Towing in 4wd
Discussion in 'Towing' started by pipsqueek, Aug 12, 2018.
  1. Aug 12, 2018 at 1:21 PM
    pipsqueek
    pipsqueek [OP] Member
    Alf
    Sask Canada
    2008 Tacoma TRD DCLB
    2015 Bilstein shocks, Coilovers
    Quick question, read the towing bible thread, but wondering if members engage H4 aka 4x4 mode for towing. Planning a trip and have a tandem 77 x 14'. Trailer weight 1500lbs, load will be 3000lbs, so 4500 and will be crossing the Rockies, so is it preferable to leave it in 4 instead of D and engage H4 - 4x4 mode?
    2008 Tacoma TRD Sport with tow package.
  2. Aug 12, 2018 at 1:23 PM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    If you're asking if you can off road with a trailer, you can. Hi just make sure you select the appropriate hitch set up if rollover is a possibility.
  3. Aug 12, 2018 at 1:24 PM
    pipsqueek
    Alf
    Sask Canada
    No off roading just 16 hour road trip one way. Engage H4 for steep grades in the mountains?
  4. Aug 12, 2018 at 1:26 PM
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    Not unless you want shave a couple 10000 miles from your drive trains life.
  5. Aug 12, 2018 at 1:27 PM
    m603holden
    Marteeen
    New England
    If it's not off-road it wouldn't be wise to use 4wd of dry surfaces.
    pipsqueek[OP] likes this.
  6. Aug 12, 2018 at 1:36 PM
    pipsqueek
    Alf
    Sask Canada
    Haha, good point. Thx
  7. Aug 12, 2018 at 1:41 PM
    m603holden
    Marteeen
    New England
    Just put it in 3 for those really steap climbs if it feels like it's bogging down. In most cases higher rpms means less work if the rpms are within an ok range
  8. Aug 12, 2018 at 1:45 PM
    pipsqueek
    Alf
    Sask Canada
    Thanks, noted.
  9. Aug 12, 2018 at 1:49 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I'll parrot what others are saying, and don't use 4H. It's never recommended to use it on the road (places with a lot of grip) because you need slippage between the front and rear tires. And all that aside, 4H wouldn't help anyways.
  10. Aug 12, 2018 at 1:49 PM
    m603holden
    Marteeen
    New England
    Don't lie. You're using 4wd all the way to DE. Haha
  11. Aug 12, 2018 at 6:37 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Never tow in 4wd unless necessary for some off road applications. The only other time on the highway I would is if necessary is in snowy icy conditions.
  12. Aug 13, 2018 at 8:24 AM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    Why would you want to use 4X4 to toe your trailer on dry roads?
