Toyo Open county AT3 285/70/16
Discussion in 'Wheels & Tires' started by wangtime89, Feb 28, 2023.
  1. Feb 28, 2023 at 11:34 AM
    wangtime89
    wangtime89 [OP] Member
    About to get the toyo open country AT3 in a 285/70/17 on my stock '21 tacoma TRD OR. Anyone have the same setup? saw on youtube that you only need to cut a little bit off the back fender and should not rub at all is that true? Pics would be great!
  2. Feb 28, 2023 at 11:47 AM
    2Shoes
    2Shoes Well-Known Member
    2021 TRD Off-Road
    As in stock, no leveling kit, or anything? That size tire will rub the back of the front fenders at partial lock. You cannot go any larger than a 275 width tire at stock height and stock wheels.
    I'm lifted 2" on mine, and have 285/70R17s.
  3. Feb 28, 2023 at 11:58 AM
    wangtime89
    Correct no leveling kit or anything. Thanks for the advise. I Saw this video and was hoping that it could fit with little trimming.
    https://youtu.be/2IzmH2LRu6A
  4. Feb 28, 2023 at 12:01 PM
    2Shoes
    2021 TRD Off-Road
    It's possible, what wheel are you going to run? I'm running a 0 offset now, and there is rubbing when I hit bumps while turning into parking lots. You do need to trim the plastics, and hammer in the pinch weld to make them fit.
  5. Feb 28, 2023 at 12:10 PM
    wangtime89
    I jus the the stock OR wheels i think they are +25 offset
  6. Feb 28, 2023 at 12:19 PM
    2Shoes
    2021 TRD Off-Road
    You won't be able to run that size tire without a minimum of 1" wheel spacers and some trimming. This is probably the most asked question on the forum, "What's the largest tire size I can fit without a lift", so I would do some searching, you'll find the info you need.
  7. Feb 28, 2023 at 12:27 PM
    neatoneto
    neatoneto Well-Known Member
    CT/Mass
    2020 TRD Off Road DCSB
    285 is asking for trouble unless you get real lucky with wheel offsets. I run this tire on 17x9 -12 wheels with a 2.5" lift and had to do a considerable amount of work to stop the rubbing.
    wangtime89[OP] likes this.
  8. Feb 28, 2023 at 12:54 PM
    wangtime89
    thanks everyone decided i would go with a 275/70/16!
  9. Jul 29, 2023 at 8:26 AM
    birry
    birry Well-Known Member
    Oklahoma City, OK
    2008 4x4 DCSB
    OME 885, Bilstein 5100's, Wheeler's (single) AAL
    I'm digging that tire + wheel combo. Looks great. I'm looking at going up a size from my current 265/70R17 Falkens (also have 2" lift), and want something with less negative offset than the SCS Ray 10's that I'm running now.
    Are you getting any poke on the sides with this setup?
  10. Jul 29, 2023 at 7:01 PM
    2Shoes
    2021 TRD Off-Road
    I have nearly zero tire sticking out of my fenders, I've gone up a little on the lift to about 2.5", but have the same zero offset and 285/70R17's.
    birry[QUOTED] likes this.
  11. Nov 26, 2023 at 11:57 AM
    Juntao206
    Juntao206 Member
    2022 Tacoma TRD OR
    Hello, I’m thinking going with the 285, do you just need the cmc?
  12. Nov 26, 2023 at 5:06 PM
    2Shoes
    2021 TRD Off-Road
    If you go with a 0 offset wheel, you don't need to do a CMC. If you go for anything with a negative offset, you'll need a CMC, an alignment and trimming to run them. It's also not just the 285, it's the side all height, and what size wheel you choose. A 285/70R17, on a 17" wheel, is going to be about the same width and height as a 285/75R16. Now, if you.want the tallest tire, a 285/75R17 will be an inch taller.
    Everyone here needs to be more specific than just saying 285's.
  13. Nov 26, 2023 at 5:35 PM
    Juntao206
    Juntao206 Member
    2022 Tacoma TRD OR
    Hello, I am currently running 17x9 -12 offset vision flows with 2" lift, gonna go up to a 2.5" lift soon, I will go with Toyo AT3 285/70r17, and what kind of alignment to run them without any issue? I will do CMC too
    Thank you
