Towing capacity , tongue weight
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gearhead695456, Feb 8, 2015.
  1. Feb 8, 2015 at 2:23 PM
    Gearhead695456
    Gearhead695456 [OP] Member
    2015 PreRunner TRD Sport
    Hello, new here, trying to buy a 2015 trd sport and wondering what is you all that own them experience with towing trailers? Specifically concerned about tongue weight , I have to pull a tandem axle car trailer with electric brakes about 4100 lbs. Not sure on the tongue weight ,as the car i tow comes relatively far up toward the truck.
  2. Feb 8, 2015 at 2:34 PM
    Nick82
    Nick82 Well-Known Member
    Nick
    Richmond ky
    2012 DCLB MGM 4x4 sport tow nav
    ARB winch bumper
    Just mention the word tow and you could possibly open up the towing flood gates of hell. I will make this one statement then I'm out.... Before you are told a dozen times to get s bigger truck. I pull fairly often a 16 foot enclosed trailer with a Polaris ranger 900 crew and lots of rescue gear. The trailer is 1700 lbs the ranger is 2100 lbs and about 500 lbs of gear making it about 4300 lbs. my 2012 v6 auto long bed pulls it great. I did install a trailer brake controller and it does a great job. As far as your trailer you want about 400 lbs on the hitch, or about 1-2 inches of suspension drop. I think you will be very happy with that set up and can expect to loose 4-6 mpg with an open car trailer. Hope this helps. Nick
  3. Feb 8, 2015 at 2:43 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    You want about 10% to a max of 15% of the tow weight on the tongue up to the max towing capacity of the truck. So if you are towing 4100 pounds you should have at least 410 pounds on the tongue to a max of 615 pounds if your truck is rated for that much.
    http://www.gmc.com/trailering-towing/tongue-weight.html
  4. Feb 8, 2015 at 2:43 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    you want about 10-15% tongue weight.
  5. Feb 12, 2015 at 6:33 PM
    RKCRUZA
    RKCRUZA Well-Known Member
    Bob
    Placerville, Ca
    2015 TRD Pro in the Garage!
    What they all have said....you are also getting up in the area where it would be nice to use a load equalizing hitch if you can't adjust the car on the trailer to give you the correct tongue weight (if you have too much tongue weight use the equalizing hitch). If you can move the car on the trailer you can adjust it front to back to get the correct tongue weight.
  6. Feb 12, 2015 at 7:01 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    This looks about 10-15% tongue...
  7. Feb 12, 2015 at 7:17 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Check this link out.
    http://www.tacomaworld.com/forum/towing/4031-tacoma-towing-bible.html
    You may be able to find someplace (CAT scale, DOT scale or even a junk yard that will let you use their scale for a small fee) that you can disconnect the trailer and check the tongue weight. Like the others said, 10-15%.
    A WD hitch will help, as well as sway control. Make sure that your brake controller is set correctly.
    Any questions or concerns on towing, definately refer to the towing bible and your owners manual.
  8. Feb 13, 2015 at 3:28 PM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    10-15% for most trailers but NOT all. Boat trailers, with trailer axles much closer to the back of the trailer, rather than utility and travel trailers where axles are centered (front to rear) generally do better with 7 up to 10% tongue weight.
    In OP situation with a car on the the trailer, may have to back it on the trailer if tongue weight is too high.
  9. Feb 13, 2015 at 3:54 PM
    Spindifferent
    Spindifferent Well-Known Member
    Central Texas
    2013 PreRunner 4.0 v6
    Tongue weight obviously increases as the car gets closer to hitch. You can measure the tongue weight with a tongue weight scale like this:
    http://www.etrailer.com/Tools/Sherline/5780.html
    http://www.sherline.com/lm.htm
    I used this scale to determine the best position of my John Deere tractor on my car hauler trailer. Took some time, but I measured tongue weight with the tractor parked at different distances from the hitch to determine the best position without exceeding the tongue weight max.
    There is a 1000lb version of the Sherline scale that is more accurate than the 2k version for the weights that we can tow.
  10. Apr 9, 2015 at 6:27 PM
    A2B in a TLC
    A2B in a TLC A to B in a Toyota Land Cruiser
    Bruce
    S. Surrey, BC
    2014 Tacoma Limited
    I have a 2014 Tacoma Limited (comes w tow package) and tow a 2012 Jayco X213. The X213 weighs just under 5000 loaded with water and gear etc. I use a WD hitch and friction anti sway.
    I did all the reading about "not enough truck" and "don't tow in the mountains". BS. I have towed Vancouver to Pemberton and Vancouver to Merritt (via the infamous Coquihalla Hwy). The truck as pulled BEAUTIFULLY. For most of the trip uphill in the mountains, I can maintain 90 km/hr (56 mph). On the 8.5% grade, I was down to 75km/hr. But so were most other trucks towing. Make sure drive in 4th, not Drive.
    Cheers,
    Bruce
    Aerose91 likes this.
  11. Apr 10, 2015 at 5:58 AM
    A2B in a TLC
    Bruce
    S. Surrey, BC
    2014 Tacoma Limited
    Sorry, forgot to mention that the tongue weight with my X213 is about 560 lbs. I did have a 150 lb canopy on the truck and it did tow fine. However, I decided to reduce weight by switching to a 55 lb Bakflip G2 tonneau.
    I use a Tekonsha Prodigy P1 brake controller. It works great. On another truck I had the P2. It was more hi-tech but tough to set up boost, etc.
    The trailer is about 23 feet long. Factory weight is about 4300 lbs (measured with a full tank of propane. With water and gear, it tows at about 5000 lbs. TT GVW is 5500 lbs, same as the Tacoma.
    Cheers,
    Bruce
  12. Apr 10, 2015 at 7:08 AM
    OCNutty
    OCNutty Well-Known Member
    Northern, Va.
    Silver Prerunner DC v6 SR5 Tow
    Not certain if i understand your 'tt gvw is 5500 lbs, same as the Tacoma' statement.
    Per the owners and code on the drivers door sticker, the prerunner v6/tow, max is 6500 lbs., 650 tongue.
  13. Apr 10, 2015 at 8:37 AM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    I have a 2005 Tacoma TRD Sport (comes w tow package) and tow a 2011 Hideout 19flb. The 19flb weighs just under 5000 loaded with water and gear etc. I use a WD hitch and friction anti sway.
    :D
    You might also want to throw in a ScanGauge to watch transmission temps while you are towing.. or you might not, they have a tendency to drive you crazy..
  14. Apr 10, 2015 at 8:45 AM
    KMitch
    KMitch Well-Known Member
    Colorado
    14 DCSB TRD Off Road
    He's referencing the gross vehicle weight rating, which is 5500/5400 depending on configuration.
  15. Apr 11, 2015 at 7:12 AM
    A2B in a TLC
    Bruce
    S. Surrey, BC
    2014 Tacoma Limited
    Thanks KMitch. :)
