Towing With tailgate down.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jarp697, Aug 6, 2021.
  1. Aug 6, 2021 at 7:56 AM
    Jarp697
    Jarp697 [OP] New Member
    Jared
    Toyota Tacoma Prerunner
    Hey guys I have a 2015 Toyota tacoma pre runner. It has 5’5 bed and I’m trying to tow with the tail gate down and bikes in the back. How long past the tailgate would the hitch need to be to turn corners without hiring the trailer?
  2. Aug 6, 2021 at 7:59 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    All depends on the trailer and whats on the tongue. You could have a short tongue trailer with nothing up front and be fine, or something with a long tongue and tons of stuff n not have clearance. A measuring tape will tell you all that you need.
  3. Aug 6, 2021 at 8:00 AM
    blu92in99
    blu92in99 Hates everyone, equally
    Elk Grove, Ca
    Depends on the trailer.
    Jarp697[OP] likes this.
  4. Aug 6, 2021 at 8:09 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    How long are your bikes? This worked with my quad. Would help get your tailgate up outta the way. My trailer there's no way to leave the tailgate down without it hitting my trailer jack. Also, towing forward is the easy part, backing the trailer it is far easier to get into harsh angles and need to worry about clearance. Good Luck!
    https://www.tacomaworld.com/threads/adjustable-tailgate-cables-on-the-cheap.477171/
    BMOW71 likes this.
  5. Aug 6, 2021 at 8:38 AM
    Jarp697
    Jared
    A little over 6 ft
  6. Aug 6, 2021 at 8:45 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    6 ft???
    Use a tape measure to determine the length from the center of the ball hitch to the corner of the lowered tailgate (#1). Close the tailgate and hitch up the trailer. Now, swing an arc from the center of the ball hitch with a radius matching measurement #1. Any part of the trailer inside that arc has the potential to contact the tailgate.
  7. Aug 6, 2021 at 8:55 AM
    Jarp697
    Jared
    Thank you the dirt bike is a little over 6ft
  8. Aug 6, 2021 at 8:58 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    You also need to consider the up-down movement of the trailer anywhere within that arc.
    Honestly if yore worried about Id just take the tailgate off
    Sidney Vicious likes this.
  9. Aug 6, 2021 at 11:49 AM
    TerraNerva
    TerraNerva Well-Known Member
    Chip
    Central Arkansas
    Ummm....Tundra
    Remember, the arc is not for one axis or plane. Mine had plenty of clearance when towing flat but when backing the trailer up a slope, this happened. Don’t be a me and get to constantly answer the question, ‘What happened to your tailgate?’
  10. Aug 6, 2021 at 12:18 PM
    Jarp697
    Jared
    Ok good to know thank you
  11. Aug 6, 2021 at 12:51 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Be careful with the tailgate down on gravel roads. I got all sorts of paint chips in the tailgate from stones being flung from my tires and bouncing off a small trailer. I got smart and used a magnetic sign to protect in the future.
    wi_taco likes this.
  12. Aug 6, 2021 at 3:54 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
  13. Aug 6, 2021 at 3:56 PM
    Wixo
    Wixo Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
    Just put the bikes on the trailer. Of get a front hitch receiver and push the damn thing #ItsFriday
  14. Aug 7, 2021 at 7:58 AM
    whttaco2whl
    whttaco2whl Well-Known Member
    KC
    North of LA
    2009 Tacoma base model, 2Whl 5Lug
    None
    have you tried the bike in the bed at a Diagonal position? Nosed into the front at a corner?
  15. Aug 7, 2021 at 8:01 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    there are hitch extenders that might allow tight turns that might prevent U
    crunching tailgate/bikes
  16. Aug 7, 2021 at 10:15 AM
    Pigpen
    Northwest Montana
    I use an 18" hitch receiver extension when towing my raft trailer with my camper in the bed. It's an 8' camper, so the tailgate is all the way down. Works like a dream.
  17. Aug 7, 2021 at 2:04 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Just take the tailgate off.
  18. Aug 7, 2021 at 2:08 PM
    gotoman1969
    Or this if you quick release wheels. And the tail gate can stay up. D2016172-43B8-43AC-8E71-905538DF28A5.jpg
  19. Aug 7, 2021 at 2:36 PM
    Pigpen
    Northwest Montana
    I'm guessing dirt bikes, not pedal bikes.
  20. Aug 7, 2021 at 3:37 PM
    gotoman1969
    Well heck that didn’t even cross my mind. :facepalm:
