Towing with a lowered 5-lug 2wd
Discussion in 'Towing' started by newbie taco, Jul 11, 2018.
  1. Jul 11, 2018 at 4:29 PM
    newbie taco
    newbie taco [OP] Well-Known Member
    Curious if people out there are towing with a lowered base 2wd 5-lug Tacoma? Would like to know what the drop is and how it does with it?
  2. Jul 20, 2018 at 8:10 AM
    jbruce
    jbruce Active Member
    2017 Tacoma TRD Off Road
    Don't tow with a lowered truck, ever. Reducing suspension travel kills the trucks ability to handle any kind of a load.
    Sprig likes this.
  3. Jul 20, 2018 at 11:00 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Right on. When you lower a truck you basically destroy towing ability. Bad idea and dangerous to tow with a lowered truck. First time while towing at any kind of speed when you hit a bump in the road it will be very clear why you don’t want to tow lowered.
    You can change that a little if you install air bags and maybe adjustable air shocks but I’d advise against it.
    Running Board Man likes this.
  4. Jul 20, 2018 at 8:44 PM
    newbie taco
    Unfortunately I have to lower my Tacoma a bit. I'm in a wheelchair so I have to get it down a bit to transfer in/out. I'm looking to only do a 2" drop in the rear. nothing extreme. Also considering using these Ridetech air over leaf air bags. https://www.ridetech.com/products/air-suspension/airoverleaf/ Looks like that is what they are designed for?
  5. Jul 20, 2018 at 8:53 PM
    newbie taco
    Had to follow-up. Just looked up the Toyota X-runner towing capacity. It is rated for 3,500 pnds? It is basically a lowered Tacoma. Why would that be ok?
  6. Jul 20, 2018 at 8:56 PM
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
    How much weight do you want to tow?
  7. Jul 20, 2018 at 9:02 PM
    Just Dandee
    Just Dandee Well-Known Member
    Dan
    Southwest Idaho
    2015 TRD OR
    Supercharged-2.5 lift-255/85/16
    Tongue weight will be more of a factor: I had a lowered elcamino and towed with it. Make sure the trailer is fairly balanced with only 200-300 lbs on the hitch and it won’t be of such as a concern.
  8. Jul 20, 2018 at 9:08 PM
    newbie taco
    Around 2,500 pounds . My trailer is Aluminum and is 660 pounds. Seems light to me.
  9. Jul 20, 2018 at 9:10 PM
    newbie taco
    Yes- I was going to get a class 3 hitch installed.
  10. Jul 20, 2018 at 9:28 PM
    newbie taco
    What are progressive bumps?
  11. Jul 21, 2018 at 7:22 AM
    Sprig
    Ken
    When you said lowered I thought you meant lowered like in Low rider lowered where the bottom of the vehicle is barely off the ground. 2” is hardly lowered. Depending on the weight and payload you may be ok towing. You still may want to look into airbags and or air shocks.
  12. Jul 21, 2018 at 9:23 AM
    newbie taco
    My plan was to use 2" lowered leaf springs with QA1 Adjustable dampening shocks. Also progressive bump stops. From there if it looks I need maybe some helper airbags. I would never exceed the factory towing capacity of 3,500 pounds. I would most likely be towing 3,000 pounds at most.
    Sprig[QUOTED] likes this.
  13. Jul 21, 2018 at 9:28 AM
    Sprig
    Ken
    Sounds like you have it well thought out. You should be good to go and good to tow.
