12. Jun 14, 2022 at 7:30 PM
    TacoBell07
    Four door 2wd Taco
    Dude its a swiss cheese taco. I just say screw that s$%^ and take advantage of the weight reduction to increase power to weight ratio
  13. Jun 14, 2022 at 7:35 PM
    TacoBell07
    Four door 2wd Taco
