Toyo RT Trail 285
Discussion in 'Wheels & Tires' started by erickrod97, Jan 23, 2023.
  1. Jan 23, 2023 at 9:15 AM
    erickrod97
    erickrod97 [OP] New Member
    Erick
    23 Tacoma OR
    First Post.
    Didn't see many posts on the new RT trail from Toyo.
    Threw some on my 23 OR.
    285/75r16 on OEM TRD Pro 16in wheels.
  2. Jan 23, 2023 at 9:20 AM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    I haven’t seen a ton of stuff about them yet either, they look awesome!
  3. Jan 23, 2023 at 11:06 AM
    eurowner
    eurowner Duke Sky
    Scoty
  4. May 12, 2023 at 8:29 PM
    5RickB
    5RickB Active Member
    Virginia
    2023 LR TRD Off-road MT
    I have a set of 285/70/17’s and so far cannot be happier
  5. May 12, 2023 at 8:30 PM
    5RickB
    Virginia
    OP, Nice looking truck by the way!
  6. Nov 9, 2023 at 10:24 PM
    SavageTacoma91
    SavageTacoma91 Well-Known Member
    Daniel
    Meadow Vista, CA
    2008 Toyota Tacoma V6 4x4 Access Cab
    I got these right when they came out, and I have to say, driving in snow or rain is pretty slippery.
  7. Nov 11, 2023 at 9:34 PM
    camposme
    camposme Well-Known Member
    Ty
    Piedmont Triad - NC
    '16 TRD Sport DCSB
    Fox 2.5 Racing Suspension w/ Resi (ET) OME Dakars (Med Duty) SPC UCAs BAMF Grille TRD Skid TRD Wheels Tom Woods DS
    Hmm have been seeing this as well... does it get better over time or nah?
  8. Nov 11, 2023 at 9:55 PM
    SavageTacoma91
    Daniel
    Meadow Vista, CA
    I was hoping it would get better but it seems to be the same, whenever it rains I have to be really careful or I will break traction at every stop and go
  9. Nov 11, 2023 at 9:57 PM
    camposme
    Ty
    Piedmont Triad - NC
    '16 TRD Sport DCSB
    Interesting... these do look phenomenal but great to know about the rain/snow. Thanks!
  10. Feb 17, 2024 at 11:16 AM
    eljedi68
    eljedi68 Well-Known Member
    David
    Kalaheo, HI
    2010 Tacoma Ext Cab 4x4
    complete Long Travel Suspension built by DMZ: 3+ Control Arms by TC, Bed Cage, Denver Under Springs, Fox all around (Coilover & Bypass up Frt, 3.0 Bypass Rr). Full Glass front fenders and bedsides. Engine so far: TRD CAI, DT Headers, URD Y Pipe, Gibson Muffler. And a Sprint Booster. Sits on Toyo OC 35x12.5 on 17’s. Nitro Rear end and re-geared for 35’s (4.56). Goals: Flowed Heads, Cams, and Boost (SC) ! So far, so good
    Aloha TW Ohana, I’m stoked some guys are trying these new Toyo’s out… I’m liking what I’ve read via the Web. But was truly hoping some Tacoma guys have tried them out.
    I’ve had many sets of the old Toyo A/T’s,, and a few years back I switched to the BFG’s KO2… simply because their a little Lighter, but most of all: They actually AIR DOWN
    where as all my Toyo’s seemed to stay Bricks no matter what off road PSI I ran (think our Taco’s are too light for these 3ply load rated E tires)
    I’m curious if these new Toyo “Trails” actually air down and flex
    My Question and hope TW guys: is looking forward to hearing some Off Road ride feed back from Taco guys
    mahalo’s
  11. Feb 17, 2024 at 12:34 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Went with 275/70/17 on my 2nd gen. So far light offroading they're great... highway road noise hardly noticable. They did great on snow covered roads but coming to a stop on ice they're a little dicey... even with 4WD engaged. Another thing i noticed... in a snow covered parking lot with 4H engaged i have to make more gradual turns now... feel more binding compared to the 265/75R16 bfg a/t's i had prior. Had to reverse/forward a few times to get in parking spot (more than usual.) Probably just because it's a more agrresive wider tire but kinda suprised me.
    Road_Warrior, Pista1 and eljedi68 like this.
  12. Feb 18, 2024 at 10:08 AM
    eljedi68
    David
    Kalaheo, HI
    Big time mahalo’s on the come back OffroadToy
    them Toyo’s look amazing on your Taco
    and I’d imagine them being bigger and the rim offset will take a mile or two to get use to on them tight parking lot turns (I’m running 35’s on Methods, and they do require a 3 point turn in certain tight spaces)
    We don’t have Snow or Ice out here lol , but we do have constant rain/wet roads
    I’m curious about when you’re just going down the hwy or country roads… do you Feel more Road Bumps? I remember my Toyo’s seemed to transmit the road imperfections into my cab a lot more than my BFG’s (again, I think it’s the fact that my Toyo’s were designed for heavier rigs), Thoughts?
    i love the look of these AT Trails big time
    aloha
  13. Feb 18, 2024 at 12:32 PM
    OffroadToy
    Thanks... Makes sense about the offset being different. As far as feeling the road i haven't noticed that much difference from the bfg e rated 10 ply. Love to see a picture of your rig with the Methods/ Toyo's.
    eljedi68[QUOTED] likes this.
  14. Feb 18, 2024 at 6:45 PM
    eljedi68
    David
    Kalaheo, HI
    my Taco is hovering on Jackstands for the last few months (doing a Restro on her). So it’ll be a month or so before I can rock some pics of the new wheels (which I will absolutely post for ya).
    but here are some pics of Tires long past lol (3 different set ups all on Toyo’s). The last pic is with my BFG’s just before my Restro project
    Discount Tire and OffroadToy like this.
  15. Feb 19, 2024 at 8:54 AM
    OffroadToy
    Nice ride eljedi68... thanks for sharing! :cheers:
    eljedi68 likes this.
