Toyo steering tundra steering rack
Discussion in 'Technical Chat' started by SoonToBeOn39s, Apr 6, 2023.
  1. Apr 6, 2023 at 10:32 PM
    SoonToBeOn39s
    SoonToBeOn39s [OP] Well-Known Member
    I finally got bigger tires 2020 Long Travel Tacoma 1997 MAGNUM
  2. Apr 6, 2023 at 10:50 PM
    MGMDesertTaco
  3. Apr 9, 2023 at 9:45 AM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
  4. Apr 9, 2023 at 3:40 PM
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    MGMDesertTaco[QUOTED] likes this.
  5. Apr 9, 2023 at 6:52 PM
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    What is the advantage of doing this swap?
  6. Apr 9, 2023 at 8:03 PM
    SoonToBeOn39s
    Stronger steering rack that won't die after putting on 35" or bigger tires
  7. Apr 9, 2023 at 8:21 PM
    HisDad
    Texas at last
    Ahhh, I get it. Makes sense if you're going to put on larger tires than the truck was design for.
    SoonToBeOn39s[OP] likes this.
  8. Jul 31, 2023 at 11:56 AM
    Sleepycheese
    Sleepycheese New Member
    Adam
    2014 Toyota Tacoma
    I just xcame across a post for a few years ago, does that mean you are still doing these conversions? I'd like this to be my next upgrade as I keep running through cheaper tacoma racks.
    LeakyAC likes this.
  9. Aug 1, 2023 at 12:56 PM
    Basikbiker
    Trav
    ive built well over 100 of these by now lol... yes i still do em
    LeakyAC likes this.
  10. Aug 1, 2023 at 1:03 PM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    I'm planning on getting one eventually...great mod imo.
    Do you recommend a stronger PS pump when doing this mod on a 3rd gen Taco?
  11. Aug 1, 2023 at 1:13 PM
    Basikbiker
    Trav
    they work well with either. an upgraded pump will help some but you also would need to add a cooler, return filter, larger resi....it adds up quick
