Toyo at3 vs kenda klever RT
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Witlocked, Apr 13, 2021.
  1. Apr 13, 2021 at 6:08 AM
    Witlocked
    Witlocked [OP] Member
    2018 TRD offroad
    Trying to decide between these two tires.
    Toyo at3 285 75r17 c load
    Vs
    Klever RT 35x10.50r17 D load
    Which will be easier to clear the tall and skinny or the shorter and slightly wider?
    I already have regear and have done the normal clearancing, cmc pinchweld cut some plastic etc. On 285 70r17 wildpeaks E load right now and they ride a bit rough in my opinion
  2. Apr 13, 2021 at 6:10 AM
    Shellshock
    Iowa
  3. Apr 13, 2021 at 6:12 AM
    Bishop84
    Bishop84 Well-Known Member
    Drop the pressures right down to 28 psi, you'll want E load if you offroad any. C load all terrains look soft on these trucks in my opinion.
    The AT3 is a far better and longer lasting tire, its definitely the better choice, along with the size.
    71tattooguy and SoCali_Guy like this.
  4. Apr 13, 2021 at 6:22 AM
    Witlocked
    2018 TRD offroad
    I was worried to drop pressure below 33psi cold cause i didnt want them to wear bad, but ill try 28 today.
    I definitely like that the at3s are 7 pounds lighter, i just dont want to have to trim my fenders to get them to fit
  5. Apr 13, 2021 at 6:53 AM
    jdiru
    jdiru Well-Known Member
    Jeff
    southern NH
    2016 Taco DCSB TRD OR- MGM
    The Toyo is a way better tire, long lasting tread and durable. I run the Toyo's on mine, awesome tire.
    SoCali_Guy likes this.
  6. Apr 13, 2021 at 7:43 AM
    GladiatorNOT
    GladiatorNOT Well-Known Member
    2017 TRD OR
    Old Man BP51 coilovers Dakar HD leaf springs Icon Delta control arms TRD Pro rims with Kenda Klever RT 33x10.5 tires Exhaust mod TRD front skid, RCI tranny and transfer case skids Southern Style Slimline front bumper Baja Designs S8 bumper light Warn Zeon Platinum 10s winch 4.88 Nitro gears ARB front locking differential ARB twin air compressor X2 Power 27 battery RCI rear bumper with Rigid SRQ lights RCI rock sliders RLD canopy Dometic CFX3 55 refrigerator TRD Pro grill Front & Rear anytime camera Seat Jackers Diode Dynamics Pro fogs
    Wow! Great advice TW members. “The AT3 is a way better tire because I love mine.” How funny!
    The Klever is a better tire if you typically air down and do any kind of serious offf roading. It’s actually my favorite tire for hitting the trails after owning KO2”s, Duratracs, and ST Maxx tires previously. The Toyo would be better as more of a road going tire and in areas with regular snow. We have a set on our RAV4 and really like them but wouldn’t run them on our Tacoma that we regularly play in the mud/dirt and do some crawling with.
    They are really two different tires for two different purposes. I guess that’s why one is classified as a AT and the other an RT. Plenty of user and some professional reviews on both. Do your own research.
    And as far as what tire would fit better, don’t just look at the tire size. Take a look at the actual specs. There can be just over a half an inch in difference between two tires in the same size.
  7. Apr 13, 2021 at 9:21 AM
    WZ00R2
    WZ00R2 Well-Known Member
    TN
    2020 Cement OR
    6112/5160, Deaver U402, 255/80r17, SCS BR6
  8. Apr 13, 2021 at 9:22 AM
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    YOu can def offroad with a C depending on what you do and even and SL
    rlx02 and Junkhead like this.
  9. Apr 13, 2021 at 12:31 PM
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    Kendas all the way.
    Solid tire. Great price. Really durable. Low road noise. Mine have been wheeled hard and I drive my truck daily. No issues.
    plus, no extra cutting needed other than CMC to get 35’s on
    oh. And for what it’s worth, I work for John Deere and they use Kenda tires on a lot of their smaller equipment and commercial mowers. Must mean something if a big company is running those tires.. just my 2 cents.
  10. Apr 13, 2021 at 4:02 PM
    Bishop84
    I don't own Toyo's and I've never even heard of Kenda tires until this post, I've worked with Toyo tires since 2005 and they have the best wear and durability of any A/T tire. I've owned R/T's and A/T's.
    I would never suggest a tire manufacturer that you have to dig and google to find any kind of information on them. These are the type of tire that shows up in a sea can and they unload them on Kijiji.
    I buy tires from tire companies that have a reputation.
  11. Apr 13, 2021 at 4:12 PM
    GladiatorNOT
    2017 TRD OR
    Wow again! That’s pretty funny also.
    I guess you weren’t around in the 70’s or 80’s then? I had Kenda’s on some of my motorcycles and bikes well over 40 years ago.
    Seems like you need to do a little more research before you post false information on TW.
    rlx02 likes this.
  12. Apr 13, 2021 at 4:26 PM
    Bishop84
    Great! They make bike tires, thats all that shows up in my regions when I search for them.
    You must be really thrifty to be buying no-name tires and putting them on a 30,000$ truck.
  13. Apr 13, 2021 at 4:55 PM
    GladiatorNOT
    2017 TRD OR
    “I buy tires from tire companies that have a reputation.” if your in the tire business I’m very surprised that you haven’t heard of Kenda before. Been around for probably as long as Toyo and have as good a rep as any tire manufacturer. Just because they haven’t been making truck tires for very long doesn’t mean they aren’t great tires. There’s lots of tire companies and tires that have been around for a long time that are still crappy.
    Check this review out on the Klever that was done on a Tacoma:
    https://www.fourwheeler.com/how-to/...-klever-rt-to-the-test-on-some-arizona-rocks/
    And show me one bad review of the Klever from any reputable site? Good luck with that. This tire has been around for several years now and has proven itself in the off road community.
    I also find it odd that you work with Toyo tires since 2005 and have talked them up but you don’t own any? And you said you’ve owned some R/T tires. Other than the Klever and the Toyo (which you’ve already said you don’t own), I only know of one or two other offerings in an R/T. Can you post some pictures of your R/T tires and tell us about them? Loved my Kenda RTs and would like to try another R/T out soon.
    Cheers
    rlx02 likes this.
  14. Apr 13, 2021 at 7:30 PM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    I've had Toyo At2s in the past, and have been running the Kendas for a couple months. Phenomenal tire so far, have had the 33s and just ordered the 35s.
  15. Apr 13, 2021 at 11:53 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I was on BFGs for 35 years on my trucks. Switched to Toyo AT2s for my older 4runner(sold) and now on my 18 DCLB and Son's dcsb. Amazing tires, light, easy to balance, amazing ride and handling, great in the rain and sand, no snow experience with them. I just put a set of AT3s on my 2000 Tacoma 4x4 and the ride is amazing. Toyos are a well known tire, very light and easy to balance, awesome 60k mile warranty. BFGs are expensive and a pain in the ass to keep balanced. I have no experience with Kenda tires, I have heard the name for years but never tried them. I'm sure they are great tires but they are heavy, unlike Toyos in a C rated or SL rated.
  16. Apr 13, 2021 at 11:59 PM
    lambo
    lambo actually dumb
    Phil
    Lone Tree, CO
    2002 Double Cab TRD OR
    Same boomer reason to keep buying BFG's despite lack of innovation. Reputation does not equal quality/performance. Refusing to change your ways is weak.
    Wulf, jeremy5000 and GladiatorNOT like this.
  17. Apr 14, 2021 at 12:04 AM
    Taconator_
    Taconator_ IG: ohv_tacotruck
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    :popcorn:
    waltuo and lambo like this.
  18. Apr 14, 2021 at 12:06 AM
    waltuo
    waltuo Well-Known Member
    Toyotas
  19. Apr 14, 2021 at 12:11 AM
    lambo
    lambo actually dumb
    Phil
    Lone Tree, CO
    Klevers are sick. Buy them, make them fit, and have fun. 35x10.5 is such an awesome size as well.
    DSC00657
    by Phillip Keefe, on Flickr
  20. Apr 14, 2021 at 2:51 PM
    Chunk
    Chunk I smell Ice Cream!
    2016 DCSB OR
    Baby Ruth
