TOYO Open Country A/T II vs General Grabber AT2
Discussion in 'Wheels & Tires' started by Squirrellydw, Apr 21, 2015.
  1. Apr 21, 2015 at 9:54 PM
    Squirrellydw
    Squirrellydw [OP] Well-Known Member
    2012 PreRunner TRD Sport
    So i'm looking at these two tires, what one would you guys suggest? Please just suggest one of these, not interested in other tires. 265/65/17
    General Grabber AT2
    or
    Thanks
  2. Apr 21, 2015 at 9:58 PM
    Josh828
    Josh828 Well-Known Member
    Josh
    Avery NC
    14 White TRD Off road, Mid travel mountain truck
    FOX 2.5 extended travel, Fox 2.0 rears, LR UCA, XSPX rims, some light bars, and switches
    ^^^^General grabbers ^^^^^
    vvvvvToyosvvvvv
  3. Apr 21, 2015 at 10:02 PM
    Josh828
    Josh
    Avery NC
    Also my vote goes TOYO,
    both great brands,
    toyos look more aggressive
    Grabbers look kinda like the stock tires
  4. Apr 21, 2015 at 10:03 PM
    llibrm
    llibrm OH NOOOOOO!
    Bill
    Winthrop, WA &Convection Oven, AZ
    06 DCSB, 06 LC120 (sold)
    Pelfreybilt Aluminum Bumper, KING 2.5 on all four corners, 4x4 illuminated switch, Cobra 75 w/ 3' Firestick, 2M/ 70cm Radio w/ Diamond NR770HB, Pelfreybilt bed bar, Lightforce Stiker 170s, BD 20" OnX6, BD S2 ditch lites on SDHQ mounts, BD SAE Fogs
    I've not run generals but my Toyos were great
  5. Apr 22, 2015 at 4:34 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Last year I upgraded from Grabber AT2 (265/70/16 Standard Load) to the OC AT2 (265/75/16 Load Range C).
    Honestly I can't really tell that much difference between the two as far as on & off road performance. Not any serious off-roading, but a lot of gravel/shale forest/logging roads....some in good shape and other's pretty rough. Both seem similar in rain and on pavement.
    If anything the Grabbers are slightly better in the snow and the OC's are a little louder on the highway.
    I went with the Toyo's primarily because they offered that size in the Load Range C.
    So far, I'd buy the Toyo's again when I'm due for new tires again.
  6. Apr 22, 2015 at 7:35 PM
    llibrm
    llibrm OH NOOOOOO!
    Bill
    Expo portal has a great write up on a/t tires including the generals and toyos.
  7. Apr 22, 2015 at 7:43 PM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    I have the at2's in 315/70/17 and love them, they perform great offroad and handle extremely well on road and in the snow and ice.
  8. Apr 22, 2015 at 7:57 PM
    hanrock
    hanrock Well-Known Member
    craig
    sask
    2012 nauticle blue dc lb
    These General at.2s seem like a really good tire ran them all last winter and this spring . I have the e rated tires ant I am very happy with the ride have them at 28/30 psi . My only complaint is th rock they throw on gravel roads I drive 50 Kms every day on the Gravel and they destroyed the factory rear mud flaps in the cold weather other than that great traction in all conditions so far
