Toyota Bilstein Shocks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kilroy2963, Sep 6, 2024.
  1. Sep 6, 2024 at 12:54 PM
    kilroy2963
    kilroy2963 [OP] Well-Known Member
    Massachusetts
    2008 Blue TRD Offroad
    So I had a brand new set put on in 2016, how long do these typically last.
  2. Sep 6, 2024 at 2:30 PM
    The_Hybrid_Hunter
    The_Hybrid_Hunter Active Member
    2013 Tacoma Silver
    Which model shocks did you get?
  3. Sep 6, 2024 at 2:35 PM
    545 Well-Known Member
    2015 Access Cab
    More of a mileage thing
  4. Sep 6, 2024 at 2:49 PM
    kilroy2963
    Massachusetts
    I believe they are the B6 4600, Toyota part number they use is 48510-A9630 for the fronts.
    I put them on at a 34085, and now i have 71000.
  5. Sep 6, 2024 at 3:17 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    When it comes to shocks, there are 3 things that helps me answer this question. Are there any signs to fluid leak around the shock body? Has the shock caused any funny tire wear pattern? Has the ride quality changed for the worse? If there's a yes to any of those 3 questions for me, I know it's time for a shock change or rebuild.
  6. Sep 6, 2024 at 5:49 PM
    O'DubhGhaill
    O'DubhGhaill Well-Known Member
    2008 Tacoma TRD Sport Access Cab 4.0L V6 VVT-i6spd manual
    po35042 and BlkDakDave like this.
  7. Sep 7, 2024 at 5:37 AM
    rblalliance
    rblalliance let the wookie win
    08 TRD OR DCSB 4X4
  8. Sep 7, 2024 at 6:29 AM
    Micbt25
    Micbt25 Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
  9. Sep 7, 2024 at 10:29 AM
    TacoTuesday1
    FL
    4600?
    bout a day
  10. Sep 7, 2024 at 10:51 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    If they put in toyota OEM Bilstein' s they are NOT the 4600's. Factory TRD OR / SPORT 2nd gen and TRD OR 3rd gen shocks are a smaller diameter than the 4600's.
    The 4600's and 5100s are the same diameter and in fact, the rear 4600's are IDENTICAL to the 5100's in everything including valving except the boot and the paint/finish. Front 4600's have slightly softer valving and no height adjustment.
    BlkDakDave likes this.
  11. Sep 7, 2024 at 1:36 PM
    rblalliance
    08 TRD OR DCSB 4X4
    This is how the look on my truck. When I measured there was like 1/2inch between the front and the back
    Micbt25[QUOTED] likes this.
  12. Sep 7, 2024 at 5:53 PM
    O'DubhGhaill
    Yes, lifted the front a bit now just about same height as rear.
  13. Sep 7, 2024 at 6:38 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I'm at ten years and 167,xxx miles on my stock Bilsteins, and they are not 4600s. Mine show no signs of leaking or failure. The 4600 series are better/more robust than the stock units.
    kilroy2963[OP] and BlkDakDave like this.
  14. Sep 9, 2024 at 5:14 PM
    Gdeyarmond
    Gdeyarmond Well-Known Member
    San Dimas, CA
    2020 TRD OR 4x4 6MT
    Bilstein 6112/5160
    As said above, if they are the Toyota Part numbers, they are not 4600's. I emailed Bilstein like 6 months ago to clarify....
    "The dampers you are referring to are a product that an OEM designed and then hired us to build. I am sure you can understand that we are hired by many OE manufacturers to build kits or shocks they make for their vehicles. When this happens, we will proudly stamp the damper with our logo but the design remains proprietary to the company that hired us to build it, in this case Toyota. Our 4600 series is a product that Bilstein’s engineers design, tune and build. Most people consider our products to be an upgrade in comfort and performance over the OEM’s. Please consider checking out our online catalog below. Thank you."
  15. Sep 10, 2024 at 4:14 AM
    rblalliance
    08 TRD OR DCSB 4X4
    The 4600 I put in my truck look different from the Blisteins that are on my son’s ‘18 OR. Especially the rear shocks that look wider. I’ll take some pictures later and post them.
  16. Sep 10, 2024 at 5:39 AM
    kilroy2963
    Massachusetts
    I found the 4600's on Amazon, shipped and sold by Amazon for less than $200 for a whole set.
  17. Sep 10, 2024 at 6:13 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Shocks are a wear item and their performance usually degrades gradually, so it's hard for the driver to notice when they have gone past their date. Even if there are no obvious signs of leaking or failure, the oil degrades and internal seals and parts wear. I've found that non-Bilstein OEM Toyota shocks last about 30k - 50k miles before their performance has degraded beyond my liking. Beyond that you usually start seeing odd tire wear, but it happens gradually. Bilsteins should last at least 50k, maybe up to 80k (but not 147k like that one dude above, he needs to change his shocks).
    Yours are in that 30-50k range and should be fine for a bit longer unless they have been severely abused. As always YMMV.
    kilroy2963[OP] likes this.
  18. Sep 10, 2024 at 8:30 AM
    kilroy2963
    Massachusetts
    So I got the correct part numbers for the Bilstien 4600's, but what spring coils would go with those, is OEM okay?
  19. Sep 11, 2024 at 5:22 AM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Yes, OEM would be fine.
  20. Sep 12, 2024 at 6:42 AM
    kilroy2963
    Massachusetts
