Towing ATV question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by eod.mickelson, May 11, 2013.
  1. May 11, 2013 at 6:46 PM
    eod.mickelson
    eod.mickelson [OP] New Member
    I just bought a second ATV for my wife, buy my current trailer won't fit both of them. Has anybody ever put one in their bed and pulled one on a trailer? I have a 2010 TRD with towing package and from what I'm seeing I would be under payload and towing capacities. Just looking for an alternative to buying a $2k trailer....
  2. May 11, 2013 at 6:50 PM
    Redfox1
    Redfox1 'Stralia! Riding Roo's and wrangling koalas
    Conner
    Santa Paula, CA and SLO
    09 Prerunner Sport TRD
    Browning Floor Mats, 275/70/17 BFG All-Terrain T/A's, Procomp 7089 wheels,Rear Spring TSB, Bilstein 5100's, LED roof light, seatbelt chime disabled, CB, UWS Toolbox,
    Short bed or long bed?
  3. May 11, 2013 at 6:52 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    How big at the ATVs? If you're talking a small 2wd 250, you'll be fine. If you both have 800cc + monsters, then you should get a bigger trailer.
  4. May 11, 2013 at 6:52 PM
    eod.mickelson
    Access cab with the 73 inch bed. One of my biggest concerns is neither will fit with the tailgate down so it will have to be open
  5. May 11, 2013 at 6:52 PM
    eod.mickelson
    I have a grizzly 700, she has a Arctic cat 550. Both about 800 lbs
  6. May 11, 2013 at 6:53 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    You'll be fine and way under payload/ towing capabilities. Your only issue would be if you are a short bed, you may not be able to close the tailgate, which depending on your trailer, may cause issues while turning. You could get always stand the one in the bed up on end so the tailgate can close, just make sure you turn the fuel petcock off on the ATV.
    Long bed you'll be fine.
  7. May 11, 2013 at 6:54 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    You answered too quick, you'll have to get creative if you want to close the tailgate
  8. May 11, 2013 at 7:56 PM
    AKTacoParty
    AKTacoParty Well-Known Member
    Jake
    Astoria, OR
    2013 DCLB
    885s, Dakars, Bilsteins, Allpro Sliders, Archive Garage Hammer Hangers, Wheelers Ubolt flip, super bumps, RCI front skid
    I have a 2012 4door with the short bed and I had a 400 in the bed and a 450 on a little trailer behind me and it towed fine. The only issue that I found was that anything over a 400cc is too wide to fit in the bed. The tailgate was down, but it didnt bother me at all. I found that as long as the front tires are less than 42.5 inches then you should be fine. I towed it through a few mountains and I didnt even notice it was back there. Good luck
  9. May 11, 2013 at 8:00 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    I've had larger quads in my truck, just need to put the front tires up on the wheel wells. Just need to be creative some times. At one point I had my cousins tex 450 atv and my crf 450 dirt bike in my short bed. Wish I would've taken photos. That was a tight squeeze and a little sketchy
  10. May 11, 2013 at 8:00 PM
    06indigoink
    06indigoink Well-Known Member
    Charlotte NC
    06 4x4
    You'll be fine, just make sure to support the weight of the rear tires on the tailgate or it will Likely fold under the weight. The payload/towing your talking about isn't bad compared to what I've personally seen my truck/ others pull...
  11. May 11, 2013 at 8:03 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Yes, I put my 400ex in the bed (gate closes) and then tow the old man's Grizzly in the utility trailer. But, I wouldn't ever tow with the gate down. What type of wheelers are they? My 400ex is a race quad and isn't very big, most all utilities even in my long bed need to have the gate down in order to be hauled.
  12. May 11, 2013 at 8:05 PM
    2004TacomaSR5
    Jon
    Montana
    Now that I saw this, highly unlikely. I'd find a bigger trailer to haul those on. You can rent trailers pretty reasonable if you only need to use it for a short while.
  13. May 11, 2013 at 8:09 PM
    2004TacomaSR5
    Jon
    Montana
    545975_10200327163954510_855911114_n_zps_43edab2a9763878d4fc0f198a0d72a8316f76218.jpg
    OP, here is my setup, as you can see, my quad is tiny compared to the old man's. His barely fits in that little utility trailer.
