Toyo Open Country AT3 vs Cooper Discoverer AT3
Discussion in 'Wheels & Tires' started by Sgt., May 23, 2020.
  1. May 23, 2020 at 8:05 AM
    Sgt.
    Sgt. [OP] New Member
    Jeff
    13tacotrd
    got a gen 2 with toyo at2 time to replace any thought on the toyo at3 vs cooper at3
  2. May 23, 2020 at 8:11 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW... I’ve read a lot of good things on the toyo at3. I’m debating on whether to buy them or another set of Falken Wildpeaks at3, the Falken’s have been great tires.
    Black DOG Lila likes this.
  3. May 23, 2020 at 8:16 AM
    Sgt.
    Jeff
    13tacotrd
    they were 3rd on my list. the look of the toyo are more aggres then the coops.
  4. May 23, 2020 at 8:27 AM
    Slick Taco
    Slick Taco Id Rather Be Airborne
    Lost somewhere in the PNW
    Current vehicles: 2019 Rav4 Lunar Rock. 2018 TRD OR DCSB KD Max tuned. 2010 Tundra Limited Crew Max . 1991 4Runner Crawler. Ivan Stewart Edition
    KD Max Tune, King 2.5 coil overs T.C. UCA's, Deaver leafs, 17x9 Black Rhyno Warlords, 33" Toyo M/T's, Metal Tech rear bumper, Westin HDX drop steps with Bullet Liner coating, K&N CAI, Baja Designs fog pods, Rigid Midnight addition 3" pod ditch lights. Cali Raised brackets and 32" behind the grill mounted light bar, Southern Style Offroad Lopro Stage II front bumper, Warn winch, FACTOR 55 Ultra Hook, FACTOR 55 Hawes Fairleed, full debadge, Cosmetic goodies such as 15% carbon tint, matte black in channel rain guards, interior LED's, Teton Workshop shift knob, Inferno vinyl detailing on the interior, Cali Raised multi rocker switch cubby insert with Mc Tuning LED switches and a few other mods I've probably left out.
    Toyo gets my vote
  5. May 23, 2020 at 9:05 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TW Jeff
  6. May 23, 2020 at 9:06 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    I've had both and prefer the Cooper.
  7. May 23, 2020 at 9:47 AM
    Philrab
    Philrab Curator of useless knowledge
    Phil
    New Orleans, Louisiana
    2015 Pyrite Mica Quad Cab Prerunner
    Bunch of Basic Taco mods.
    Looking at the Cooper LT’s or 4S’s? May make a difference in the recommendation you get.
    What’s your anticipated usage, mostly off road or pavement?
  8. Oct 9, 2020 at 6:22 AM
    TacoJon2020
    TacoJon2020 Active Member
    Jon
    Chicago, IL
    2020 Mag Gray TRD OR DCSB MT
    My bad for highjacking this almost dead thread but I'm in the same boat as OP although I'll be going with the 265/75R16 on the SCS F5 (16 X 8 6 X 139.7 4.50" +0mm) as I do not plan on a lift... yet. The versions that Tirerack.com and discounttires.com are the:
    COOPER DISCOVERER AT3 4S ($159.99) 41lbs each
    Toyo Open Country A/T III E rated ($204.10) 48lbs each
    Toyo Open Country A/T III ($169.36) 41lbs each
    This is my daily driver that runs 90-95% on-road but hopefully less in the future. I live in Chicago so want tires that will be good in the winter and on our terrible roads. I drive 60-70% on the highway. But I'm also coming from an 03 WRX with a very tightly tuned suspension so I'm used to added NHV. Though, part of the reason I moved to the Tacoma is to have a more family friendly (comfortable) adventure ready vehicle since I have a 2.5 y/o and one due in less than a month. Basically I want it all right? haha Any suggestions would be greatly appreciated from this Tacoma noob who wants a safe,capable, and fun truck on/off road.
    Thanks,
    Jon
  9. Oct 9, 2020 at 7:38 AM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    Either one but stick with SL load rating. Both brands have additional sipping on there SL vs LT.
  10. Oct 9, 2020 at 11:09 AM
    TacoJon2020
    Jon
    Chicago, IL
    This might be a dumb question but SL is the less robust version? Less plys? Reduced weight? LT is stronger/heavier? Like I said, just getting into the Tacoma world.
  11. Oct 9, 2020 at 11:20 AM
    NMBruce
    NMBruce Well-Known Member
    SW Colorado
    2020 Quicksand TRD OR, sold = 2006 GX470 (past 85, 2-1987 pickups,90, 92, 96 pickup, 2000 xtracab, 2002 double cab)
    Ironman Foamcell 3" lift, ARB dual compressor, GoPro mount, BadElf mount, Drive grab handle, RCI skids, Victory sliders, half rack, TuffStuff Alpha ll RTT, Dometic 75 Fridge, extra USB & Outlets
    I like both tires and the main two I will look at come replacement time. If most of your driving is on the road, SL tires are find, for me about 25% of my driving in on dirt roads , forest roads or off roading. I had a set of SL tires on an GX470 and one day on a nice forest road, a rock busted the belt, flat tire that can not be repaired, no more SL rated tires for me.
  12. Oct 9, 2020 at 5:18 PM
    CoyoteCalling
    CoyoteCalling Well-Known Member
    3rd Gen DCLB Silver
    Love my AT3s, but only have 500 miles on them. They feel "sticky" and aren't too loud on the road. I ran Coopers on my 4runner, and hated the road noise.
  13. Oct 9, 2020 at 5:21 PM
    TacoJon2020
    Jon
    Chicago, IL
    when that happened did you air down? If so, what psi were you at? Part of me would rather get sturdier tires for the times that I’m in the field and not looking forward to changing a tire due to a puncture. I know it’ll happen eventually but if the ride/mpg isn’t THAT effected then I’d go with the 6-8lb increase for the peace of mind.
  14. Oct 9, 2020 at 9:44 PM
    NMBruce
    SW Colorado
    I was not aired down, my tire pressure was around 38psi and I was on a forest service road that people take RV’s down.
  15. Oct 9, 2020 at 9:54 PM
    Bishop84
    Bishop84 Well-Known Member
    Toyo will last longer and better quality.
    That said I have the cooper at3 4s and I'm pleased overall.
  16. Oct 9, 2020 at 10:17 PM
    Tacoturtle
    Tacoturtle Well-Known Member
    Trey
    Athens, Ga
    2015 red dcsb sport
    I've had both, I currently run the coopers. Maybe it was just me, but I felt like the toyos did not perform well in the rain - they hydroplaned really easily.
    -Rorschach- likes this.
  17. Oct 10, 2020 at 4:01 AM
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    You must have had the old Toyo version. This new just came out around 4 months ago.
  18. Oct 10, 2020 at 10:12 AM
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    I don't have any experience with either, but just based on tread design, I would think the Coopers would be better on road, while the Toyo's would be better off road. So choose based on which is your priority...
  19. Oct 12, 2020 at 11:37 AM
    Jtlange
    Jtlange New Member
    2020 Cement TRD Off Road
    Im wondering about snow performance between these two tires. I live in CO and spend a lot of time driving in snow on I70. Which of these perform better?
  20. Oct 12, 2020 at 12:16 PM
    Thegenerik1
    Erik
    NorCal
    18 DCLB OR
    The Cooper Discover at3 4s has great reviews for snow driving.
