Toyota Brake Pads - Shims Required?
Discussion in 'Technical Chat' started by eltaco, Jan 25, 2019.
  1. Jan 25, 2019 at 7:35 AM
    eltaco
    eltaco [OP] Well-Known Member
    Littleton, CO
    '07 4x4 DC Offroad
    I'm needing to replace my brake pads, and plan to go back to OEM style this time around. The pads I'm planning to go with are the below P/N. These pads do not come with anti-squeal shims, though I see Toyota does sell them as OEM parts. I know some pads require the shims, others do not. Can anyone tell me if I need the shims for these pads? I realize at one point these pads came with shims, now they do not.
    04465-AZ100 - Toyota Front Pads
    04945-0C030 - Toyota Anti-Squeal Shims
  2. Jan 25, 2019 at 5:20 PM
    stefanlg55
    stefanlg55 Toyota Master Technician
    2008 Tacoma TRD OffRoad
    I would get the shims just because the fact u will keep the contact surface of the pad/piston from causing rust to build to leading to brake fading. ( what happened to mine )
    Toyota use to sell the kit w/ shims, however the shims were not up to par and caused more issues them it should have solved. rust was getting behind them and also the shims were causing noise. Never noise issues on the tacomas because the pins held them in place, but on non pinned the shims would float and rub against the caliper bracket causing scraping noises.
  3. Jan 25, 2019 at 10:27 PM
    eltaco
    Littleton, CO
    '07 4x4 DC Offroad
    Appreciate the response, but I’m not clear.
    you wrote you would get the shims... then later wrote they caused problems. Which is it?
  4. Jan 25, 2019 at 10:35 PM
    Bishop84
    Bishop84 Well-Known Member
    Shims are 100% required, they don't create issues, if there aren't any the pads will vibrate and squeak on low pressure applications.
    It doesn't create or reduce brake fade. It takes up the slack of the pad to rotor to piston.
    That said, some aftermarket pads come with shims that can transfer to the OEM pads. You may have transferable shims, I do it all the time. Just make sure to use a non-petroleum grease between the shim and pad.
  5. Jan 26, 2019 at 6:09 AM
    stefanlg55
    I would get the ones you posted. The ones i was saying to stay away from where the Toyota pad kits that came with shims, they are not the same ones u posted and the dealer I work for no longer sells them because of all the issues that we had from them.
