toyo open country M/T sizes
Discussion in '3rd Gen. Tacomas (2016-2023)' started by afdtrdpro, Mar 12, 2019.
  1. Mar 12, 2019 at 5:39 PM
    afdtrdpro
    afdtrdpro [OP] Member
    chris
    17 trd pro
    I am trying to get a little more height on my truck without changing my shocks right now. What are the biggest tires I can fit without rubbing/problems on a stock suspension pro, while keeping the stock rims? And what other options do I have if any, to get more height without getting new shocks/coilovers?
    P.S. besides getting a taller tire, I would like to go a little wider too.
  2. Mar 12, 2019 at 5:45 PM
    HacksawMark
    HacksawMark Well-Known Member
    Mark
    OREGON
    2018 Silver Tacoma V6 DCSB TRD OffRoad traded for 2019 Ford XLT 3.5L EcoBoost SC
    Going from 265/70/16 to 265/75/16 will give you another inch.
  3. Mar 12, 2019 at 5:52 PM
    afdtrdpro
    chris
    17 trd pro
    can i go 2 inches or it will rub?
  4. Mar 12, 2019 at 6:33 PM
    HacksawMark
    Mark
    OREGON
    Others will have to chime in about that. Keep in mind taller and wider tires will affect your MPG.
    afdtrdpro[QUOTED][OP] likes this.
  5. Mar 12, 2019 at 6:46 PM
    Toki
    Toki Don’t get killed by Theta.
    Jon
    San Jose, Ca
    2018 Tacoma 4x4
    Little bit of this and a little bit of that but stock af.
    You can definitely go taller but how much are you willing to cut? To go wider, either different off set wheel or wheel spacers. However by doing so you may need more cutting. In the end yes it will fit if you are willing to some :sawzall:
  6. Mar 12, 2019 at 6:50 PM
    afdtrdpro
    chris
    17 trd pro
    I don't want to cut, I think im going to do 265/75/16. unless I could do 275/75/16 without it rubbing.
  7. Mar 12, 2019 at 6:52 PM
    JCOOR
    JCOOR Well-Known Member
    TRD Burglar
    255/85/16 will be the tallest with no rubbing but gotta switch brands
    doublethebass likes this.
  8. Mar 12, 2019 at 6:55 PM
    HacksawMark
    Mark
    OREGON
    Not likely as they are nearly 3 inches taller than stock.
  9. Mar 12, 2019 at 7:11 PM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    JCOOR likes this.
